Redline Engineering Tryke/Spyder Lift The Redline TR1500 is perfect for trikes. With side extensions that aren't full length, accessing your trike from the motor forward is a breeze. It lifts to 46" high, is 110" long, and has plenty of width at 63" wide. The TR1500's features include a 3 piece removable rear ramp section, free front extension panel, built-in casters, OPTIONAL wheel vise, rear drop out panel, side extension panels, dual operation foot pump, and a built-in safety lock system. Call us or enter your order online today! ELECTRIC CAPACITY
• Release pressure will needed adjusting for max lift
• 1400 lb capacity with sides, front extension & vise
• 1550 lb capacity without sides, front extension & vise
• Air operation lifts 1500 lbs with all accessories
UPGRADE TO ELECTRIC MOTOR (INCLUDED)
• Electric is smoother, quieter, and faster!
• Upgrade to electric pump & large cylinder
• Air/hydraulic pump not needed or included
KEY BENEFITS
• Built in casters for easy moving (non load bearing)
• Includes drop out panel, front extension panel, side extensions, 3 pc ramps, pump
• 8.25'' lowered height
• Crated weight 716 lbs
• 46'' max lifting height
• 1,500 pound lifting capacity
• 80.5'' table length standard
• Side extensions are 59" long
• 139" max length with 25" ramps
• 63'' wide with side panels installed
• 29.5'' table width without side panels
• Minimum 100 psi required to operate
• Drop out panel is 17" wide x 20" long
• 110'' table length with front extension
• Constructed of 11 gauge steel .125" thick
• Upgraded electric pump outputs 28 MPA
• 6 Locking Positions (23", 27 ½", 31 ¼", 34 ¾", 37 ½", and 42")
Was $2200 with all accessories. Asking $1500. Located near Staunton, Virginia.
