Results 1 to 9 of 9
    Aug 2015
    Franklin, TN
    Default GSP on 2014 RT Limited keeps dying
    I have 6500 miles on our 2014 RT Limited and the GSP unit died two weeks ago driving to the dealer for other work scheduled. They looked at it and cleaned all the connections and it worked again. Yesterday during a long ride, it died again! The Spyder is still under warranty. Anyone else having issues? Suggestions on what to do? Thanks!
    Greg Gorgone
    Franklin, TN
    gpg28712@gmail.com
    828-708-2681
    Nov 2012
    North Las Vegas, NV
    Try removing the battery and cleaning those contacts.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2015
    southern WI
    Maybe the wires are crossed......ya got the "S" and the "P" crossed.
    Sorry, couldn't resist
    2016 RTS , Pearl White
    Default CONNECTIONS
    Quote Originally Posted by Chef G View Post
    I don't know what connections they would have cleaned........however if this fixed the problem it would lead me to believe the connection is probably loose and them fiddling with it corrected it.......But it should not have come loose again !!!!.....Something may need replacing ..........Mike
    Jul 2011
    Mitchell, Ontario, Canada
    I assume you are talking about your GPS. Pop the GPS off the mount. Inspect the contact pins on the mount. Are they straight? Are any stuck down? Then inspect the contacts on the back of the GPS. Are any damaged?
    Have you ever washed the Spyder or driven in the rain without the GPS or protective cover installed?
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    I agree with Billy , mine had the same issue. One of the pins on the mount was pushed in.
    Aug 2015
    Franklin, TN
    Quote Originally Posted by MZEMS2 View Post
    Greg Gorgone
    Franklin, TN
    gpg28712@gmail.com
    828-708-2681
    Aug 2015
    Franklin, TN
    I use the cover but I will check the pins. Thanks! I have the unit plugged into my laptop and it is fine so it has to be the connection to the bike.
    Greg Gorgone
    Franklin, TN
    gpg28712@gmail.com
    828-708-2681
    Sep 2014
    USA
    A bit of Dielectric grease on the contacts will help..Does not need much..
