Bike mounted Garage door opener
Is there a bike mounted Garage door opener available for the Spyder RT. The one that I had installed on my Harley was connected to the high/low beam headlight switch. Changing tge position of the switch would initiate the garage door opener to raise or lower the door.
I look forward to your responses.
I velcroed mine to under the dash, just behind the pull down safety card. Works great just tap the button and go. Do not even notice it there.
I Velcroed mine to rear inside surface of glove box.
try this one; if you've got dip switches this should work.
http://www.amazon.com/Transmitter-Solutions-390LMD21K-Keychain-LiftMaster/dp/B002P5TS6K
2018 F3-T
ThreeWheels came up with a very innovative design...
That's the same I did with mine.
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
X2!
BRP is still trying to catch up with Harley technology! 😂
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Pragmatic Member
I purchased a keychain size remote and velcroed it to the inside wall of my glove box. I just open the lid and press the button as I'm approaching my house. I don't even have to remove the device from the velcro. Much cheaper than the ones you install on the bike. I still have plenty of room in the glove box for odds and ends.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
