Results 1 to 7 of 7
    Aug 2015
    Carolinas
    Default Check Engine light codes and solution
    We have a 2015 RT with 4,000 miles on it and we've had it for 6 months. The check engine light came on with limp mode. We got home ok since we were only about 12 miles away. We checked the codes online, since someone here or on another site told us about the Google play app for Spyder codes. We had a code of P340 and then we had one P0000. We called the dealer who suggested we come in. The dealer told us that since it was still under warranty,
    BRP can pick up the tab for towing. So they checked it out and the problem was the CAM shaft sensor had gone bad. They sell Ski Doos also and they simply took one off of one of those in the showroom and replaced it. Problem solved.
    Jul 2014
    Mint Hill, NC
    As long as your Spyder is under the original factory warranty BRP Roadside Assistance will cover towing service up to $200 per incident. If you need such service remember to tell the customer service rep you must have a rollback truck.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Default Good to hear..!!
    Roger Rattigan put together the code app for apple and android and it has helped many folks here and elsewhere. Glad your dealer was as helpful with getting you back on the road. He's a keeper..
    ​2012 RS sm5
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by spyderjo333 View Post
    THAT is a customer conscious dealer!
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Jun 2010
    Las Vegas
    On our trip to Alaska this summer one of the 2014 RTs had the same problem. We went to one dealer in Anchorage who didn't even know where the battery and fuses on the 14 were located and another who knew what the problem was and who also took one off a display motor.
    Sounds like your dealer is a keeper.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2015
    Carolinas
    Great Dealer!!!!!!!!!!!!!! The repair was made the same day the bike was dropped off. They even let us use a trailer to bring it home. WILMINTON POWER SPORTS YEA!!!!!
    Sep 2019
    GA
    Thanks this helps. Sad part is my warranty just went out in April.
