Results 1 to 25 of 27
Thread: adding collant
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Default adding collant
    whoever designed for the location of the coolant reservoir tank ought to be shot! rant off
    Mar 2015
    Brockport, NY
    Default I'll second that
    Along with the less than ideal location, it is also very difficult to see the level of coolant in the reservoir. I think mine is a little bit low, but will need to get the angled inspection mirror out to see if I can look down onto the tank. To tough to tell by looking through the plastic to get an accurate level
    2014 RT-S Pearl White
    Default Well..!!
    it is awkward...but on the RS not too bad. I find that if you sway the spyder when checking it is easier to see the liquid. I run 75% water so tougher to see but if its moving it becomes visable. I have had to add water maybe twice in three years so they may have found this spot to be suitable. Has anyone seen where the battery was placed on the old suzuki intruders..?? Now that was a genious...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2011
    Kalamazoo, Mi
    if you shine a light into it from below the level is much more easily seen
    2018 F3-T
    2018 F3-T , Pearl White
    Bryant, Arkansas
    Be sure to add the right coolant for your year Spyder or it could coagulate and mess up your cooling system.
    Cruzr Joe
    Invalid Emails
    Oct 2015
    I added prob a pint or a little less maybe of the blue peak brand mix. all I had.
    Default OMG
    Quote Originally Posted by quasi View Post
    ....Well you were certainly low on coolant.......However as " Cruzr Joe " just mentioned mixing certain types of Anti-freeze can be very bad........and BRP doesn't use the Common Type ( that figures ) ........Good Luck with what you put in, ....what EXACTLY did it say on the container ?????......Mike
    Invalid Emails
    Oct 2015
    put it this way I will be draining it shortly! so if I go to auto zone or advance auto parts as long as it is formulated for aluminum it should be alright??
    well I guess the owners manual just ain't for looks is it! coolant specifically designed for aluminum engines. I didn't realize this peak mixture I have sitting here was so old. it's formulated for 1989 and earlier!! having worked in the automotive collision field for 30 plus years I know to check these things. oh well, the bike is 3 or 4 years old and I am sure it could use new coolant.
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    ​It's the same person who's responsible for the placement of the rear wheel air valve.
    Nov 2012
    North Las Vegas, NV
    If you think putting coolant in is hard, try changing the spark plugs.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Invalid Emails
    Oct 2015
    drained, flushed twice, filled and burped with 50/50 premix formulated for aluminum.
    Very Active Member Pandy's Avatar
    Mar 2011
    Lake Wylie South Carolina
    Default My method
    I remove the plastic cover thing for the radiator cap/dataport access (has a pictogram of both) and shine a light from the rear of the tank. So, if the level is low, I am halfway towards topoff. My $.02
    Patrick
    2011 RTS 2006 Yamaha Morphous
    Feb 2012
    Spring City,Utah
    I just had my coolant changed by my dealer( High Country Power Sports in SLC). In the course of our conversation he told me that the threaded bung was just jambed in the hole and frequently comes loose when the drain bolt is removed. They had this happen a couple of times and had to remove the radiator and welded up.Their method is to remove the lower hose and drain the coolant that way.
    Has anybody else run into this problem
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2010
    Las Vegas
    All of these things were the creation of tiny little engineers.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2011
    Default Why yes
    When I changed my coolant the first time I wrung off the bung. Solution? Purchased new plug, epoxied in place and use the lower hose drain method. You live and learn.
    Patrick
    Registered Users nightshift357's Avatar
    Jul 2015
    north Carolina
    Can anyone explain to me how to access the coolant reservoir
    Sent from my SM-G925V using Tapatalk
    Mar 2011
    Default What
    Quote Originally Posted by nightshift357 View Post
    Whatcha got? Year, model, you know, stuff like that.
    Jul 2015
    north Carolina
    I have a 2015 RT Limited, and would like to know how to access coolent res reservoir.
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Easy to access---hard to read the level
    On the 2015 RTs the cap is just below/behind the black access panel on the right side (sitting on the bike), under the frunk lid. Its got a computer and temperature Icon molded on it.
    Just open the frunk lid and pull the one Push-pin plastic rivet holding the wedge shaped black plastic cover above/behind the frunk opening. There is a Once the rivet is out, slide the black plastic cover out (note the tabs that fit in the slots), and look under the overhang to see the coolant tank fill cap. Fairly easy to get off if your hands aren't too big. In bright light you can see the coolant level or with back lighting as some have said. Otherwise, a long plastic zip tie can be used as a "dip stick" to try to guage the fluid level.
    In good outdoor light, you should be able to see the fluid level and the "cold" and "hot" level lines. A long stem funnel from the parts house can allow you to direct a small amount of BRP coolant to the reservoir. Be sure to put the cap back on to the second detent, so it doesn't leak.
    2015 RT , OEM Black Gloss
    Nov 2012
    Pueblo Colorado
    Just open the frunk lid and pull the one Push-pin plastic rivet holding the wedge shaped black plastic cover above/behind the frunk opening. Once the rivet is out, slide the black plastic cover out (note the tabs that fit in the slots), and look under the overhang to see the coolant tank fill cap. Fairly easy to get off if your hands aren't too big. In bright light you can see the coolant level or with back lighting as some have said. Otherwise, a long plastic zip tie can be used as a "dip stick" to try to guage the fluid level.
    Mar 2011
    Default Coolant check
    Sounds a lot like how my '11 access is. So now if I ever trade up, I'll know how to check coolant without having to look in that pesky owners manual.
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default Coolant leak
    As long as we are talking coolant...I note after very short ride, like from the garage into the trailer, there is a wet spot/leak under the bike. Nothing after a 200+ mile ride. Return to dealer who told me they couldn't find anything. Suggested the bike 'burped' the coolant. Frustrating it is with the 15 RTS SS 1330. Just wondering if anyone else has experienced such a leak and if so what was the cause? Thanks
    i suppose if it blows, the dealer has it on record and BRP will make good. (Let's hope)
    Mar 2015
    Brockport, NY
    Default Subtle leak on my rts 2014
    Have been noticing the sweet smell of antifreeze the past few rides and spotted some drops along the right side a arm the other day when I got home. So I checked today when it was cold and I was down about a pint. So I topped off and it will be added to the list of repairs for the dealer this spring, prior to the spyderfest trip.
    Nov 2013
    Oro Valley Arizona
    My spell check will not allow me to spell C O L L A N T? I have to do it this way. How could that happen? I guess I have a lot to learn eh Joe.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Bossier LoUiSiAna
    Default Just had similar
    Fyi had warning light go off for no good reason & asked Lamonster share pic's of mod he did. Fyi led & the Rt looks easier than my ST so good luck.
