Results 1 to 17 of 17
    Nov 2015
    Florida is home, working in Oregon
    Default BahaRon Swaybar Rocks!
    Just got back from having the BahaRon Swaybar installed at Power Yamaha with great results. It really is worth it on the 2015 RT-S Special! As a bonus, the dealer told me that the air system on the bike is not working and to schedule an appointment to get it looked at. It is throwing the "MANUAL" code for me, he couldn't get it to do that but he also never heard the system function on his test ride either. We'll schedule that for when the Corbin seat arrives.
    Default Congrats..!!
    Another happy customer. That bar does make a difference. As for the suspension it is a nagging problem hope they can get that fixed up for you...
    Sep 2014
    East Texas
    Thumbs up Another happy customer
    Welcome to the Baha Ron fan club. You made an excellent choice. May you have many curvy miles of smiles.
    Nov 2015
    Quote Originally Posted by Ben Burped View Post
    PLENTY of turns in the Oregon Cascades!
    on being another satisfied customer!
    Nov 2015
    Default Corbin on, Air Ride fixed.
    Got the Corbin Seat installed and Power Yamaha Fixed the Air Ride system as well. Found a bad connection. One side affect is the Headlights were aimed into the ground since the rear is now sitting much higher. Re aimed them. Also noted that the Spyder is not as twitchy with the new ride height. They are apparently Sensitive to that.
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Default Who is Baha Ron?
    Is Baha Ron a relative of Baja Ron?
    Pam
    Nov 2010
    Tyler, Tx.
    Default Baja Ron Sway Bar
    We have a 2010 RT-S SE5 with the Elka Stage 5 shocks and Pit Bull's shock locator. Recently we had Baja Ron's sway bar installed and it has improved the ride and stability of our Spyder. Very happy with the addition of this sway bar. You can tell a noticeable difference in how the Spyder handles.
    Reese
    Jun 2014
    People's Republic of NY
    Quote Originally Posted by Pampurrs View Post
    Pam
    3rd cousin on aunt Fannies side
    Mar 2016
    Acworth Georgia
    Smile Will a dealer install Baja Ron's sway bar
    Hello, I am a newb. Just purchased a 2012 RT SE 5. I have a disability and not able to install it myself. Wondering if a Spyder dealer will do it and at what cost. And is it advisable to purchase the bar for the 2012 RT?
    Quote Originally Posted by Rukpub View Post
    Whether or not to purchase a bar is completely up to you. But I can say that most dealerships will install a sway bar kit. However, price can vary greatly so it is wise to check that aspect before getting the work done (as with anything else).
    1-1.5 hrs. shop labor rate is about the upper limit of what they should charge you.
    Congratulations on your 'New' Spyder!
    Jan 2016
    Mandan, North Dakota
    [QUOTE=BajaRon;1101223]Whether or not to purchase a bar is completely up to you. But I can say that most dealerships will install a sway bar kit. However, price can vary greatly so it is wise to check that aspect before getting the work done (as with anything else).
    Congratulations on your 'New' Spyder![/QUOTEHi BajaRon we just got our 2014 RT Limited and the wife and i have taken it out a few times and really noticed the dipping in the corners. I watched a video on how to install your swaybar but i did notice that he took one off to put yours on. What is the differnce between the factory one and yours if you don't mind me asking? Thank you Sir. Craig & Lori
    [QUOTE=threefingers2;1103645]
    The Spyder does come with a sway bar from the factory. I've ridden a Spyder with no sway bar and it's pretty comical, to say the least! The install process removes the stock sway bar and replaces it with mine. My bars are made with thicker, stiffer steel giving you more control. This keeps the Spyder flatter in turns and more stable in all conditions. Because of the way a Sway Bar works with the suspension, this is accomplished without giving you a stiff or harsh ride. The ride straight ahead remains unchanged. Visually, it doesn't seem like much of a difference between the 2 bars. But functionally, it can be quite impressive.
    I hope this answers your question.
    Jan 2016
    [QUOTE=BajaRon;1103704][QUOTE=threefingers2;1103645]
    I hope this answers your question.[/QUOTEThank you Ron for talking time out of your day to answer my question, and yes it did help.
    Dec 2015
    Galax VA
    Mail man just showed up with my new bar and shock adjusters. Hope to be turning wrench's early next week on the RTL. Just want to say thanks to Ron for the outstanding service.
    Invalid Emails
    Oct 2014
    Calgary, Canada
    I put my Baja Ron's sway bar in myself last fall. I have two artificial knees and NO KNEELING order from my surgeon so any low down work is a PITA to say the least.
    That said, it was a fairly simple unbolt and bolt job all the while sitting on my butt beside the bike.
    The only problem I had was raising the bike enough to thread the replacement bar in place, before bolting it all back together. Believe me when I say the bike had to have been on at least a 35 degree angle to make it work.
    Far more of an angle than any ramp could make it without a bit of "help" with stacked 2x4's placed at exactly the right spot on top of my ramp ...
    Far more than I want to attempt again all on my own.
    My safety Jack Stands were also at their limit and so I didn't want to spend any more time on my back under the thing than absolutely necessary ...
    The result however was nothing short of remarkable. I no longer get the feeling I am about to be bucked off of the thing at every second turn. Truly worth the investment.
    Jan 2016
    We just got our 2014 RT and it was the first thing my wife and i noticed was the leaning in the corners , it kind of scared us at first. But i'm wondering when they charge $30,000 plus for a machine why the factory dosn't put the correct one on in the first place? It looks to me that seeing all the things a Spyder owner has to do that the Factory should have made standard is quite alot. Just a newbies observation.
    Quote Originally Posted by blitzkreig View Post
