Digital Tire pressure gauge
Lost my pressure gauge. I like the gauge that came with the RT. Looking for a replacement. Any one have a idea where I may find one. If BRP had it I would probably have to buy the total tool kit. Left it on seat and took a test ride. Bob
There are many on the market but accurate ones cost $$$. I use this it has a bleed off so when I do the fronts I over fill a bit and tap the bleeder to get exactly the same on both sides.
http://www.amazon.com/gp/product/B00...rch_detailpage
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
BRP took them out of the tool kits several years ago. Have you asked your dealer to see if he can find one for you?
Originally Posted by Magdave
i use the same & very happy
I just kick the tires
I have my foot calibrated once a year
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
Good grief! Some of us are sooo anal about stuff that doesn't really matter SO much.
I have to disagree with you on this point, the air pressure in your front tires especially need to be checked often for a good ride and proper tire wear.
Cruzr Joe
I have this except that mine has the straight tip, works great.
Cruzr Joe
Mine is similar but has a nipple for filling on it without removing the schrader valve and disconnecting. Some one on here posted it a year or two ago.
I love it!
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Cruzr Joe
Size matters and so does the air in your tires! You can take that to the bank. Listen to "Uncle Joe".
Jack
2015 BMW R1200R LC
This is what I use: EZ-AIR Tire Gauge by G. H. Meiser $19.95 on Amazon.
This allows the digital tire gauge to be connected while you put air in the tire. It has an air chuck connected to it. Best I have ever used including easy hookup to the rear valve stem.
Jack
2015 BMW R1200R LC
valve placement
That rear tire is a real PIA. I can't get a gauge or fill on it without bending it upward. Am I doing something wrong.
Allen
Ozzie Ozzie Ozzie
Nope, you're not doing anything wrong!!
Checking the pressure on the rear tire just IS a real PIA!!
Have you guys heard of "fobo bike"? Check it out @ fobobike.com. There are videos available to watch as well. I have them and they work GREAT!! Hope this helps.
i sell & use accutire setpoint at my shop
1 of the members on here uses & did video.
2011 RT-S SM5 - Black
Originally Posted by trikermutha
I see your video on ebay
Mine? Really?
Got a link...
Bob
Originally Posted by finless
Mine? Really?
Got a link...
Bob
Never mind. I found it.
Bob
Cruzr Joe
Notice the word "SO" in my post. The point I was trying to make is this: Sometimes it seems that some of the old timers on this site make the Spyder to be the most maintenance intensive thing on the road. For instance this thread....
While I agree that air pressure in one's tires is important, a half pound here or there ain't gonna make a hill of beans worth of difference in the handling or the longevity of the tire. (I seriously doubt if all but a very small minority of the folks on this forum ride their Spyder to the full the extent where the EXACT SAME pressure in the front tires is going to matter at all) Check it as often as you like, doesn't really matter to me.
There was also a recent post about valve clearances with some folks sermonizing about how important it is for the clearances to be checked at each service. Just because the book says so? The books are basically written to protect the manufacturer. (ie. the safety placard) True valve clearanc is important, but IMHO, unless you are deaf you'll hear some valve clatter before any permanent damage is done. Granted, this time you had better get it fixed. Once again, how many of us are running our spuders to the fullest extent ppossible?
Amen.
i have What you're looking for & I'm not using it will need battery replaced but works. Let me know
I use a baseball bat. Go by the tone
