Ground Clearance
I am new to Spyders and have just bought a 2015 RT limted SE6. Is there a way to get better ground clearance. I am 6'5" and weigh 350 ,my wife in small and weighs a little over 100. We ride two up and the ground clearance bothers me. The area of Texas I live in is Blackland and the highway has alot of dips and humps.
WELCOME!!
Good Morning rw,
And welcome to the madness.
I might suggest spring stiffeners---- Two different types for sale on this sight. also a BajaRon anti-sway bar. Enjoy your new ryde.
Hitting bumps in the road causes::::::
Kaos
Welcome..!!
Glad you jumped into the fray....as mentioned stiffeners if you have no adjustments. I have shock relocators from pitt bull and fox adjustable shocks and now have a 71/2" front clearance on my RS. You can try step by step...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
A set of shock pre-load adjusters, and a Bumpskid ought to set you up about right...
SpyderLovers Sponsor
I have never regretted installing a Spyderpops Bumpskid. Even if you do increase the ground clearance, you'll still encounter the occasional high spot.
2016 RT-S Special Series
I am as tall and heavy as you. There are a couple things you can do as mentioned by others here
to gain a little clearance. That's all good !
And now, the "reality". You are going to grind a couple things, and scrape over this-and-that. If you care what the
underside of your spyder looks like, then certainly get a bump skid. Your best defense is PRACTICE, and technique.
Drive enough cemetery road and you will learn to get up out of the "2 tracks", and not straddle any obstacles in the roadway.
Now, since you opened this door.....Texas. The only state in the union where the crummier the road, the higher the speed limit is the rule. Go figure. Everything you do encounter is going to be worse at "full tilt". You'll get through it...........the only question is how many bits you leave behind.
You will LOVE your RT, and welcome home.
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
First Ride
Rain finally stopped and we had a beautiful day today so after church took the Spyder out for about a hundred mile loop with wife. Topped a hill and road kill in middle of lane with on coming car. Skid plate under nose rode over it with no problems but I will be investing in Spyderpops bumpskid.. Down side I lost the thingy that holds the Key. Thought it was securely in my pocket after putting key in ignition. Got home and no joy. Does anyone know where I can get replacement? Ride was smooth a little diving in curves. Will take some training time and probably will need the heavier shocks and sway bar. Will go one piece at a time. The Highway pegs from Lamonster worked well just need a tall seat. Thanks for the welcome and information. rwc
Reason: Misspelled words
Our Spring Stiffeners will help that. Less than $100 total. Install in 5 minutes and no moving parts to break. Lifetime warranty.
http://dochumphreys.wix.com/roadster#!products/cdk6
PM in you need more info.
And I use the products I make and sell so I know they work.
Originally Posted by BajaRon
There are other alternatives out there. But this is what I offer. Fully adjustable (threaded) units that install on the existing OEM shocks. They work great! These will keep the front of your Spyder at the correct height loaded or unloaded. They also reduce sway, lean and dive in corners and while braking.
They come in Red, Silver and Black (not pictured)
I no longer scrape at the end of my driveway with my BajaRon Adjusters. Mine are red which is clearly the best color. We have installed two sets and the install isn't too difficult. It helps to have a second set of hands - might be a little difficult to do on your own. Another quality product from BajaRon.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Ron are these only for the RT????
I also have a set for the RS/ST models.
I wonder if there some adjustable shock ( air or hydraulic) trigger with a flick of a switch available out there.
2012 Spyder RT SE5 Brake pedal mod
SURE!
From my 7-29-15 post - gain ground clearance
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
Cuznjohn ended up getting heavier springs for the front of his 2014 RT...
Did he still have the oem shocks; or had he switched to Elkas?
Question: Is the caster or camber affected by these mod's that 'raise' the front end??? Pitt Bull does a Laser alignment before delivery and it would be a shame if that was made null and void.
I had never thought about ground clearance issues as I haven't bought my Spyder yet but being 6ft-5in tall and 360+++++ (?) pounds of solid corn fed table muscle, I can see trouble ahead
On my motorcycles one can just steer around a hump of roadkill that is so prevalent here in the country where I live but low ground clearance means that a lot of extra caution is required in my area.
Have you ever hit a Skunk???? OMG
Sam
2021 Spyder RT ES6 PETROL metallic. Carthage, Missouri 64836
Sam
The adjusters did not alter my alignment.
2010 RT- 622
Sam
A good question. And the answer is, not necessarily.
The idea of adjustable shock spring pre-load is to MAINTAIN proper front end height (ground clearance). Within reason, raising or lowering the front end will not greatly affect alignment. Obviously, when you load the Spyder with gear and riders, you can lose an appreciable amount of ground clearance. This changes the suspension geometry and the alignment.
Before installing spring adjusters I recommend taking a height measurement at the front of your Spyder, unloaded and with 1 rider in the driver's seat. This is likely the way that your Spyder was aligned. Then, when you load your Spyder and it loses ride height, you can easily adjust the Pre-Load on the front shocks to regain what you lost. Not only will you recover precious ground clearance. But you will return the front geometry to the same position where your alignment was set. Your Spyder will not only handle better and avoid ground strikes that might otherwise occur. It will decrease lean and dive, especially when braking.
Originally Posted by rwc
I am new to Spyders and have just bought a 2015 RT limted SE6. Is there a way to get better ground clearance. I am 6'5" and weigh 350...
The BajaRon shock adjusters solved this very problem for me. Plus, they smoothed out the ride considerably.
Also... For someone of our build, I would also strongly recommend the BajaRon beefier anti-sway bar. It'll also offer a considerable handling improvement in the turns.
Do you know if Elka Stage 2 will raise the bike up?
I am about to consider upgrading from my 2012 RTS SE5 to a 2015 RTS SE6.
I am considering installing Elka Stage 2 shocks which my dealer recommends as things can be dialed in more preciously as he says.
Regardless will adding these do the same or do you all still suggest Spring adjusters?
2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
The Elka Stage 2's already come with spring tensioners. BajaRon offers that option at a much lower cost for our OEM shocks.
