Pragmatic Member
Rotating front tires
Has anyone taken their Spyder to a tire shop and had them rotate the front tires? I could take the wheels off and take them into a shop to have the tires switched from rim to rim, but it would easier to just pull in and let them take them off and mount them. I'm just wondering if any tire shops would be able to do that.
The manual says to rotate them when the tread depth gets to 4mm, and mine are at 6mm right now. Just planning ahead.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
YES
yup, i've had dat dun b4......
however, when u buy nu tires, DO NOT buy UNI-DIRECTIONAL tires.... dat way us can just take da left tire n put it on da right, n take da right tire n put it on da left.... I'VE DUN DAT on my RS with NO ILL EFFECTS....
and i'll do it again once my F3-S needs nu tires up frt.....
DAN P
SPYD3R F3-S
Pam
I only have 1 tire shop that will remove & install on the spyder. Most places like BigO only touch the tires only do to liability or jack won't fit
If the Spyder has the original Kenda tyres on it you can NOT rotate them – the Kendas have directional tread. Most owners replace their rear tyres about 4 or 5 times before they need to replace the fronts, unless poor wheel alignment has reared its ugly head and caused uneven wear.
Lindsay, originally on a 'poor-man's-ST'... an '08 RS with all the after-market bells and whistles, but now on a '16 F3, furiously adding bells and whistles.
Sunny Queensland in Australia.
Pragmatic Member
Please re-read my question. I am well aware that they are directional tires, thus the need to take them to a tire shop to be switched.
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
I'm not sure it would be worth it, I have read of some that have done it and the tires were damaged. If they are wearing even, I would leave them alone.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
OK, point taken, but there are many owners who believe that simply rotating the wheels will do the job – it won't. But why worry about rotating when the wear is already well advanced? The fronts wear so s-l-o-w-l-y that you have lots more life left in them.
Pragmatic Member
I've got a little over 10,000 miles on them now. It can't hurt to rotate them and possibly get another 10,000
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
SpyderLovers Sponsor
I have 21k on the fronts of our RT. They still probably have 5k before they will be on the wear bars. At that point I plan on installing cage tires...
Pragmatic Member
Good to hear you've good mileage out of them. I also plan to go to cage tires when these OEM tires expire..... front and rear.
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
Lotsa miles
I got 26k miles on my front tires before changing and the only reason I changed then was because we were going to do twistys in Tenn. and N.Carolina and I wanted extra good tread . I put the original brand back and am very happy .I see too many riders try to squeeze the last mile out of a tire and to me it just ain't worth it .
Pam
I have over 20,000 and have never rotated them, still look like new
I Took them off the Spyder hauled them down to Firestone they swapped them from rim to rim rebalanced. Well worth the $35.00
If your tires have any uneven wear to them you are wasting your money rotating them.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I thought one of the reasons for rotating tires was to even out uneven wear.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
You need to fix the problem that causes the uneven wear and that is usually caused by the Spyder being out of alignment.
2010 RT- 622
Thanks for clearing that up
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
True That!
You'll actually be fixing more than 1 thing.
1- You're front tires will last longer (maybe MUCH longer)
2- Your Spyder will steer easier
3- Your Spyder will handle better
4- You and your Spyder will be happier
Happier is good!
Originally Posted by BajaRon
Directional tires usually do much better in the rain. They typically resist hydroplaning much better than Non-Directional tires. Since the Spyder is susceptible to hydroplaning, and it can be quite hazardous, it isn't a bad idea to stick with this kind of tire. Good traction in the rain is worth much more than being able to swap sides without dismounting the tires.
And, if you have good alignment. Front tire wear is typically pretty even, eliminating the need to rotate.
Absolutely correct.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Rotating
What you want done is exactly what I do. I rotate mine every other oil change and it's worked wonders for tire longevity. I remove mine and take them to my regular tire shop. In my experience, most commonly used floor jacks are too tall for Spyder use so that's why I remove and haul in. If they aren't too busy, they will do this without charge. I hope this better answers your original query, now stand by for posts about jacks that fit under an RT that automotive tire shops surely have.
Patrick
2011 RTS 2006 Yamaha Morphous
Patrick
Front tires in general last a looong time and considering the age factor along with UV deterioration, I simply question the cost/benefit result. What with time, transportation, service costs, etc.
Flipping....
In my time here I have seen more issues from rotating the tires than benefits. I had uneven wear got an alignment.(Squared Away) and got over 30,000 miles out of them. (Kendas) I have not seen or heard that doing it has evened out the wear on the tires...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
