Metric bolt/screw size per location
Is there an info location as to which size metric screws are needed per mounting location? Some of mine are longer--mostly m4 or m5, the sheet metal screws holding the headlamp outer panel were way to loose/stripped--replaced with larger screws. One of the lower windshield mount screw was cross threaded & torque head stripped & easy out failed to remove :-(
I gots to stop working on this F3's at night in dim lighting
Don't know..!!
Shop manual may have some but outside of the bolt and nut torque spec's section don't think there are. You just need to pull a good one from another location and match it up. If they are not backed they can be a bit longer but I wouldn't go to short. (especially battery posts)....
2012 RS sm5
Put BRP Parts in your search engine and select the BRP Parts catalogue
You just need to search for you model, & Type, Year and you should find both Size and the torque settings
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
