Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    Quote Originally Posted by Hayfield View Post
    Heated gloves are the best option - but ski gloves work well, too
    For SERIOUS cold weather; snowmobiling gloves will work even better!
  2. #27
    Oct 2013
    rome new york
    Yes sir Bob
  3. #28
    Active Member GeorgiaBill's Avatar
    Aug 2015
    Marietta, GA
    Default Hippo-Hands
    Quote Originally Posted by DrewNJ View Post
    I've thought about those. Any issues grabbing the clutch? How easily can you get your hand on/off the bars? Any recommendations on a specific brand? Thanks!
    I have heated gloves and jacket liner, but those weren't enough several years ago, so I bought Hippo-Hands. Attached them to the handlebars, inserted my hands into them and went for a ride.
    I was kind of mentally dense that day, so when I noticed my gas consumption was really poor, I stopped and checked for gasoline leaks and found no problem. Then on my way home from the North Georgia Mountains I engaged the cruise control, which had stopped working. Finally realized the Hippo-Hands were being pushed into the brake and clutch levers, and took them off after a single use.
    Since most of us don't have brake or clutch levers, Hippo-Hands might be an option. I think I might try mine one more time this winter.
    -Bill
    2019 Black F3-T
  4. #29
    Very Active Member AMTJIM's Avatar
    Jun 2008
    Vail, AZ
    It's more likely the wind chill that's getting you. Get some brush guards, I have the attachment parts from two cheap cycle gear brush guard kits and some Can Am Quad brush guards. Another possibility would be the Yamaha brush guards they use on the new FJ 9 or the Tenere
    In the twisties I was playing the tart...
    2009 GS SM5 , Red/Black
  5. #30
    My Missus will often complain about her hands getting cold...
    Has anybody figured out what sort of "Brush Guards", mount up to the passenger grab rails the easiest?
  6. #31
    Jun 2008
    Vail, AZ
    That's what your luv handles are for, Bob...make use of them.
  7. #32
    Active Member Brettssunshine's Avatar
    Jun 2015
    Lancaster PA transplant (Southern born and bred)
    So many options! I've got to look into some of these things because I don't want to give up riding yet!
    2015 F3-S SE6
  8. #33
    Jun 2015
    Quote Originally Posted by bmccaffrey View Post
    Hot hand warmers.
    Cheap throw them in gloves ,boots instant heat 6-8 hrs
    Used for hunting . Work great
    I've tried these on several occasions.....on my own and riding as a passenger in my gloves and boots; they just can't keep my hands warm enough. My husband tells me all of the time that I'm part zombie.
    2015 F3-S SE6
  9. #34
    Cold hands... warm heart!
  10. #35
    Oct 2013
    rome new york
    Quote Originally Posted by Brettssunshine View Post
    Really
    I 've had them almost burn my hands when they were against bare skin.
    I think heated grips and gloves may need both to keep them hands warm
  11. #36
    Mar 2012
    NJ
    Really
    I'm using the pollyheater snow mobile grip heaters that go inside the bars. I use hi to warm them up and kick them down to lo while ridding. Even then I have to turn them off once in awhile because they get so hot I have to "air out".
    I'm quite certain that if I left them on hi the entire time that I could melt the grips off the bike! [emoji38]
  12. #37
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    There are battery powered heated gloves that work pretty well, and don't need the wiring to the Spyder's electrical system. Carry some extra batteries, just in case.
    john
  13. #38
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Hot hand warmers.
    +1 They work. My winner ridding gloves have a compartment for HotHands warms. They also make body warmers and foot warmers. I put body warmer under my layered cloths. One on my chest, lower back, arms, and legs. My wife does the same. We live in the northeast mountains of GA. and it gets cold in the winter.
    Mike
  14. #39
    Jul 2011
    Mount Airy,Ga.
    Quote Originally Posted by asp125 View Post
    Anyone know? Does the RS charging system have enough power to run heated vests and gloves for both driver and pillion?
    The charging system only put outs 500W at 6,000 rpms. Under 6,000 rpms is not known. The lighting system on my RS uses 185 to 205 W.
    Mike
