2012 RTSE5 stalling at take off. FUN in heavy traffic!
Bike has 13,532 miles and it recently started this craziness. The "check engine" will flash at random during take off/first gear only (no flash pattern, just random flicker). Oil level is good. Fuel tank is not overfilled. Then it started cutting off at random during take off. Now it started stalling at take off a lot and sometimes while coasting with the throttle close. Will restart instantly while still moving. Have to learn how to pull any fault codes (nothing strange has ever shown up on the screen) that are in the bikes storage and start pulling panels and check out the vacuum hoses for any leaks. Also think I read something about a RPM or crank position sensor coming loose that causes bad ride results. It also started to idle a bit rougher that normal. If it was a car I would think mass air flow sensor. Gonna read thru the owners manual really well before tackling it, also have the shop manual. Any leads on possible causes highly appreciated! Keep y'all posted on my success.
As far as vacuum hoses, check the 2 small hoses on the left side of the engine going from the MAP sensors to the throttle bodies. These fail a lot.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Got the panels off but the bugs are coming out so I hung it up for the day. Found 1 of 2? of the MAPS hoses, and they "look" good. Manual states the correct length so I may replace it/them anyways to play it safe. Has anyone made a home version of the BUBS hook-up yet so you can check everything yourself, or does it require to much to make a home version feasible?
Spydercodes android ispyder app store
Norm H Austin Tx
2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
The auto stores have some better quality hose replacements, remember to keep the hose lengths the same. There have been several posts giving part numbers. Although the 2012's are not known for throttle body issues, you may have a bad one. This would require a trip to the dealer and a hook-up to the "BUDS" for verification.
Just my thoughts and good luck
Stalling Issues
Another thing to check would be the purge valve. I was having stalling issues similar to what you describe. My dealer replaced the purge valve and it has been running great ever since!
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
Pull your codes by pushing mode,set and turn signal buttons straight in, at the same time. Then you can check the results on the Spyder codes app.
Good luck.
Ryde as if your life depends on it,
because it does !! Ryde Safe!
Vietnam 67-69
Banged Up Member
12's were notorious for throttle body issues.
Chris
Chris
I think that was the 11's that had the throttle body issues.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I have the same spyder. I had the same problem. 11500 miles. last year I replaced the hoses. the hard to find hose is behind the wires opposite of the first hose.it looked good but take it off and bend it to see the cracks. 20 miles when new the throttle craped out and had to replace it.
FINALLY got the hoses found and removed. Rear hose looked good, front one was cracking. What size have you all found for the MAP hoses? NAPA had 1/8th inch fuel line hose but it does not fit very tight. O'Riely's had Prime Line clear (part#7-081532) but its to small of a diameter. Have fuel hose from work and it was also to large inside diameter. We have a hose specialist in our area. What exactly am I asking for again? Thanks again for any and all help!
Napa H466
Finless has written a complete documenation on the subject of MAP sensor hose failure and replacement.
http://www.spyderlovers.com/forums/s...ghlight=vacuum
Reason: added link
Thanks for the link. I did not find that info with the search engine option, think it has more to do with my computer skills than with the site. I ordered the hoses Frank showed from NAPA, strange that the hoses were not in stock. Will have the wifes Spyder back up and running this Wed. Thanks again for the help!
some good to know info, i will be ordering me some of those hoses to keep on stand by..
2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
Banged Up Member
Below is what I was referring to. This was posted by Lamont in another thread sometime ago.
Chris.
Roadster 2012-4 A Updated Throttle Body Actuator Protection B
This is just a heads up for all 2011-2012 RT owners. Your dealer should be contacting you but if you want to be proactive you can contact them and setup an appointment to have the 2012-4 done.
Middle Side Panel Grommet Replacement 2011 Models Only
All involved customers must be notified, all involved units must be corrected as per instructions herein
Product: |
Roadster |
Bulletin type: |
Warranty Campaign |
Bulletin no: |
2012-4 (rbg2012-005 en AG) |
Revision no: |
Revision date: |
Campaign no.: |
2011-0013
2012-0004 |
Publication date: |
April 4th, 2012 |
Subject: |
A) Updated Throttle Body Actuator Protection
B) Middle Side Panel Grommet Replacement (2011 Models Only) |
YEAR |
MODEL |
MODEL NUMBER |
SERIAL NUMBER |
2011 |
Spyder™ RT |
All |
All |
2012 |
See attached list |
PROBLEM
Problem A
In some conditions, the throttle body actuator could get damaged, which could lead to fault codes or limp home mode when trying to start the engine.
IMPORTANT: For 2011 models, carry out this campaign even if campaign 2011-0008 was already performed on the vehicle.
Problem B
One some 2011 vehicles, one of the middle side panels rubber grommets might fall off after multiple removal and installation of the panel.
SOLUTION
Problem A
Update ECM with revised software.
Just a little FYI on the ECM update.
The throttle body actuator protection portion of the bulletin is very important as updating the ECM software will greatly increase throttle body reliability. This bulletin applies to all 2011 and 2012 RT models. It does not apply to 2010 RT models. Under certain conditions, the ETA (electronic throttle actuator) could experience an over-current period which would overheat the electric motor and cause it to fail. This type of failure would result in the engine going into limp home mode at start up and trip any of these codes. P1614, P1610, P1611 or P1615. When this happens it is necessary to replace the entire throttle body. With this new software in place, the ETA cannot receive excessive current. Operation of the vehicle will not change in any way. There will still be the quiet humming as the throttle blades are held closed for 40 minutes after the engine is shut off. It will start and run exactly as it did previously.
All done and sealed back up! Runs feakin' GREAT! I'm basking in the success of doing it myself with some donuts. Its the little things in life. Anyways, now I have to find out what Service Bulletin(s) have and have not been done. Im the 2nd owner and the dealership did register it with BRP BUT that appears to not guarantee getting notified of anything. Back to enjoying the Spyder again, the wife will be so happy to ride it now all fixed and reliable!
