Results 1 to 20 of 20
    Active Member ChrisW's Avatar
    Oct 2013
    Fernley, NV
    Default Need RT Passenger Arm Rest's
    We have the first year 1330 RT and the wife wants her passenger Arm Rest's just like she has on my Goldwing. Can anyone help us with finding them please?
    Thanks Sandy & Chris
    The Wife's 2014 RTS SE6
    New tires: Back, KUMHO ECSTA 225/50 R15 (24psi) @ 9,380 miles, Fronts, KUMHO SOLUS KH16 175/55 R15 (20 psi) @ 9,421 miles
    Invalid Emails
    Feb 2015
    Wichita, KS
    I have a set from Corbin that works well and my wife likes them.
    Jun 2010
    Las Vegas
    Diamond R makes some that swing in and out.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Linden, CA
    I have them ... Rivco
    Give me a call
    Dave
    Quote Originally Posted by ChrisW View Post
    Oct 2013
    Fernley, NV
    Give me a call
    Dave
    How, do you have a web site?
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    my wife loves the Revco's and yes they swing out as well.
    2015 RT Limited Intense Red Pearl
    Member jimsrts15's Avatar
    Dec 2013
    Harlingen, Texas 78550
    Default RT arm rests
    Copy and paste this URL, http://www.bigbikeparts.com/template...9&GroupGuid=59
    Happy riding. J Clark
    Active Member Dochatley's Avatar
    Sep 2015
    Dallas
    Quote Originally Posted by spyderbee13 View Post
    Just added a set of these and also got the drink holder they have to go with them. Very easy install and they work great.
    My Missus loved the Diamond-R set that we had on our 2010 RT...
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default We have the Ultimate Seats rear arm rests
    They look identical to the Rivco - maybe the same part. Reasonably easy to install and a rear cup holder can be attached.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Active Member Red RT-S's Avatar
    Newport, VT
    Default Corbin arm rests
    We have Corbin arm rests and while they work well I cannot recommend Corbin. First they took several weeks to be delivered which seems excessive to me for what should be an off the shelf item. Second, the installation instructions were not good. They tell you to remove 2 screws in the trunk. There are actually three, and the third one is hidden pretty deep in the darkness inside the trunk. Third, the reinforced screw holes in the arm rests did not line up with the holes in the trunk, thus you have to put the screws into the arm rest where it is not reinforced making the mounting much less secure. I bought these because of Corbin's reputation, but I doubt I will purchase anything else from Corbin.
    Active Member remark2013's Avatar
    Sep 2014
    Los Alamos, New Mexico
    We have the RIVCO's and love the look and comfort . They also pivot in and out!
    Kent.
    Ride Safe All
    2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
    Nov 2012
    North Las Vegas, NV
    http://www.motorcycledave.com/
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Invalid Emails
    Apr 2015
    Montgomery, Al.
    Default Passenger aem rest
    Be careful with any that mount to the side of seat. The ones I've seen have a metal/rubber insert that is only in the plastic. Easy to pull out with little downward pressure. Plus if you s/o is somewhat a "widebody", it
    cuts down on room and will rub or bruise thighs.
    I know.
    Can't remember the brand I have but they have a metal
    plate the mounts under the seat. And with my Ultimate
    seat, I had to shave down the bumpers a little so that the
    seat would close as it should.
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    Rivco on our 2015 RTS Wife loves them
    Bill
    2018 RT Anniversary , Brake pedal extended
    Feb 2015
    Louisiana
    Default Passenger armrest
    Quote Originally Posted by Ex Winger View Post
    Bill
    I have the Diamond R armrest, not really satisfied with them. They are pretty filmsy can't put any pressure on them or the mount will bend, they also vibrate really bad.
    Active Member Empty Pockets's Avatar
    Apr 2013
    Monument, Colorado
    Rivco here as well, works good for us
    Bryan
    Sep 2015
    Parkesburg,Pa
    Just installed rivco,easy install and the 3 rubber mounts in the plastic feel strong,wife likes them
    Active Member jonnysevel's Avatar
    Jul 2013
    Stevenson, Maryland
    I have the Corbin arm rests on my 2013 and they are fantastic!! Install was a little tricky but everything lined up perfectly when it is installed correctly! Very solid and they look really good.
    Jonny
    2013 Spyder RT Limited
    • TricLED 3rd and 4th Brake Light
    • Spyderpops Bumpskid with TricLED LED kit
    • GloRyder Wheel Lights
    • Spyderpops Missing Belt Guard
    • Corbin Arm Rests
    • TricLED Turn Signals
    Linden, CA
    Default motorcycledave.com
    motorcycledave.com
