So I am wanting to clean the bugs off the front grill of my F3 and I read somewhere not to use a pressure washer your spyder. What is the best way to get the buggage off the front grill? Thanks[emoji16][emoji16]
take mine to the car wash all the time. oops! it works!
there are comercial bug removal sprays at your local autoparts but soapy water works well and a lot cheaper. Most of the spray cleaners like black diamond, plexus, protect all, pledge do a good job as well...
Gene and Ilana De Laney Mt. Helix, California
2012 RS sm5
Here's a little trick I learned from owning airplanes. I had major bug guts on the leading edge of the wings that were a pain to get off. An old timer aircraft mechanic told me to use WD-40. Worked like a charm.
Lamonts black diamond cleaner Was rage @ spyderfest'15. Rest is like any vehicle -soap water rag & ELBOW-grease ,common sence helps too dont put all ur weight on hand with soapy rag& or find a donation event that offers car wash,granted more of a spring time thing, but can be found. Dont try to be nice & let family or neighbors kids wash it for you. Will end up with pools of water in wrong places & no telling what else jacked up.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
it's hard to get bugs out of the grill on the F3, I had a grasshopper infestation on the way to the Deadwood rally and tried to get them out of there with just a hose and a toothbrush. Luckily it's only 4 screws holding the grill assembly on. If you need to, get a #30 Torx screwdriver and take that bad boy off and clean them off from the backside.
We now have His and Hers Spyders!
Current Spyder: White 2015 F3-S SE6
His Spyder: White 2015 F3 SE6
I sure hope you were behind a windshield on that trip. Otherwise you could have skipped supper.
Luckily I was, but from the knees down, my pants were covered just like that too. The gross part was I didn't even notice any of it until I stopped to take a picture along the needles highway and stepped away from the F3. Then I saw that as I was headed back to it. NASTY!
I live in the area, so any trip out on to the plains, this time of year, tends to gum up the works. I shot water from about every angle and still had to pluck hoppers out of the grill with a small needle nose. I went to the dealer to order the new grill that is in the 2016 parts catalogue because it doesn't have all the cross bars. Figured it may be a lot better for those of us in big bug country. As with a LOT of stuff that BRP offers, it's not available and won't be for at least a couple more months. By December, I don't anticipate grasshoppers being a problem!!
