Originally Posted by Mikescanam
That'll work 😎
It couldn't hurt you to have a few more lights 😎
Wiring Harness?
Which did you purchase?
Thanks
Thanks
Originally Posted by cheska
Nice trailer
Thanks
Plate blocked
Here in Ca you would have an issue with the hitch blocking the license plate. I have also heard, but never got a real answer about warranty issues on the F3 and a hitch.
2015 F3-S. And Another Day To Be My Kids Dad
Very nice..!!
nice setup. Looks like you have to remove the rear axle but is well made and should do the trick well. Cool trailer... can't beat the price either...
2012 RS sm5
wiring harness
blocking plate
the hitch can be unbolted with 4 bolts the side plates stay attached to the frame that way you can remove the hitch when not in use . They can not see the plate when you are pulling a trailer so if you remove when not pulling trailer you should be alright
the guy that sells them was at spyderquest this year with the same f3 that's in his picture on ebay. looked like a nice set up!!
Ordered yesterday! How did you wire that into your wiring harness? Did you use an isolator?
Wiring
yes I used a universal trailer wiring and relay wiring harness from Kuryakyn part # 7671 and a 5 to 4 wire converter part # 7675 also from kuryakyn
Got mine this week but not yet installed. I called Canada and inquired on wiring harness and they have one for the F3s as an accessory item for $69 US. Only one problem, if you have the 2015 Freedom trailer, their harness won't plug in as it is a "4 flat" male plug. Easy fix.
