Results 1 to 25 of 36
    Aug 2015
    Maryland
    Default New fault code C0042
    I just replaced front brake pads, rotors, and rear tire. Now the 2013 RT Limited throws Brake Faults on display. Tried the display reader trick and received a C0042 code which isn't anywhere I can find. Anyone know what's going on? I had a stuck caliper that started all this and now my pedal is softer than it's ever been. Not sure I like the long travel.
    Jun 2013
    queens ny
    are you sure that is the code you got, i could not find it either
    NO BIKE AT THIS TIME
    Aug 2015
    Maryland
    I just took it out again and verified. Sort of random events cause it but definitely I get BRAKE FAILURE message and then the console can be used to display C0042.
    Nov 2012
    North Las Vegas, NV
    Did you bleed the brakes?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Aug 2015
    Maryland
    Bled the brakes, front and rear, no bubbles. Saw in shop manual something about VMC (VCM) bleeding? Know anything about that?
    Sep 2014
    USA
    Aug 2015
    Maryland
    Tough read on image but helped find the page in my manual. Now to figure out WTH that module is located. Looks like under front Tupperware.
    Sep 2014
    USA
    looks like somewhere around the front suspension area under the tupper ware.. behind wheel area
    Very Active Member garb55's Avatar
    Coolidge Arizona
    I think you need to be connected to the Buds system to activate the VCM and bleed it
    I read that somewhere
    should not need to bleed VCM unless you allowed the brake reservoir to suck in air
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    You can bleed the brakes without BUDs but it wont bleed the ABS system as you cannot open it without BUDs.
    While doing this work never turn on the key. If you do it can log a fault that you might not be able to clear without BUDs.
    Bob
    2011 RT-S SM5 - Black
    Aug 2015
    Maryland
    Default Still no definition of C0042 code
    Quote Originally Posted by finless View Post
    Bob
    I can't say anymore what I have done or not done with or without the key. I would suspect the good news is the error messaging will 'clear' itself from the display every time I shutdown the bike and will randomly rear it's ugly head during the next test ride or two.
    This all began back at the dealership when they 'mis-informed' me, do not want to go back there for BUDS service.
    Still shocked that no one has chimed in with a definition of a C0042 code!
    Site search yields zip. WWW search yields all but this vehicle.
    May 2013
    Stanton, ca
    Quote Originally Posted by DonCopenha View Post
    I looked in all the code documents I have including the new list that was published for 2014/15 and the new F3's.
    That code is not in any list I have! But it is inbetween codes all related to the VCM and brakes.
    Bob
    Jan 2012
    Texas
    Default abs bleed
    Bob
    works for cars, won't hurt to try, find loose gravel about 30 mph apply brakes hard so abs activates, do several times, this purges air out of system in a car, don't see why it won't work on spyder
    Member jimsrts15's Avatar
    Harlingen, Texas 78550
    Default fault code C0042
    Sort or new to forum. C0042 is a VCM code meaning low break pressure switch (LPS). good luck J. Clark
    Default fault code C0042 cont.
    possible causes of C0042.
    LPS activated,
    Low brake fluid,
    Brake fluid leak,
    Air in hydraulic brake system
    LPS circuit failure,
    Master cylinder piston seal failure,
    possible service actions,
    Check LPS
    Check brake fluid level,
    Inspect for brake fluid leak,
    Bleed brake system to remove air in hydraulic brake system
    Check LPS circuit,
    Replace Master cylinder
    Aug 2015
    Maryland
    Quote Originally Posted by spyderbee13 View Post
    LPS activated,
    Low brake fluid,
    Brake fluid leak,
    Check LPS
    Check LPS circuit,
    That's what I needed, a direct reference to the code, thank you. We performed a manual bleeding process last night and found air in the VCM. The ryde is still on the lift for its oil change but I'm hoping that solved it. If not, I'll be walking down your list and looking for the gremlin.
    May 2013
    Stanton, ca
    LPS activated,
    Low brake fluid,
    Brake fluid leak,
    Check LPS
    Check LPS circuit,
    Where did you find this code? What documents? I have all the code documents from BRP and it doesnt list it.
    Bob
    Default Code C0042
    To Finless: Have BUDS.
    Aug 2020
    Doha
    Did you find solution for this problem ? I had the same thing and didnt know what to do
    This thread goes back to 2015.
    Jul 2015
    Dorr, michigan
    This is quite interesting, even though this is years old it still pertains it sounds like.
    I now have 3600 miles on my 2020 RT Limited, and on the way home last night got a brake failure warning with code C0042.
    I have looked through the repair manual I purchased, the owners manual, Lamonsters code page, and as of yet have not found what C0042 is.
    I Turned the bike off, waited about 30 seconds, restarted it, and all lights were off and no more code showing on the screen.
    2020 RT Limited , Petrol Blue
    Sep 2018
    greensburg,pa
    Did you have your foot resting on brake pedal? I remember some having an issue with foot touching pedal long enough that the ECU throws a code.
    Not sitting at a red light,but rather riding for miles and the brake pedal is slightly depressed.
    Check the fluid level also.
    2018 RT-L , Blue
    Aug 2020
    Doha
    Did you find the reason of this code i have the same issue like you have and when i shut it down the code and the brake failure message disapear and just in the next ride directly shows up again so any advices ??
    Sep 2014
    USA
    Have you tried to bleed the brakes since you mentioned the pedal is soft.
    Dec 2020
    Australia
