Missing Saddle Bag Reflector
I rode a couple hundred miles yesterday. I wanted to give the 2013 ST Limited a bath before putting her to bed. Sadly, I noticed that she is missing a reflector on the left side saddle bag. It's the oval shaped reflector right in the middle of the side. Any idea where I could pick up a replacement?
All the best,
John
Dealer or BRP has them. I bought some last month. Wasn't too expensive. Can't remember exactly how much but under $20 for a set I think.
2013 Spyder ST Limited Black Current
stock (so far)
stock (so far)
How are they attached? I couldn't see where there was any adhesive.
All the best,
John
Bag reflector - sun
What is it about heat and these spyders? From the DESS codes (had mine replaced after it overheated) to letting bike sit in the sun while visiting the dealer and the reflector was on the ground (on that sunny side) when I came out. Needing to be regular on. Glue issue on these Givi bags
All the best,
John
That must be why it fell off.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
A double self adhesive thick rubber "Spacer". It is probably still attached to the reflector. A recommend roughing up the plastic area of the bag with course sandpaper to give it some gripping surface and clean with alcohol before installing. Mine seem pretty secure for now
stock (so far)
Adhisive...
get some 3M double sided tape. Clean off old adhisive then clean both surfaces with alcohol. Do not rough up the surfaces these tapes like smooth flat surfaces. Then reinstall. Keep pressure on for a minute or so...
2012 RS sm5
you can also use a hot glue gun to stick the reflectors
osm
Both of mine fell off. First the right then the left, all in the first 3000 miles. The replacements (under warranty) stayed on. The right side after my accident (complete new saddle bag) is also now staying attached after about 5000 miles. New or better adhesive??
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
Had same problem
Took pic one week was there, another pic it was missing, only way I knew. Mine was covered by warranty fyi. Yes double sided sticky tape like the 3m you can get at auto parts house. Clean surface with alcohol (Let evaporate dry) & dont have to scuff up, better if smooth but MUST BE CLEAN! keep pressure holding good contact for 15min or more, I took my bag off & stacked books on top overnight.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
stock (so far)
Thanks..... I've lost three..... I'll order replacements tomorrow.
Keep 3 Down..!!!
I believe you're looking for part#704902053, Spacer Decal, $4.99 and 705001572, Rear Lateral Reflector, Red, $24.99
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Golden opportunity to upgrade
This is the perfect time to upgrade to Custom Dynamics "Brightsides". Better visibility and better product. It's held on by 3M adhesive that sticks extremely well after it's activated. It's a win-win-win situation. Consider it. If you want a product that is inherently reflective, TricLED makes a fine product and is sold by a really good guy.
If your spyder is still under warranty, the dealer will get you a free replacement set. I had one fall off also. once they fall off, you cant get them to stay. They gave me a set but I had to put it on myself.
My wifes new Harley had the tank badge fall off. They replaced it as well.
2017 F3 Limited
Thanks!
Hey Everyone,
Thanks for the advice. I called my dealer. They said they would get a replacement for me. The Spyder is still under warranty. The dealer will probably want to stick it back on themselves. If that's the case, I'll let them do it. I bought the bike at Hollinger's Sport and Turf in Ephrata, PA; they've been great about everything.
All the best,
John
Just to add my 2 cents.
Yeah, I had one fall off also. As the adhesive foam seemed to be still well attached to the reflector, I just got out my trusty bottle of contact cement, cleaned both sides with alcohol applied cement to both sides, let them dry and glued it back on. Even if I had to buy the cement, less than $5.00 bucks. I know, I'm cheap.
sidecase reflectors
All the best,
John
I have a 2013 ST-Limited and one side reflector fell off (lost). I called the dealer and ordered a pair. Alcohol clean the area, dry it thoroughly and press the new reflector on. Simple and no mess.
jb
Its not hard to do it yourself, The kit comes with 2 to a package so make sure you hold on to the other one in case another one falls off.
If the dealer does it, you may not get the extra one unless you ask for it.
2017 F3 Limited
Follow Up
My dealer called earlier this week to tell me that my replacement reflector is in. I picked it up this morning; there were actually two in the package. I prepped the area, stuck the new reflector on, the end. Thanks to all for the advice.
All the best,
John
Mine fell off too. I might just take the other side off and use it as a pattern to cut out matching reflectors out of DOT truck reflector decals.
2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
I put some LED side marker light on mine.
corbin Lamont cut seat with back rest, graphic gator,Chrome grips, trailer hitch,buttler mug, two brothers exhaust, painted center fender strips. center brake light, Led lights, tricLed fender lights
Under Warranty!
I called my dealership and within a few days, they had a new set of reflectors for me. I had to put them on myself; no problem.
All the best,
John
2022 RT Limited
- Garmin XT (I would be lost without it)
Driving Lights (Very bright to improve my sight)
Floorboard Lights and Turn Signals (I like to be seen)
Passenger Armrests (So my wife doesn't fall off)
Trailer Hitch (So we can bring more stuff with us)
Chrome Wheels (Because the beautiful stock wheels just weren't good enough)
Front Fender Sequential Reflector Lights (I was wondering what to do with my paycheck)
