Results 1 to 2 of 2
    Oct 2013
    Houston, Texas
    Default 2013 ST stereo problems
    I have no sound coming out of my left speaker. I have check to see I am getting power to the speaker. It is getting power. I have checked the speaker to see if it is bad. It is good. I have also plugged in a different speaker and still no sound.
    Does radio have a balance setting? Or does anyone have any suggestions?
    Thanks
    Active Member JCWeatherman's Avatar
    Aug 2015
    Lancaster County, Pennsylvania, USA
    This is an interesting problem. If you tried another speaker, your old one is probably OK. How did you check that you were getting power to the speaker? I would think that there is no signal going to the speaker from the amp. Worst case scenario is that the amp is blown; best case is a loose wire or a blown fuse. You might need to seek the help of your dealer or someone with some electronics experience.
    All the best,
    John
