How to hook up heated clothing
We in MN love our cold weather. We also love our Gerbing heated gear. Had no problem hooking up to our 08 RS. There is even a switched power connection.
How do I hook up with my 15 RTS?
Thanks in advance,
Jim
Minneapolis
08 RS/SM5 (Hers) (sold)
15 RT-S (Mine)
For the rider use a Panel Mounting Kit. (EDITED TO ADD old Pat number ACPMKT - THE middle cable shown on their site isn't the BMW cable it's a coiled cord or it should be because that's what came with both of mine).
For the passenger install a power socket back near (below the right side) riders heated grip and use the Gerbing 12V DC Plug Cigarette Adaper. (EDITED TO CORRECT old Gerbiing pt # TCPLSW). It has a cord to attach to your Gerbing control for the heated jacket liner or whatever youre using.
They've re-done their site and it's no where near as imformative as in the past. Either they don't have a number of items anymore of it just doesn't show them. Like the Plug Cigarette adapter which I bought 2 of just last year.
Good luck.
Thanks in advance,
Jim
Minneapolis
Jim,
I would be happy to show you how I did our RT. PM me if interested and we can meet up.
Les
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Understand the Gerbing items. My problem is where to tie into Spyder's 12v system?
jt
15 RT-S (Mine)
You can go right off the battery
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I'll second this. Yes, I could install a relay to allow a "live when running" condition but I've run my Gerbings fused line straight to the battery on the last 4 bikes that I've owned. I've wired three others for friends. You will unplug when you dismount so there isn't much of a chance that you will take off your liner and controller and leave them on the roadster and plugged in. Easiest is usually the best solution.
If if you are adding other farkles then bite the bullet and get a fuse panel with internal or external fusing
"If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
I spliced into the 12v socket in the rear trunk. I took off the rear seat back and fished the wire in to the trunk. Was pretty easy
Jonny
2013 Spyder RT Limited
- TricLED 3rd and 4th Brake Light
- Spyderpops Bumpskid with TricLED LED kit
- GloRyder Wheel Lights
- Spyderpops Missing Belt Guard
- Corbin Arm Rests
- TricLED Turn Signals
Wired both straight to the battery on my 2014 RT Limited.
Sent from my Galaxy Note 4 using Tapatalk
Thanks to all!
Thanks for all the great info! Start running wires in the morning (after getting a fuse panel, of course)!
15 RT-S (Mine)
