Air Horn for 2009 RS
I just replaced the OEM horn for my F3S with a Strebel Nautilus, love it! Does anybody know if this horn fits in the same location as the OEM horn on my RS? Any issues with wiring or should I buy the Universal Plug and Play harness Used on the F3 also? Thanks for any wisdom or advice.
IT IS, WHAT IT IS...
They are all the same GS/RS/RSS thru 12...
2012 RS sm5
you need the wiring harness and relay for your 2008 GS because of the type of charging system used.
I have a 2015 RT Limited and did not use the included relay because of the type of charging system the 1330 motor uses.
I have a Rolo Bad Boy air horn and no electrical issues when holding the horn on for a few seconds.
Same here... direct replacement of the oem "tooter", and no problems (So Far! )
