So interesting development and I wondered if anyone else has experienced this. Since we have had the recall work done on our 2013 RT, I am noticing an increased exhaust popping on deceleration. I always downshift the transmission manually, and as I do this I have noticed an increase in the popping of the exhaust. Not too sure if the removal of the accustic panels would cause this, and not too sure that it is a problem......... In fact it sounds kinda cool. Wanted to hear from anyone else if they have experienced this.
I have noticed the same thing, although intermittently. The exhaust somehow sounds louder to me as well. Fuel mapping maybe?
Popping indicates a lean condition. Since fuel is metered by a computer, it is most likely air in combustion chamber caused by air leak. Can be a leak in a vacuum line connected to the FI or perhaps the exhaust was removed and new exhaust gaskets were not installed.
If they leaned out the mix; it sure could cause this... It's normally not a problem. And you're right; it DOES make the bikes sound a whole lot meaner!
Try rolling the throttle closed, before shifting... No fuel; no popping!
Whatever the cause it is not from the recall. No one has ever reported that issue before. Plenty of popping exhaust threads some after market mappers others doughnuts . I can't hear anything like it but then I wear a full helmet.
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Uh-Oh, the long awaited honeymoon looks like it's over a bit early![emoji57]
Sent from my SCH-I545 using Tapatalk
I am not too sure how you can say that, but then negative is your game! Since the recall we have we have put almost 8000 miles on the bike with better gas mileage and, even though we didn't have a lot of heat issues, it seems to run cooler. We have over 25000 trouble free miles on this machine and that has not changed! So while you look at the glass half empty, I see it over flowing with goodness. We have such a great dealer, I will check with them as we are about do for an oil change!
We also have had no problems since the recall. The panels are cool now, you can put gas into it easily when the engine is hot and seems like the gas mileage is slightly better.
A much better machine all around now with no complaints.
The only thing we hear is from everyone with all other years wanting the side vents on theirs.
