Switch Size for heated grips
Does anyone know what size switch comes with the heated grips option. I'd like to put my LEDs on a similar switch adjacent to where the heated grip switch is located near the key. I need to know what size switch goes in the existing hole
The plug for the hole measured 18.6mm I would say a 19mm switch.
Make sure you get a latching switch. There are momentary ones out there too.
For an example the following is a link to a pair of switches.
http://www.amazon.com/gp/aw/d/B00EAC...iIL&ref=plSrch
