Results 1 to 12 of 12
Thread: Nanny?
    Sep 2015
    williamstown nj
    Default Nanny?
    Hi all I'm new to this what is a Nanny???? I keep hearing it but not sure what it is??? also what is Limp mode???
    Jun 2010
    Las Vegas
    The "nanny" is basically the computers that kick in when you do something stupid, the vehicle stability control, traction control, etc. Limp Mode will limit your RPM so that you do not damage the machine if it has a problem. It allows you to continue on so you can get to a safe place or a dealer when a problem arises instead of shutting it down.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2015
    williamstown nj
    Default Nanny?
    Quote Originally Posted by steriltech View Post
    Why thank you sir for clearing that up!
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    VSS. [Edit: Vehicle Stability System]
    Chris
    Nanny is always watching us...
    Sep 2012
    Junction City, KS, USA
    Part of the fun of ryding a Spyder is finding out where Nanny draws the lines. When you cross them, you'll know!
    PrairieSpyder (Patti)
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    You don't necessarily have to do something "stupid" to get the nanny's attention. Sometime's the light on the dashboard will flash for a couple of seconds when you take a sharp turn or twisty at (what she considers) high speed. It's her way of saying, "I'm watching you"
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Nanny saved my bacon a couple times when I went into hydroplane mode. Took a couple incidents, but now I respect driving through standing water a lot more.
    Default There you have it..
    It's called the nanny because some would like to go a bit wilder in their ryding style but the sensors reporting to the computers will stop you by appling the brakes or retarding the ignition. One will slow you down the other keep you from speeding up. She is set at a good level though she has been given a wider berth on the F3's. The limp mode will allow you to continue on if there is a problem. If serious she will shut down to prevent catastrophic problems. But don't worry, in normal ryding you will never meet the nanny and idealy you will never get the limp mode...
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    You're welcome maam.
    2010 RT- 622
    Idaho
    Years ago there was a farmer in central Idaho from whose house he could see all of his fields. His wife was notorious for keeping an eye on the workers in the field, even using binoculars most of the time. All the guys knew she did this so when they needed to stop for a bit of bodily relief they always made sure they were facing the house!
    2014 Copper RTS
    A lot of us feel that way about Nanny; let's try and give her something to look at!
