EMERGENCY:
Im stranded
Oil lite on
Noise
Experienced Mech advice pls
5044947309
let's ride safe & be careful out there,
Mike in Nawlins'
2014 Black SE6 Limited "Charlotte"
New Orleans Ride Captain
Patriot Guard Riders
Where are you located right now?
Are you near Ponchatoula, Denham Springs or West Monroe? The Spyders to the Rescue site has people in those places.
Go to SpyderLovers Home page. On the right look for "Spyders to the Rescue" and select by State and City. It will list people with their phone numbers. I think all the ones in La will be able to haul a Spyder.
Good luck.
Let's see..!!
have you checked the oil level..?? Add oil if needed this may do it but the oil light refers to the oil pressure. If it is not the level you will have to go into it deeper. Nothing you can do roadside. Depending on the noise mentioned you may not want to run her anymore till its checked....
2012 RS sm5
was unable to work the forum past the first post on my iPhone
First thing I did was check the oil level and it was fine. I then arranged the tow.
I'm home safe just now...Progressive Insurance Road Service provided a tow from Waveland/Bay St Louis/Gulfport home to Metairie/New Orleans for a reasonable price...covered for 15mi and it was 65mi run.
Bike in driveway, I'm deflated & a wreck (already bipolar disabled and financially challenged). I bought the bike 3 weeks ago and put 400mi on it...only had 1400mi when purchased used from a small family dealership who deals in used bikes and parts. Bike was sold on commission...I met the first/original owner.
So, I received a call from a board member checking on me and suggesting checking for any codes. That will be my next move as soon as I catch my breath.
Anyone know of any documented problems with 2010 RT's with oil starvation, grenade engines, etc ???
VIN is 2BXJBLC1XAV001160]
like I say, I'm really frazzled...geez, first payment on loan isn't till Oct 15th
think you're having a bad day !!! cough cough
Mike in Nawlins'
Oil light
Let us know if any codes but it does not sound good , good luck. People here know some stuff .John T
I'm glad you're home safe and mostly sound. When you get a chance print off the Spyders to the Rescue list and keep it on your byke. I'm glad you were able to get a tow.
thanx guys...
I can't find the Rescue list...hit 'home' and didn't see anything
can you post a url direct to it for me...thanx
Mike in Nawlins'
Pragmatic Member
I'm glad you're home safe. Sorry you've had so many problems with your Spyder. Hopefully things will get better.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
Originally Posted by PatriotRider
thanx guys...
Try this:
http://gnipsel.com/spyder/
ok, pressed buttons : mode-set-turn signal cancel at same time with key on: result is blank lcd screen
I had to turn the key on a few times during the day to engage the parking brake on & off when the bike was on the flat bed truck for the tow.
does that mean any codes relating to the oil light on longer show on the screen...is there a way to otherwise check codes without starting the engine? if there's an oil starved knock and possible oil pump failure, I don't want to start it for sure.
TIA
Mike in Nawlins'
Oil light may not throw codes. There are only three oil related codes. P0520-oil pressure sensor circuit malfunction. P0523-Oil pressure sensor sticking. P0524-Engine oil pressure too low.
USAF '69-'89 E7
Thailand/Vietnam 1972
TIA
The sequence only checks active codes, so once you turn off the key you lose visibility of any codes that popped up with your issue (unless they reoccur as soon as you turn the key on). You have to be hooked up to BUDS to see historical codes.
Clifford Fargason
2013 Spyder RTL
2007 Royal Star Venture
I suppose I would have thought that the oil light coming on from the sensor would shut it down or at least put it into limp mode to protect the engine from harm.
Mike in Nawlins'
Looked up your VIN and there were no recalls for it.
http://can-am.brp.com/spyder/owners/...JBLC1XAV001160
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
It's just like the oil pressure sensor in your car. It illuminates the warning light but won't necessarily shut the engine down. Unfortunately I don't think it will be covered by BRP warranty given the year of the bike. Did the dealer give you any kind of warranty? Keep us posted on what you find out.
USAF '69-'89 E7
