Does anyone know why this racket is happening
https://youtu.be/8O6Rfxta-EE. This happened today after a 70 mile ride and started when going up a slight incline on a road.
Originally Posted by SpyDerSts
I will take a shot at it, check to make sure that all your spark plugs are in tight.
also does it do it with the engine just idling and revving it up. if so check the oil pan to see if it is dented in
NO BIKE AT THIS TIME
From video & not hearing bike sounds like exahust leak , plugs or pipe. Any extra heat or smell (burnt) clutch would have more grind than pop. Fyi. Redneck opnion
It it only does it upon accelerating until it gets above 3500 rpm and it also is bogged down like something is holding it back. The rear tire looks like it is shuddering also while accelerating.this is an SE5 transmission. It only has 1985 miles on it too
dealer
Sounds awful - I think I'd be straight to the dealer for a warranty fix. Here's hoping it's something simple.
Interesting..!!
does seem like it is in the clutch. There have been several problems with them. Being an SE if not run at high rpm's the wear is damaging. Clutch is fully engaged only at over 3,500 rpms. I would check it out before running it anymore. If any parts let loose the whole package can go. If under warranty your covered so do it soon. Looks like it only does it under a load are there any signs lights or codes..??
2012 RS sm5
This sound is a similar sound you would have if one of your cylinders is not firing. While it still may be a clutch issue; I would at least first check to see if spark is getting to both cylinders. If not, you want to change the plug first. If you still do not have spark, then change the plug wires.
Double-check for any codes also; even if you do not see any warnings on the screen.
If the lack of spark is not the problem, then I would guess the problem would require a tech looking at your Spyder.
I hope for your sake it is something simple.
Best of luck, and please be sure to post your results...
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
Rockin Member
Thats exactly what my 2011 RT sounded like when the Throttle body went bad.
Heres my video https://youtu.be/ZITpoQd4rwc
2011 Pearl White RT Limited
HMT Brake Light, Fender Tips Kit, Mudflap Lights, GloRyders, Seal Floorboards, Powerlet 12V, Garage Door Momentary Button, Bump Skid, Elka's Stage 1, Ultimate Sea, Air Wings
Member of the Woodstock Spyder Ryders (Illinois)
Originally Posted by Macca
I would have to agree with you on this one... I forgot about the TB problems. Good call.
SL #7026
VBA #652
HOG #3935417
My bike has always made that sound if I don't allow a 5min warm-up prior to engaging the clutch. The dealer informed me that's normal.
I do experience that occasionally but mostly during initial startup.
Keep 3 Down..!!!
Rockin Member
If your hearing the same knocking sound as in either of the videos posted, that's not normal.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Does yours idle high like in the video from MACCA? His 2011 has a high idle, 1700 is too high for the v twin. My ST idles at 13/1400 rpms. But it certainly sounds like the same issue.
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
Mine idles at 1350to 1400. And yes it definitely sound like (MACCA's) bike. Don't have any engine lights come on though...it seems to only do it when throttling up in gear to move. At an idle it doesn't appear to be present
no,not anything with warmup,it just started after a 70 mile ride so it was completely warmed up and started when going up an incline.
That bike is shut down, and in Limp Mode... my 2010 did the same dance as Macca's, when the throttle body issues surfaced. The next that it does that; pull up the error codes.
Good Luck!
Good Luck!
We will will keep y'all posted as to what the Repair Shop says. We r trailering it to Springfield Ohio...Making sure we r there before their doors open!
low oil
saw a spyder doing the same thing after topping off the oil stopped happening
was barely low and was doing this
Rockin Member
I am surprised they didn't pull up any codes
...in the pink (Girls On Spyders)
I had to have my whole clutch system replaced on my 2013 ST....sounded very much like yours......some of the clutch plates were bent....from manufacture
#IamARyder #RideASpyder #CanAmSpyder
Tags for this Thread
