THE K & N FILTER SWAP
For those who may not know how to do this .....Thank you from them......Also BAJARON sells them for less then you can get them on-line.............If you go this route you will never have to but another one and neither will the next owner ...or next....or next...etc ................Mike
What is the cost of each? Yeah, I know K&N lasts forever, etc, etc. At 81 I'm not gonna be here forever, so its only the initial cost that concerns me.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Pragmatic Member
That's good stuff, thanks for the info. I'll be changing mine soon to the permanent one from BajaRon. I suspected this would be a fairly simply project, and you just confirmed it.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
2014 Copper RTS
SpyderLovers Sponsor
Originally Posted by WasWinger
How can that be? Is it washable? There's no way you can run a filter forever without cleaning it some way or another, either by replacing or washing or blowing out.
A K&N air filter will eventually need to be cleaned and re-oiled. But they actually filter better as they accumulate dirt - to a point. In most environments that the Spyder encounters. It is going to be many years before a service is needed.
Keeping it stock would be fine too..When I removed mine stock it was still clean..I have no noticeable performance increase with the K&N . The one advantage it is washable..
Not so easy for me -
Ricford - Any idea why I might be having trouble getting the "ring" that holds the filter in to seat? I got everything apart ok, got the old filter out, the new K&N in thru the ring but it won't twist back on again. Thoughts?
Pragmatic Member
I put in my K&N air filter a month or so ago, at the same time that I did my 12,000 mile oil change. You are right, it's easy-peasy. And as Mike stated, you'll never have to change it again.
Thanks for the comprehensive instruction for those who's hands tremble at the thought of changing their air filter.
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
