Results 1 to 12 of 12
Thread: Air filter
    Very Active Member Martin Slovakia's Avatar
    Mar 2015
    Bratislava, Slovakia
    Default Air filter
    Hi Guys,
    have any of you installed this K&N Air Filter.?
    http://www.ebay.com/itm/381347047729#vi-ilComp
    Is it really compatible with F3?
    thank you for any tip.. martin
    Default yes
    BAJARON, is a vendor here and doesn't sell " ANYTHING " for Spyders that doesn't fit ..........The 1330 engine uses the same filter for all applications.......Mike
    As BLUEKNIGHT911 says... It's Plug & Play!
    Mar 2015
    Default thank you
    Thanx guys,,
    Martin
    Active Member TommyBwell's Avatar
    Jun 2014
    Atlanta, GA
    I just looked at Bajarons vendor page and it says he has K&N's for all models except the 1330 Ace motor. I guess he just hasn't updated it.
    Jun 2014
    Atlanta, GA
    Default Disregard Previous Post
    Quote Originally Posted by TommyBwell View Post
    At the top of the page it says he doesn't have them but at the bottom where he lists them individually he shows it.
    Active Member 2 Cruysyn's Avatar
    Nov 2011
    Broken Arrow, OK
    Yep, he has 'em. That's where I got mine (and the sway bar, and the preload adjusters, and the...)
    Baja Ron - Dimple - Ultimate - Lamonster Garage - K&N - Smoothspyder - Amsoil - Hiflo - FOBO - Spyderpops
    Sena - Dynaplug - Shoei - Tourmaster - Garmin
    Thanks guys for proof-reading my ad page. I missed that opening statement when I updated the K&N Air Filter section. Indeed, I do have the K&N Air Filter for the Spyder. $46.95 delivered to US locations. A bit more for shipping to Canada and Worldwide.
    May 2009
    Connecticut
    Only Changed at 18-19,000 miles so I will stay with stock!
    Sea Doo GTI-SE 90 Jet Ski!!
    Mar 2015
    Default I want my f3 breath more
    The reason I want to go with K&N and the OIL filter is because I would like to see if it breaths a bit better.
    I have noticed downgrade in top speed - from almost 200km/h when the bike has around 3k km to little over 180km/h only at 18k km, and I think it is due to air filter.. Yep I gain some weight but I doubt it is the real problem )))
    Together with D-cat i hope it will perform and sound better.
    Nov 2010
    Hanover Park, IL
    Does anyone know if they make an "open air" intake like the Kwel Metal ones they had for the original twin engine? I have one on my current RS and love the way it made it sound. I am looking ot buy a 2016 F-3 and am starting to do my research on aftermarket products.
    Default Not sure..!!
    Quote Originally Posted by BLUEZL600EFI View Post
    Home page, JT's Machine shop has the same filter set up you mentioned but you can check with him if he has or has in production one for the triple 1330 yet. The one for the twin works great...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
