has anyone found a source for 5009 turn signal bulbs?
I have done an internet search, this site search and have not found an answer for where to get replacement 5009 bulbs. just in case, they are used in my 2014 STS rear directional signal housing. What have you guys done when you needed a replacement.
Tks Allen
Well..!!
most autoparts stores carry all our bulbs. But if you want cheapcycleparts.com has all oem parts at great prices...
2012 RS sm5
I replaced mine with LEDs. I don't think that they are 5009s the headlights are 9005s.
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
5009 bulb
the bulb I removed from my rear directional lamp is a Osram 5009. It is amber in color with the pins at 150 degrees. I have gone to five auto part stores as well as Batteries Plus, in Austin, and no one has the bulb. If some one has actually bought this bulb please let me know where they got it from. If you substitute a LED did you use a load resistor.
bulb
the local Spyder dealer did not have the bulb, but I was able to get it from the Ducati dealer. Their no. is 39040211A
Anyone else find another source?
Tks Allen
Hard to find, I know was looking for two weeks
I finally purchased from interlight.biz
Just replaced my headlight bulb with hb3 9005 Sylvania from Carquest in Bandera TX. This is exact match to the one that was in the light.
wiredgeorge Mico TX
2010 Can-Am Spyder RT SM5
2018 F3 LIMITED
I agree, if your already in there you might as well upgrade to the LED's much better lighting.
led replacemen
the LED replacement is about $19plus $4 for load resistor that gives off a lot of heat and needs to be inline some where other than in the housins because there is not enough room for it. Thanks for all the help
He is not asking about headlights...
Do an internet search for RY10W
Also look at Kawasaki Part Number : 92069 92069-0024 BULB,12V 10W for $2.87
bulb
this lamp is also used on Aprilia motorcycles.
I now have enough to stop the search.
Has anyone seen amber directional signal covers to replace the smoked ones?
Does anyone know where to get paint that can be used to color clear lamps, or the plastic cover?
Led bulb
What's the # for the led bulb switch out ??
