Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: 1800cc F3
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default 1800cc F3
    OK DUDES n DUDETTES......
    while @ my dealers, wait'n for my oil change, the manager told me that there is a
    KIT out there that will convert my/our very able 1330 ACE engine up to 1800cc's without the need for doing anything to the bottom end... has anyone out there heard of this KIT...?
    i asked, and he said all that he knew was the KIT was out there....
    HELP....! ! !
    Dan P
    SPYD3R F3-S
    Default Interesting..!!
    but you may have to widen your search. Like Aprilla has the rotax 998 cc twin in a 149hp model they may have some triples beefed up as well. Search the rotax engines..they have some interesting ones we never hear of...
    ​2012 RS sm5
    Active Member Xyzzy's Avatar
    Apr 2015
    Arkansas
    There's only so much material in the cylinders to allow an overbore so it would have to be a (big) stroker kit. You'd need at least an inch longer crank or shorter piston. Good luck with that!
    Mar 2012
    NJ
    And you have to figure out the tuning. Not something BRP is really into. They do a great stock machine but haven't really offered much in the add on performance area. Except for one time in the past with the RXX.
    They leave the real performance arena to the aftermarket, and the aftermarket has no idea what a 1330 motor is.
    Good luck!
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    If it's a kit, it probably includes bore liners, pistons, rods, and a stroker crank. Again, cubic money. Reminds me of when I was building engines, first question would be, how fast do you want to go, second would be, how much money do you have?
    john
    Very Active Member spacetiger's Avatar
    Sep 2013
    N. Va
    He must have read about the GW conversion and got confused. I would be shocked to know there is a bolt on kit to raise the 1330 to 1800cc's - which no bottom end change.
    13 ST Limited F/R suspension, Corbin, GIVI top case
    16 Vespa Primavera 150: Stock
    16 Piaggio BV350: Suspension, braking mods in work
    14 HD XL1200T: F/R suspension and brake mods; Corbin saddle and bags
    09 Aprilia SC250: F/R suspension and minor brake mods
    97 Honda PC800: F/R wheels, F/R suspension, and F/R brake Mods; Corbin saddle
    90 CB-1: In work, long term project
    89 Honda NT650: F/R suspension; Corbin saddle
    1800cc would be something that a lot of current owners may be interested in.
    If its non-BRP modification, that is going to slim down the takers. Good by warranty and it is probably going to mess with other things as well.
    I will have to adopt a wait and see on this one. But--I'm a waitin.
    Default What are we saying..??
    Quote Originally Posted by retread View Post
    john
    We can only go as fast as our wallets will let us...i
    ​2012 RS sm5
    May 2013
    Indiana
    Not that I know my AFAHITG, I think a 1800cc motor would not be doable with the OEM engine components. Would it even fit in the space allotted???? Potential heat issues???? 1500 ccs, maybe
    2021 Marsala Red Metallic RT Limited
    Jul 2010
    Las Vegas, NV
    Default Big bore kits
    156cc more per cylinder is not that much. The tuning piece is trickier. A 998 kit is available; one was offered for sale already installed by a SL here. 140 hp. Might be fun!
    Joe Meyer
    Jun 2014
    ny
    i'm curious what the mileage will go down to
    SoFlo
    For the F3, maybe this is a factory big bore kit with all the oem tuning items like a new computer, new exhaust, and engine parts.
    Similar to how the Toyota sells supercharges for the trucks via the TRD options stuff.
    Found this on the internet to validate the possibility.
    A very capable turbocharged, direct-injected 1.5-liter 3-cylinder engine that produces a staggering 400 horsepower
    SoFlo
    May 2013
    Apex, N.C.
    I don't think it would be possible to increase it to 1800cc without getting a stroker crank or something. In fact, I do not know of any internal combustion engine that can increase it's size by over 30% with just a big bore kit. If there was such an increase, then bye bye transmission.
    Yup! I'm sure that he "heard about" a kit...
    Probably from his ex-neighbor's Brother-in-law's eldest Son's ex-wife's Divorce attorney's maid's sister...
    Going from a 1330, to even a "nominal" 1800cc displacement would require that a whole lot more than just bigger pistons be stuffed into the engine...
    In order to reach that displacement just with pistons; you'd need to be up in the 97mm size.
    (Stock is 84mmm...)
    There's just not enough room in the cylinder walls for that much slug!
    Now; you either change the crankshaft, or at least change the mounting point of the connecting rods...
    This is getting to be a mighty large project!
    Some basic Math for this exercise...
    A... Area of a circle: Pi (let's use just 3,14) times the radius of the circle (R), squared.
    The radius of the circle is one-half of the bore.
    D... Displacement of a cylinder: A times the stroke of the piston (S)
    Those calculations will give you the displacement of the circle. Multiply by the number of cylinders, divide this mess by 1,000, and you've got the entire package.
    The stock Bore is 84
    he stroke is 80...
    I'll let you guys grab your calculators, and play with the Math!
    Active Member lwrydr's Avatar
    Sep 2013
    Olympia, Wa
    Default Engine size?
    In my humble opinion if the engine is big enough to scare the heck out of me then I'm a happy camper. My 998 cc does just fine......
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Default I FOUND THE KIT
    I found the kit. The kit contains 2 stickers, you put one on each side of your engine.
    ...Just for "funsies"...
    A 2mm overbore (which might be about as large as you dare to, and keep reliability in the engine...)
    Would get to up to about 1393 cc
    Remember: the stock bore and stroke, are 84 and 80mm.
    86 divided by two, equals 43...
    43 squared, equals 1849
    1849 time our value for Pi (3.14), equals 5805.86
    5805.86 times 80, equals 464.468.8
    464468.8 times 3, equals 1393406.4
    Divide that by 1000 to clean up the Math...
    1393.4064
    May 2008
    Bargersville, IN
    he stroke is 80...
    Bob, here's an easier one; .7854 X bore squared X stroke X number of cylinders. This was published in Hot Rod in the late '50s, works.
    john
    May 2015
    Default Math
    2+2-1=3 , NOW TAKE THAT !!!!!!!!!!!!
    john
    Thanks!
    They're using some different manipulations around the entire bore (diameter), than I use with the radius....
    We get to the same place!
    I was never much of a Math Whiz, and I'm certainly NO mechanic; but I DO enjoy practical applications for playing with numbers.
    My most recent exercise involved building a 686cc engine, and putting it into my 660 Grizzly. (Yamaha came out with their own 686 with fuel injection, but it only had a 4-valve head...)
    The 660s had the magical 5-valve on top of it, so after looking at all of the oversized parts that I could get; I went with a +2mm JB piston with a 10:1 squeeze, and a Raptor Bumpstick... (Cam)
    This combination ran on 87 octane without a hint of pre-ignition, and it pulled like a freight train...
    An earlier game involved turning a 439cc two-stroke snowmobile engine, into a 513cc monster.
    That one required that the mounts for the connecting rods be moved out 1.5mm (for a 3mm stroke increase), and I had to overbore from 67.75mm, to 72mm. I knew that the cylinders had enough meat for this project, because they used it as the basis for other 72mm-pistoned machines.
    We added over 40 horsepower to THAT one!
    And it still runs today!
    Apr 2011
    GREENVILLE, SC
    Default BOB BOB BOB
    (Stock is 84mmm...)
    the KIT would come with larger jugs.... no boring out of existing jugs....
    let's get back to the original question; HAS ANYONE HEARD ABOUT THIS KIT...?
    dp
    SoFlo
    Quote Originally Posted by SPYD3R View Post
    dp
    I have not heard about it. Did some searching in the Sea Doo world and did not see it either.
    PK
