F3 fog light
After 8500 miles the factory fog light has stop working.
Does any one know the replacement lamp?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
They are standard H3 halogen lamps. You can pick them up at any auto parts or even wal mart.
Thanks for the information. I went ahead and opened it up and found out that you are correct. Details on the BRP website omits the bulb detail. It is an Osram 64151 55 watt bulb. I used the Sylvania model. ImageUploadedByTapatalk1440981271.158641.jpgImageUploadedByTapatalk1440981281.359421.jpgImageUploadedByTapatalk1440981290.498803.jpgImageUploadedByTapatalk1440981298.585083.jpgImageUploadedByTapatalk1440981308.323868.jpg
You do not need to disassemble as far as I did. There is a latch with a hinge to remove the bulb. No screws will need to be removed. The positive wire connection can be pulled out without removing the heat shrink and replaced with ease.
Would you happen to know the outside diameter of the housing on the fog lamp??? Thx
The opening is approximately 70mm. The housing enlarges as you get closer to the mount.
Thx
PAY
FOR WHAT WE PAY FOR THESE BUGGIES, BULBS SHOULD BE FREE FOR LIFE......
i've already replaced the license plate bulb and one rear bulb,,,,, wha'sup'wit'dat.....?
dp
