Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Active Member bobgeorge's Avatar
    Jun 2015
    Georgetown, KY
    Default RT - Air Pressure?
    Hello,
    I'm a new spyder rider...only around 700 miles. On Sunday I put my air pressure at 20lbs in the front and 28lbs in the back. I think that is what is recommended in the manual for stock wheels.
    Now my ride seems a little more bouncier than before?
    Has anyone else noticed this? What air levels do you keep your RT?
    Thanks
    2015 Can-Am RT Limited Pearl White
    Farkle: Laser alignment, Bararon sway bar, Bump skid with LED, Tri Axis adjustable handlebar, BRP heated comfort seat, Utopia backrest, Kott grills, Tailgunner Black Widow exhaust, BRP adjustable side wind deflectors, and Upper wind deflectors.
    Jul 2014
    Mint Hill, NC
    I've been riding my Spyder for slightly less than 11 months and 10,200 miles keeping the tires at the 20/28 recommendation in the operator's guide. I keep the ACS rear suspension on firmest setting too because I like to "feel" the road and do not find the ride fatiguing. I weigh only 13 stone so I'm by no means stressing the suspension system.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by bobgeorge View Post
    Hello,
    Thanks
    I keep mine at 20 and 28 just as the manual says. Your tires will last a lot longer if you keep them exactly at the recommended pressure.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Jun 2015
    Georgetown, KY
    I weigh around the same weight. I might try changing the ACS settings on mine and see how the ride feels. Thank you!
    Mar 2015
    San Tan Valley, AZ
    13 stones = 182 pounds
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    I run 21 psi up front...
    and 25 psi out back...
    The 15" front tires need s bit more tire pressure than the old 14" ones... there's less sidewall available for flexing!
    Default Ranges....
    usually they indicate a range like from 15 to 20 lbs. Both manual and on the swingarm of the roadster. What suits you best will depend on where you ryde, solo or double up and road conditions. On my RS double up I find 17 lbs in front works best and 28 in the rear. The range given is for average weight and best tire wear. If its to bouncy check you shock settings as well as adjusting your tire pressure. Have seen folks running as low as 15 on up to 22. Make sure fronts are at the same pressure both sides...
    ​2012 RS sm5
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Quote Originally Posted by Pampurrs View Post
    Pam
    Wow
    if 13 stones = 182 pounds
    I'm just a big granite bolder
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by garb55 View Post
    Wow
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    But I always thought that it was like oxygen...
    But it sure does sound as if Donnie Iris has got one heckuva great Bar song!!
    Active Member Blade's Avatar
    May 2015
    Chesapeake, VA
    Post Tire Pressure
    [Pampurrs;I keep mine at 20 and 28 just as the manual says. Your tires will last a lot longer if you keep them exactly at the recommended pressure.
    I have the same bike and it seems that I have to constantly add air to my tires. I check them before each ride. Is this normal? All of my two wheel motorcycles didn't require as much checking as the Spyder ?
    Blade
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by Blade View Post
    Blade
    All motorcycle tires seep. I've never had a motorcycle (included my Spyder) that didn't. That's why a tire gauge and compressor are essential items in the garage of every motorcycle owner. They need to be checked and aired up every couple of days, and for sure before a long ride.
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Nov 2013
    Oro Valley Arizona
    20# front and 30# rear. I'm a few stones too much.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by jaherbst View Post
    Jack
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    Jack
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    May 2013
    Indiana
    Hello,I'm a new spyder rider..only around 700 miles.What air levels do you keep your RT?Thanks
    First, and. LUV your color.
    Like you, this is my first . I just crossed 1300 miles (400 white knuckle miles was the ride home, so that doen't count.) I just looked under my seat and the info there says:
    Fronts: 20 +/- 2 psi
    Rear: 28 +/- 2 psi.
    1. We ride 2-up 95%
    2. I have 1 of DOC Humphries spring stiffeners on each front shock, and a pair on the rear shock.
    Coming off 9 years of riding GL1800 trikes, I'm used to 41 psi in the front bias ply tire and 30 psi in the rear radial car tires. Right now I'm running 24 psi in my front Kendas, and 30 psi in the rear. I run my rear suspension in the middle. Going to be taking a 4 day trip where we'll put 800-1000 miles on the odometer.
    Hope this helps.
    Mike
    2021 Marsala Red Metallic RT Limited
    Quote Originally Posted by Magdave View Post
    Hi Dave!
    Thanks for some Robin!
    Here's another taste...
    Active Member TEHelms's Avatar
    Sep 2014
    Indian Trail, NC
    Default Leaking?
    Blade
    Try using the nitrogen available at many places...I usually go to Costco to top mine off. The molecules are larger than O2 and thus don't leak out nearly as quickly. Now, don't fall for all the hype surrounding nitrogen...but, here's the thing, most of these air fill up machines you pay to use, have a great deal of water in their systems and you don't really want that in your tires. The nitrogen is much dryer in addition to the larger molecules.
    I use Discount nitrogen: I get it at the filling station...
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    It's generally safe to experiment going up or down a bit from the recommended PSI, because inexpensive tire gauges are only "good enough" -- i.e., not precisely accurate. Good for the job they do.
    For example, the tire gauge I keep in my truck shows 33 psi in my truck's tires, but if I use the gauge I normally keep with my Spyder to measure those same tires, it reads 35 psi.
    Get a decent gauge (avoid the $1 special in the cup at the cash register) and keep that for your bike. Then go up and down a bit in small (1 or 2 psi) increments, using the recommended settings as your starting point. Then find out what feels best for your bike and use those readings from then on.
    Or, you could try to find a no-kidding calibrated gauge, but IMO that's not worth the extra price (and providing you can find one).
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Been using nitrogen for 7 years now.
    When I had my Harley, only required top-off 2 to 3 times a year during seasonal changes.
    Too soon to tell on the Spyder as I've only had it 6 months, but so far with the Nitrogen, I've topped off once (mid July seasonal change) and expect it will need to be done again in November or December.
    Also suggest if possible to fill with 100% (bottled) nitrogen. The "machines" run about 95-98%.
    Of course being a HOG member helps as all my nitrogen is free.
    Note: Nitrogen will cause your tires to be harder at the same psi.
    AJ
    Quote Originally Posted by TEHelms View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    May 2014
    United States. North Carolina
    Blade
    They leak less if you remove and plug the nails/screws you pick up in them
    Eric
    YNC(SS) (Retired) - U. S. Navy Submarines
    2014 RT-S Cognac
    3 seadoo's,CBR250R, Suzi GT750 waterbuffalo's x4, Rebel 250, MB5, '84 Alfa Spider, '97 Jeep TJ, '93 Saab C900CVT, '99 SLK230, '65 Mustang, '59 Fairlane, '48 Ford 8n
    Default It's not a Spyder...
    ...But it does show what can happen if a tire blows!
    Aug 2007
    Boerne, TX
    25/30. I like a firm ride. Try 25 and if too firm, reduce 2# and ride again until you find your sweet spot. I ride solo, so a passenger will make a difference....
    I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
    SAVE THE CHUPACABRA
    If you have not been to Luckenbach, your journey is not complete.
    May 2013
    Indiana
    Quote Originally Posted by Mr. Cognac View Post
    Must be something about being a, and/or ex, GL1800 trike rider. We're used to 41 PSI in the front tire. I'm currently running 24/30 with a passenger.
