Results 1 to 25 of 26
    Active Member LEEB's Avatar
    SE Pennsylvania
    Default NEW PROBLEM - HELP PLEASE!!
    Well, a couple of weeks ago I reported on Spyderlovers that I received a DESS error and the bike wouldn't start, until 2.5 hours later it decided to. This is the same Spyder that had the DESS module replace earlier this Spring. Well, we have been busy the last week or so getting ready for our son's wedding and haven't even looked at the Spyder. Today I thought I would start it and take a short ride. I turned the key and everything looked fine, no DESS error. It wasn't until I hit the starter switch that I had the problem. When I hit the switch the starter motor turned the engine over as expected, but then instead of starting the engine coughed once and then wouldn't even attempt to start. The battery had plenty of power to turn the engine over, since I had the Spyder on a Battery Tender, but the Spyder would not even try to start, just turn on the battery power. Any idea what this problem may be? Could it be connected to the eariler DESS error? What is the procedure to find the error code to give to the dealer? Any help would be greatly appreciated. PS - This is a 2014 RTS.
    2014 RT-S Pearl White - 'Miss Pearl'
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    There may not be an error code. However, the procedure is, key on, press turn signal switch in, mode and select switch at the same time. This will show an active code if one is initiated.
    I'm sure you checked the kill switch. I have inadvertently hit it myself when starting.
    Can you tell if there is any power draw when hitting the start switch?
    Check the pre start relay in the left fuse box.
    There have been issues with starter magnets coming loose.
    Keep me posted.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Member: Royal Order of Rat Bastards
    SE Pennsylvania
    Default Error Code U0155
    Well, I was able to check the stored error codes and found an active code of 'U0155'. I'm at a loss as to what that means. Once again, 'Help anyone'!!!!
    Did you try pulling up error codes?
    There's something very unusual happening with your bike...
    Check your battery connections too!
    SoFlo
    Sounds complicated...
    Jul 2011
    Mitchell, Ontario, Canada
    Here is a case of the error code is unrelated to your problem.
    Try a wide open throttle start. Before pressing the starter button. Twist the throttle to wide open and hold it there. This will turn the fuel injectors off. Press the starter button for 20 to 30 seconds. If it does not start. Wait a couple minutes to allow the starter to cool. Try again. If it still does not start try a normal start again.
    PS It has nothing to do with DESS problem you had earlier. If it was a DESS problem the engine would not crank at all.
    SE Pennsylvania
    Default Thanks PMK
    Thanks PMK! These instructions sound like something for the trained tech, not an old man with little to no mechanical expertise.
    SE Pennsylvania
    Default That worked!!!
    I tried your process above and it worked. The Spyder is in the garage right now idling just fine. I'm afraid to shut it off or ride it, but at least we got is started. Thanks for your help 'Bov'. It's times like this that make you realize just how valuable Spyderlovers is.!!!
    Jul 2011
    Quote Originally Posted by LEEB View Post
    Happy to help. Take a drive and it will be fine.
    Jun 2010
    Las Vegas
    I hope your garage door is open!
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default There you go...!!
    billybovine to the rescue...glad you got it sorted out and running agsin. now get out and have a ryde will relax you from all that wedding stress stuff..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    I also want to thank you, Billy, for your suggestion. I never heard of the "wide open throttle start" before, but it's a good trick to keep in my "problem solving arsenal".
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    SE Pennsylvania
    Default Door Open
    Yep Ann! The garage door is open. When I got it started and came in the house and told my wife, her first question was, "Do you have the garage door open? I don't want to come out there and find you lying on the floor." You ladies all think alike! I guess that's why we keep you around!! Well, one of the reasons!!!
    Glad to hear that Miss Pearl got her throat cleared, and is back to purring!
    SE Pennsylvania
    Default Took a ride!
    I took it for a short ride and she ran fine. I just didn't shut it off until I returned home. I left is set for about 30 minutes and went out and it started right up. It's still going to the dealer, due to the DESS error, and for their opinion on today's U0155. We're headed to Spyderquest in a couple of weeks and I want the Spyder to be fully ready for the trip. I also have to replace the original rear tire. Only 6,888 miles on it.
    Good luck with her visit to the dealer!
    6,888 miles on an OEM rear tire isn't bad at all!
    SE Pennsylvania
    Default Fur Ball
    We have two cats! Maybe she got a hairball!!!
    Oct 2013
    Pottstown, PA
    Lee,
    If you are interested in an automotive tire, Netzley Tire will be one of the vendors at Spyderquest. I had Derrick Netzley install a Yokohama s-Drive on mine last month. It fits the wheel better than the OEM, it's much less expensive, so far it performs better, it should last longer, and you'll pay less for the install. He'll install any tire you want at Spyderquest, if you contact him ahead of time and make an appointment. (He'll need a little time to get in the tire you want.) PM me if you want more info.
    Rob
    2013 RT Limited
    Rob is right; they can set you up with whatever tire will best do the job for you.
    SoFlo
    What do you suspect happened and why?
    If the engine was able to crank over, agree it was not DESS related.
    Do you suspect the fault code is leftover from the previous problem?
    Do you know if the machines will self clear faults after so many cycles with no fault?
    PK
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    the wide open throttle start procedure is usually used when you suspect an engine from being flooded, meaning too much gas in the intake.
    I guess that was the problem in this case. Now the question becomes, why was it flooded?
    2018 RT LTD , Black
    Jul 2011
    PK
    From my own experience and from others posting. If the Spyder has been sitting for a while or if they have been on a trailer ride. Every once in a blue moon they flood instead of start. Does not make sense since they are fuel injected, it should not happen.
    Whether there is a TCM code or not it should not have any effect on starting. Unless there was a low voltage problem and then there would be a cascade of codes streaming across the screen. This code in particular was a communication problem. I tend to ignore communication codes unless they are actually causing a problem. A lot of stuff happening on power up and one module is unhappy with another for not speaking up fast enough.
    Fault codes change from active to occured several different ways. It all depends on the specific fault type. As soon as the problem is fixed the fault goes away. Or after a period of time the problem does not come back the fault goes away. Or after a power down cycle, key off for 30 seconds and if the original problem is still not there on power up. I have also been told that some faults can only be clear by BUDS. I am skeptical of that and would like to know which ones those are.
    Vermont
    Nice to hear that you got your spyder started. Sent pm Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    SoFlo
    Good answers, thanks.
    So taking some stuff further. I watched Shawns video the other day on the oil change #2. He showed a bunch of BUDS / MPI-2 stuff. One thing he did do was rest the maintenance to zero. I assume or the oil change. If this is not reset will it show a cluster light, or can the average DIY person reset to 0 by some other means. I saw no mention in the Maintenance Manual but maybe overlooked it.
    I am now looking for an MPI-2 setup, and will buy the unlock code once I have the hardware.
    PK
    Jul 2011
    PK
    I watched that video too. What I really found interesting was that you can see all the driver control switch/button inputs. That brings up the question of why some dealers seem to take so long to diagnose faulty switch issues.
    The maintenance record I think is a record only and will not show a cluster light. If it did I would have shown a light a long time ago.
    This spring I downloaded a trial version of BUDS. At the time I did not have any time to look at it. I recently tried to use it again. It had timed out and no longer usable. This winter I will try it again.
