Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 106
  1. #51
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Doc, I don't oppose your vent installation. However the plastic on the top of the 1330 is not the airbox. The plastic atop the engine is the intake manifold. The concept of replacing it similar to the V twin may not have the same merits.
    The two airboxes sit left and right of center and have little effect on blocking airflow.
    The 1330 throttle body is forward facing. The still airbox is forward forward of that. The duct that couple the 1 airbox to the still airbox its over the steering unit. Airbox #1 is on the left side.
    The airboxes could be removed, not sure you would gain much. The intake manifold would be more difficult, but someone with enough skills, time and money could design a new one. Lot of work though.
    PK
    You didn't comprehend what I wrote. The 1330 suffers the same problem that the 998's have in that you can't get to the spark plugs easily. The 1330 is worse. As you so illustrated in the second picture showing the 2 airboxes that cover the top of the 1330 engine thus making it impossible to get to the spake plugs. Read the shop manual for changing the plugs. So removing the airboxes has merit if one wants to easily work on the top of the engine are with out removing a bunch of interference just to do the job.Why would one want to remove the air intake and throttle body. The design as it stands makes it easy to come up with a new air filter design like the one for the 998 engines.
  2. #52
    SoFlo
    Doc, you are correct, every 28,000 miles I need to remove one airbox to replace spark plugs.
    Sorry I did not comprehend everything you posted about removing heat or how involved replacing spark plugs might be.
    But now the real question about keeping the rider cooler. If you install the scoops, there is no means to run the BRP air deflectors. How does the rider aim airflow onto themselves with the scoop in the way and blocking the flow to the rider?
    All the best.
    PK
  3. #53
    This is my solution.
    http://www.spyderlovers.com/forums/s...48#post1026648
  4. #54
    Jan 2010
    USA Folkston,Ga
    All the best.
    PK
    I had the BRP air deflectors and was not impressed with there performance riding in the high 90 degree weather here for the last month and a half. I have the windshield that has the vent in it that in the summer I open except if it is raining. It provides air where it is needed (upper body). If you feel the air stream of the open air deflectors it is pulling hot air out of the engine compartment and directing it back to the rider.
  5. #55
    May 2009
    Connecticut
    HEY SARGE ...GET A LIFE ........Mike.......And if you really think this is of major concern , I suggest you contact the administrator and have Him eliminate ALL the colors except BLACK.............
    OR you could simply Post in Black letters like everyone else? What you say is Important and you Do Not need to Post in Red?
    Sea Doo GTI-SE 90 Jet Ski!!
  6. #56
    Nov 2014
    TriCities, WA
    Called the dealer today to get the scoops. Lucky I had the part # and the price. He started out at $150 each until I insisted that everyone was getting them for $67, finally he agreed and after I went over there and paid for them, ordered them. Not allowed to take a CC# over the phone, WTF.
    Thanks Doc for providing the correct info.
  7. #57
    Nov 2014
    TriCities, WA
    Thanks Doc, I installed the scoops today, your help with the blind holes is appreciated. Somewhere it said that when you installed the main scoop you should take the grill off and then install it again. I did that on the first one, but it isn't necessary, so didn't on the 2nd one. Someone else had an issue reinstalling the air wings and had to re-engineer them. I have the Baker ones and I could re-install the top ones, but their movement is limited but still useful.
  8. #58
    Sep 2015
    Texas
    Default Request for Can Am Spyder Air Scoop Template
    Quote Originally Posted by Doc - Riverside View Post
    You can order any color as long as it is BLACK. If you want matching colors you will have to get them painted yourself.
    They are the BRP Scoops. Part number 219800388. As mentioned in other threads they are $67.00 plus tax. The vents are a great accessory at an unbelievable price from BRP.
    Cooler glove box and seat area
    Price above. You don't need the template. Send me a PM with your E-mail address and I'll send you a PDF file on how I did the install.
    As explained above. Plus one of the very first mods I did was the CAT Bypass.
    If anyone wants the instructions on how I installed them without the template send me a PM with your E-Mail address.
    Just registered on this site and sent you a pm for the template. Please let me know if my pm made it through to you. Thanks!
  9. #59
    Nov 2012
    North Las Vegas, NV
    Default RT vent kit on 2014 RT
    Got the scoops put on my 2012 by the dealer for zero cost on Saturday. They seemed good on the way home. I will give them a better test on Tuesday.[someATTACH]115440[/ATTACH]ImageUploadedByTapatalk1441643582.810788.jpgImageUploadedByTapatalk1441643591.496684.jpgImageUploadedByTapatalk1441643600.729835.jpg
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  10. #60
    Active Member RTL1330's Avatar
    Dec 2014
    Campbell River, BC, Canada
    Wink Scoops going on
    I ordered scoops and dealer will install next week when in for my 20k service. Wow only 8 months and 20k on my 2014 RTL.
    Anyway thanks for info but dealer cut me some slack and tech has put on several on 2013 retro so I'll let him do it.
    FYI, Canadian dealer here was $74.00 for kit and max $150.00 to install.
    CMS in Courtenay installed them. Craig did good job!
    2020 RTL - Petrol Blue Metalic / Black, dark model.
    Colour match rear tail cover, Garmin GPS.
    Heated Ultra Comfort driver seat & backrest.
    LED headlamps, LED Front corner lamps and lower front LED lamp.
    Baja Ron sway bar.
    Ride Til You Rot!
  11. #61
    Oct 2015
    Moody, Texas
    Default air scoops
    Finally found your post again. could you please send me the info on your install of the scoops.
  12. #62
    Albion,Michigan
    Default Thanks for the response/PDF file on the air scoops and heat recall-
    I received the material that you sent. The picture of the heat recall looks the same on my spyder. No vents were installed so when I go back to thew dealer I am going to see if he would supply the scoops and I will install them. Thanks for all the material that you sent. Dave in MI.
  13. #63
    lake mary fl.
    Gee... Do you think that they'd ever offer them in the popular body colors?
    ...Maybe just leave the front end of them Black...
    ! I have them on my bike, and as soon as I have a chance I'm going to have them painted or cover with carbon fiber!
  14. #64
    Invalid Emails
    Mar 2011
    NE TN
    Thumbs up Thanks Y'all
    My thanks to y'all and specially Doc-Riverside! BRP will be Good-Will comping me the air vents on my 2011 RT.
  15. #65
    Newfoundland, Canada
    Default Where do I get them?
    I have the exact same 2014 and I would like to get those on mine. Where did you get them?
    Richard
  16. #66
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Richard Budden View Post
    Richard
    Just call around to dealers near you with the part number posted above. I got mine from a local dealer that had them in stock.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
  17. #67
    Dec 2015
    Galax VA
    This looks like a worth while mod, anytime you can reduce temps in the engine compartment is a good thing. Just my 2 cents.
  18. #68
    Nov 2014
    TriCities, WA
    It is smart and don't let the dealer try to charge more than the $67 List price.
  19. #69
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Looking good Doc.
    JT
  20. #70
    Sep 2009
    La Valle, WI
    Doc can you send me instructions for 15 RT-S or post them.
    2018 F3 Limited , Oxford Blue
  21. #71
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Vents
    I recieved instructions from Dave and put these on my 2014 RTS and they preform great. My glove box is no longer hot, have cool air moving over it, and the Spyder is much lighter, as you remove two panels under the Tupperware. I cut my plastic with a dremel type tool. Good luck to all who try.
    2011 RT-S SE5 Viper Red
    2014 RT-S SE6 Cognac
    Bajaron sway bar w/ aluminum heims
    Custom Design HM Brake light
    Custom Design Red front fender lights with turn signals
    Lidlox
    Corbin arm rests
    2014 RTS SE6 , Cognac
  22. #72
    But I have a question: what sort of riding conditions do you normally encounter?
    City traffic (Stop & Go)
    Suburban
    Rural
    Interstate riding
    I ride rural two-lanes about 90% of the time, with virtually no traffic around me.
    My bike never heats up, and I just wonder if it's the "sitting in traffic"; that makes folks feel the heat.
    Thanks!
  23. #73
    Apr 2013
    Little Elm Texas
    The scoops look great and anything to remove the heat around the glove box area is a must. Now i'll do the same.
    Thanks Doc for posting!
  24. #74
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Suburban
    Rural
    Interstate riding
    Thanks!
    Hey Bob, It is much more noticeable when getting stuck in traffic, but at this time of year down here in Florida, the temps have been around 100 or more, so it doesn't make much differernce where whether you are in town, or out on the road, if you are in the sun, it's HOT. The vent kit really makes a difference in the rider seating area, and glove box.
    David
  25. #75
    Active Member noboot's Avatar
    Sydney Auustralia
    Through our (Australian) summer I had no heat problems with the 1330 motor heating up any body panels.
    So to give a little extra cooling I did the following as I don't find the need for additional scoops.
