Page 41 of 44 FirstFirst ... 313738394041424344 LastLast
Results 1,001 to 1,025 of 1100
  1. #1001
    Sep 2017
    Durham,Maine
    That was the antenna.
    2012 RTL , Pearl
  2. #1002
    Active Member GearHd's Avatar
    Mar 2015
    Connecticut
    This is what I'm talking about. I don't believe that is the antenna.
    Wife has a 2014 ST-L
    2014 ST Limited , Silver Platinum Satin
  3. #1003
    Dec 2013
    Quote Originally Posted by GearHd View Post
    That round ring thing with the cable looped thru it that's then zip-tied to the module is an after market Ferrite Choke that's been added/installed after the Spyder's left the factory by someone, probably after they'd experienced a few DESS issues, in an effort to try to stop any spurious signals over-riding & swamping the DESS signal between the antenna & the DESS Module; or maybe it was done in an effort to lessen the chances of the antenna itself being swamped by a stronger signal &/or to iron out any possible spikes in the signal..... : Doing this Ferrite Choke thing was one of the earlier BRP suggestions/attempts at fixing the DESS problem, altho it' since been revealed that doing this didn't seem to work too well &/or at all for many tho!!
    It seems the only 'solutions' to the DESS stopping you starting your Spyder randomly that might be available atm are for you to replace the various Modules as & when they fail or as DESS problems become too much of a bother, but be aware that if you do that, you're only ever gonna be replacing the original dud items with exactly the same items that are still very likely going to experience this failure again/eventually; or you can see if you can find someone to Disable the DESS & then never worry about it again!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  4. #1004
    Idaho
    This is what I get in my service manual. Sorry for the sideways picture.
    That was for 2013 and earlier. The DESS was changed in 2014.
    2014 Copper RTS
  5. #1005
    Mar 2015
    Connecticut
    Thanks for the info. Funny thing is, we bought this Spyder brand new. It had been back to the dealer a few times for some warranty work but none of it was ever for a DESS issue. We just recently had the DESS issue, that's why I changed the module to the latest part number.
  6. #1006
    Mar 2015
    Connecticut
    Makes sense, thanks.
  7. #1007
    SoFlo
    Some DESS modules came equipped with Ferrite Chokes to lessen induced interference from electrical concerns into the system.
    Realize that when DESS issues first appeared, the errors were initially scoffed at by dealers and the Mother Ship to the (we have never seen that before). Then as issues became more widespread, owners were told that Key Fobs from other vehicles (cars, trucks) nearby to the Spyder during start was causing the faults. Then overhead powerlines, cell phones, and no doubt Alien UFOs, Heart Pacemakers, you Apple Watch, Cousin Eddies metal plate and more.
    After several variations of different “dash numbers” of the modules, the latest became the “916” which remains today with the 2022 models. However, the actions prescribed by the warranty department ranged from simple module changes, to antenna changes, and even complete replacement of the key switch, antenna, module, keys and reprogramming.
    Ultimately though, and not able to be accomplished by dealers, for best reliability, having the DESS disabled is the best fix. However it does eliminate the anti theft feature of a correctly working DESS.
    The consumer public will never know exactly how widespread DESS failures are. Only a small percentage of Spyder owners are on Spyderlovers. Similar to the failing front sprockets and NHTSA recall, dealers indicate the number of failed sprockets is very few. While the true number may never be known.
  8. #1008
    Sep 2014
    USA
    My 2014 original module had the ferrite on it. The new modules do not have them on the module.
  9. #1009
    Vermont
    GearHd,
    Way back when I had the DESS Module and the Switch (1st and 2nd time) replaced, the original keys worked, and they still do work.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  10. #1010
    Very Active Member cyclelover63's Avatar
    Mar 2011
    Big Sandy, TN
    Is this happening to anybody that also has the little "barcode store reward cards" attached to their keys. I have an Air Ambulance card on my key and was wondering if this causes it intermittently. I worked for an auto dealership and Chrysler stated that it could cause interference with their keys.
  11. #1011
    Mar 2015
    Connecticut
    Quote Originally Posted by cyclelover63 View Post
    I know we never have anything on or near our keys.
  12. #1012
    Vermont
    On my spyder keys I do not have any cards or other keys on the key chain.
    I use 1 key to start the bike, and the other key is in my pocket on a key chain. Anything that I have that has a magnetic strip ( on credit cards, or my cell phone I carry put in the trunk). I have a 2014 RTS-SE6, I know I posted the above info at the beginning of this thread. I also posted what the BRP person asked the dealership ( when the dealership opened up a case with BRP).
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  13. #1013
    Vermont
    Bumped
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  14. #1014
    Aug 2019
    North Carolina
    Got the dreaded DESS warning this past weekend on my 2014. At least I got stranded in my garage!
    Spent today changing and relocating the module. Found enough wire in the harness to put it up by the coolant reservoir. Will be much easier to change in the future if needed.
    Last edited by Peter Aawen; 03-09-2023 at 04:11 AM. Reason: Fixed attach display; caps; & ' 's ;-)
  15. #1015
    Quote Originally Posted by petew View Post
    I don't know if you got your idea from my post on this from 4 years ago, but I had no more problems after moving it ..... Mike
    Last edited by Peter Aawen; 03-09-2023 at 04:14 AM. Reason: Fixed quote display ;-)
  16. #1016
    Vermont
    petew, What was the DESS module part number?
    Thanks for posting the pictures.
    What is your current spyder mileage?
    At least you didn't get stranded on the road somewhere.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  17. #1017
    Aug 2019
    North Carolina
    Deanna
    Module part # is 710004916 which I believe is the most current
    Mileage is right around 2500 , I purchased the bike 3 years ago with only 500 miles on it .
  18. #1018
    Vermont
    petew,
    The first time that I had the DESS error was on July 14th, 2015, and the DESS module replaced on July 17th, 2015 at that time the mileage was 6.994. They replaced the DESS module ( part number at the time was 710004190) that was under the Manufacturer warranty.
    Then the 2nd time I had the DESS module and Switch replaced on Aug. 31,2015 at that time the current mileage was:8,740.
    Yes,that is the current DESS Module part number.
    OK.
    I hope that you don't get the DESS error again!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  19. #1019
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Can someone please PM or email me the procedure for replacing the Dess module? My 2019 RTL Dess failed after having battery issues. I will be ordering 710004916 asap and want to try doing this myself. Post replacement, does it need to learn the keys? Is there a procedure for that?
    If by email , PM me for my email address
    thanks very much
  20. #1020
    Idaho
    Quote Originally Posted by WRCLVR View Post
    thanks very much
    You haven't finished up with your thread about key error and starting issues. Did you do the load test on the new battery? Have you tried jump starting the Spyder from your car battery? You very well could be making a premature conclusion about the DESS module being bad. You need to make absolutely sure your battery is in top condition first. I don't believe there has been any other confirmed report on the forum about battery issues causing a DESS to be damaged.
    2014 Copper RTS
  21. #1021
    thanks very much
    Read what IMS posted ...... I have pics in one of my Albums ..... the module is located behind the trunk wall just above the Battery ..... so frunk has to be removed ..... the main issue with doing this is re-attaching the rubber AIR snorkel to the Air Box.... I wouldn't even bother with it, not having it actually helps the throttle bodies breath ..... Mike
  22. #1022
    Vermont
    thanks very much
    Did you get a DESS error on your screen?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  23. #1023
    Vermont
    Bump
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  24. #1024
    Apr 2023
    Chenango County, NY
    Does anyone have a wire diagram of the DESS module? I have a theory I want to test out on my 2014 and it would save a ton of time if I knew what wires went to what. Thanks!
  25. #1025
    Idaho
    Quote Originally Posted by PartsBob79 View Post
    Are you referring to the external wiring connections, or the internal wiring of the module. There are only 5 wire connections to the DESS. Two are for the antenna at the ignition, one is power in, and two connect to the ECM. Internally it is a special limited purpose computer processor so there won't be any way in H*** anyone is going to be able to give diagrams of the internals.
    BTW, I see you are new here.
    If you have intentions of doing your own service work on your Spyder you would be well served to get a service manual for about $25 to $30 from www.canammanuals.com. It has a wiring diagram in it.
    Also, for something like this you would do better to start a new thread. This one is years old and many members won't bother to look at it so you'll miss out on getting answers.
    Last edited by IdahoMtnSpyder; 04-29-2023 at 12:10 AM. Reason: add welcome & manual comment
    2014 Copper RTS
