Page 42 of 44 FirstFirst ... 3238394041424344 LastLast
Results 1,026 to 1,050 of 1100
  1. #1026
    Apr 2023
    Seattle Washington
    I just had the Check Key message today with my 2020 Spyder F3S with 1800 miles... After towing it home that caused me $250. If disappeared right after the spyder was dropped off my driveway...
  2. #1027
    Apr 2023
    Seattle Washington
    Quote Originally Posted by larryd View Post
    I DIS-AGREE with this post...I had 3 DESS modules replaced and 1 complete ignition switch with antenna...AND still had DESS issues...Only after having a forum member turn it off did my issues disappear...
    SO MY RECOMMENDATION IS; HAVE THE PIA TURNED OFF AND LIVE HAPPILY EVER AFTER...larryd
    What do you mean PIA???
    Yes, those with earlier model years were fortunate not to need disabling the DESS as the DESS worked without fault. Can Am changed a system that worked fine in previous years to a few years of problems.
    If you read the majority of this topic, 99.9% is focused on 2014 and later Spyders, and the person that started this topic does have a Spyder within that range of years.
    My 2020 Spyder F3S with 1380 miles showed the fault "Check Key" today. After 2 hours of trying everything I called the towing company that charged me $250 just to bring my spyder 4 blocks away from my house. Right after my spyder was dropped at my driveway, the Check Key fault disappeared...
    Last edited by Peter Aawen; 05-09-2023 at 05:10 AM. Reason: Merged immediately consecutive posts...
  3. #1028
    Durham,Maine
    Quote Originally Posted by alexf415 View Post
    I think what he was trying to say is if you are ok with the possibility of being stranded out on the road because of this safety item keep it hooked up! If just taking your key out of the bike doesn't deter, someone from stealing your bike, then having this unit on this bike stopping you from using your key out in the woods somewhere is a PITA, and the crook will still take your ride if he wants it!
    2012 RTL , Pearl
  4. #1029
    PIA = Pain In 'A part of your anatomy where you normally sit'!
    But we all try to comply with Forum Rule 4 that says something like: Don't Bypass site filters for swearing, yada yada yada.
  5. #1030
    Vermont
    Quote Originally Posted by PartsBob79 View Post
    Does anyone have a wire diagram of the DESS module? I have a theory I want to test out on my 2014 and it would save a ton of time if I knew what wires went to what. Thanks!
    PartsBob79,
    I don't have a wire diagram of the DESS module, but I think someone should chime in on this.
    Good Luck!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  6. #1031
    Vermont
    If you get the DESS error on your 2020 F3 S, the DESS module/Antenna/switch should be covered under OEM warranty and the B.E.S.T warranty. I had the DESS module changed twice (all 3 were covered under OEM warranty) and had the Antenna replaced twice.
    If you get the DESS module replaced, would you please post the part number?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  7. #1032
    Apr 2023
    Seattle Washington
    Deanna
    I don't think I will go that route anymore. The dealership gave me an appointment date of June 12. I can't wait that far while my Spyder is parked at my driveway with sunny weather. Meanwhile according to my email, my buds2 with Megatech for 1 year is arriving this weekend.
    2020 BLACK SPYDER F3S
    BMW EXHAUST TIP
    PUIG WINDSHIELD
    TUFSKINZ TANK PROTECTOR CARBON FIBER
    DISABLED DESS
    LED LIGHTS
    RAM MOUNT
    INSTA 360 X3
    SENA 10C PRO BLUETOOTH
    ALPINESTARS JACKET
    SCORPION EXO ST 1400 CARBON HELMET
  8. #1033
    Mar 2015
    Fritch, Tx
    I have been getting the Check Key notice for a couple of weeks now.
    edited due to circumstances beyond my control. will splain more later.
    Those who say " I can't" will always be right.
  9. #1034
    Vermont
    I am just trying to help. OK. Good luck with your buds2 and with the Megatech.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  10. #1035
    Vermont
    Quote Originally Posted by cruisinTX View Post
    I have been getting the Check Key notice for a couple of weeks now. Have an appointment for 9AM on the 25th at the local dealership to get it disabled. While on the phone, they didn't seem to have a problem with doing it the way I want. We'll see what happens next Thursday.
    cruisin TX,
    I thought that the dealerships can't disable the DESS. Keep us posted!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  11. #1036
    cruisin TX,
    Deanna
    Most won't ( BRP rules ) or Can't ..... but if they are willing and have the Megatech license .... well maybe they will ....... if they do .... don't Advertise the fact .... JMHOP .... Mike
  12. #1037
    Apr 2023
    Seattle Washington
    Ok Today I disabled the DESS on my 2020 F3S. Oh my goodness. That easy... I am now willing to ride again this beautiful Spyder. I have the megatech license for a year.. I'm from Seattle area in Washington state. wink. wink.
    BMW EXHAUST TIP
    PUIG WINDSHIELD
    DISABLED DESS
    LED LIGHTS
    RAM MOUNT
    INSTA 360 X3
    ALPINESTARS JACKET
  13. #1038
    Feb 2022
    New Zealand
    So will PITRA pass muster here. Thats - Pain in the rear anatomy?
    2017 F3 Ltd
  14. #1039
    Mar 2015
    Fritch, Tx
    My appointment came and went without any happiness this morning. The service manager gave it a shot with two different systems at his disposal and said neither one would allow him to click on the disable icon in the DESS section of the system. He said the icon was there but had the familiar red circle & bar over it. At least he tried and sent me on my way no charge. Not sure what to do next except hope I don't get stranded somewhere. On a positive note; I was using a "new" key that had been hanging in our key closet since purchase instead of the original that is now 9 years old. He said continue on with that one and maybe keep the other new one in my pocket as a back-up but leave the old one at home. He also opened a case with BRP on the issue to see if they might authorize an override in the computer or have some other insights as have been discussed here on SL.com.
  15. #1040
    Sep 2014
    USA
    https://www.spyderlovers.com/forums/...7&d=1656537098
    Click on the link and it will open up the bulletin
    I am sure nobody wants to go back a million pages to find it
  16. #1041
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    Hello you should start a rental program charge a fee you would soon get your money back i will be your first customer.
  17. #1042
    Vermont
    cruisinTX,
    I am glad that the dealership opened up case with BRP.
    Good Luck!
    Keep us posted on what happens.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  18. #1043
    Mar 2015
    Fritch, Tx
    cruisinTX,
    Good Luck!
    Deanna
    I've started reading this entire thread from the beginning to acquire as much knowledge as I can about this problem. The one big question I currently have is, when was it discovered that disabling the DESS would solve the problem? From what I've read up to page 10 so far is that the DESS sends signals to the ECM so the ECM can decide whether or not to allow start up. If the DESS is disabled then the ECM gets no signal, how does that allow it to approve starting the engine or not?
  19. #1044
    The DESS effectively triggers a DON'T START signal in the ECM if/when it doesn't read the correct code from the key, so by turning the DESS OFF, it can never trigger that DON'T START message, and therefore the engine will start EVERY TIME! Simples really!
  20. #1045
    Mar 2015
    Fritch, Tx
    That makes more sense now. I just need to find someone closer to home to do the delete for me. Doesn't seem to be anyone near Amarillo who can do it.
  21. #1046
    Vermont
    crusinTX,
    Would other people chime in on this?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  22. #1047
    Sep 2015
    Chilliwack, BC. Canada
    crusinTX,
    Deanna
    Deanna, did you not read Peters explanation just a couple of replies prior?
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  23. #1048
    Vermont
    Quote Originally Posted by bigbadbrucie View Post
    Yes, I did.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  24. #1049
    I'm not sure I agree with Peter's description. Look at the following extract from the 2014 service manual.
    All the DESS does is transfer the key code to the ECM which compares the code with the list of stored codes. If it matches one the ECM allows the start to occur. If it doesn't match then the ECM prevents starting. I believe when the DESS is disabled it actually is not a disabling of the DESS process. What disabling does, I believe, is change the computer code in the ECM so that it does not do the comparison but always allows the start sequence to take place. "Disable the DESS" is not an accurate description of what actually is done. It's more like "Disable the ECM from doing the allowed keys check." Disable the DESS is just a simpler way to say what is done.
  25. #1050
    Mar 2015
    Fritch, Tx
    hmmm, you must be thinking the same thing I am. Find the power wire to the DESS and simply diconnect it.
