Page 13 of 44 FirstFirst ... 39101112131415161723 ... LastLast
Results 301 to 325 of 1100
  1. #301
    Vermont
    Quote Originally Posted by PaladinLV View Post
    8 days from Quebec to Las Vegas seems acceptable.
    Beside the only thing that comes and goes quickly to Las Vegas is MONEY!
    Thanks for the info on the key, but that kind of bothers me.
    If the same key is used with a new ignition switch , then that says to me ALL Spyder RTs a Keyed alike and only the DESS module chip is different????
    Confused.
    And if they only reprogram the key and the teeth are the same why do you need a new trailer lock?
    More confused.
    Obviously I'm missing something or can't see the forest for the trees
    Thank Deanna
    AJ
    AJ, To me 8 days from Quebec to Las Vegas works for you, if I had to wait 8 days( Quebec to Derby Line, Vermont, my dealership is there) I would not be happy.
    My dealership had to reprogram the key to the new switch ( that was done in Aug. 2015) so it would work with new switch that they installed. Also, my dealership changed the look of my 2 keys to match the new switch.
    Does that help?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  2. #302
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    New DEES and Ignition Switch Installed.
    Part numbers were as you previously posted.
    One Correction.
    When they install a NEW ignition switch, the switch comes with two NEW keys and a new Trailer Lock.
    These keys are "programed" to the new DESS and the OLD Keys, Ignition Switch & DESS are sent back to BRP.
    If a new DESS module is installed WITHOUT an ignition switch, then the OLD keys need to be preprogramed.
    So now we wait and see if we ever get another error
    The final bill was $720.00 with Labor. One would think BRP would want to solve the problem but maybe a eating the repair is cheaper then redesign
    AJ
    Does that help?
    Deanna
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  3. #303
    Vermont
    One Correction.
    AJ
    AJ, That is good to know that you got the New D.E.S.S. and Ignition Switch installed, with the part #'s that I previously posted on this thread.
    When I got my ( 2nd D.E.S.S module, and Ignition switch installed) I did not get a new set of keys, but I did get a new trailer lock. Also, I still have my Original keys, they ( dealership changed the shape of my keys to match the new the Ignition switch).
    I hope that you do not get the D.E.S.S. error.
    The D.E.S.S. module/and Ignition Switch is UNDER WARRANTY. I hope you did not pay the $ 720.( final bill). I see that you have a 2014 spyder.
    If you do get the D.E.S.S. error or need to have the D.E.S.S. module/or ignition switch replaced again. Please post on this thread, BRP needs to get a grip on this. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  4. #304
    Feb 2015
    Las Vegas
    Of course I did not pay, that was what it cost BRP
    BTW - considering where the DESS module is located, I am no longer buying BRPs statement that it is "saturating" the key.
    If anything, the cause is a signal that is too weak. But with 40 years working with RF what do I know
    AJ
    2014 RT-S
    2014 RT/S , Black
  5. #305
    Vermont
    AJ
    AJ, that is good that you did not pay ( $720) the final bill.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  6. #306
    Active Member duke50's Avatar
    May 2014
    IL
    Left stranded DESS error - again. Lucky for me my trailer and motorhome was at a campground 5 miles from where I was stranded. Hitched a ride back to camper then took to my dealer another 20 mile. This is the 4th time same issue. Last time they just cut new key. Still under warranty
  7. #307
    Feb 2015
    Las Vegas
    You need to have them open a case with BRP.
    Change that.
    You need to DEMAND they open a case with BRP.
    BRP won't argue they will replace BOTH the DESS module AND your IGNITION.
    It takes BRP up to 10 days to respond to dealer and then the ship time.
    Job takes dealer 2.1 hours (at least that's what they charge BRP).
    The part numbers for a 2014 are DESS = 710004190 / Ignition = 710004413
    AJ
    Quote Originally Posted by duke50 View Post
    Left stranded DESS error. Lucky for me my trailer and motorhome was at a campground 5 miles from where I was stranded. Hitched a ride back to camper then took to my dealer another 20 mile. This is the 4th time same issue. Last time they just cut new key. Still under warranty
    2014 RT-S
    2014 RT/S , Black
  8. #308
    May 2014
    IL
    Thanks I'm going to do just that. 2014 r-t-s 6800 mi
  9. #309
    Vermont
    Thanks I'm going to do just that. 2014 R-t-S
    Do not back down at your dealership. Their is a lot of excellent info. on this thread/with pictures to go to your dealership with.
    Be sure your dealership has the parts ( D.E.S.S. module, and the Ignition switch parts at your dealership) before you leave your spyder. Get a copy of your work order, and A CASE # for future references.
    Good Luck! Keep us posted please!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  10. #310
    May 2014
    IL
    I did take a pic of the orange screen as soon as It happened. I will let you folks know what dealer has to say.
  11. #311
    Vermont
    Looking forward to hearing what the dealer has to say.
    Don't forget that this thread has some excellent info to take to your dealership with. Good Luck! Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  12. #312
    Invalid Emails
    Nov 2013
    Nashville
    Had the dess error pop up once over the weekend after my dealer had reprogrammed the keys. Headed to spyderfest wednesday. I have an appointment to have the sway bar installed and will ask pitbull to look at the dess error. I had my dealer open a case number with brp when they reprogrammed the keys.
  13. #313
    Vermont
    Quote Originally Posted by Tnpapa View Post
    Thanks for letting us know. Keep us updated on what Pitbull says about the dess error. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  14. #314
    Feb 2015
    Las Vegas
    Reprogramming your keys IS NOT a fix for this problem.
    There is only ONE FIX and that's to replace both the DESS module and the Ignition, anything else is a TEMPORARY workaround at best.
    BRP knows this - seems like your dealer does not.
    If they open a case, BRP will send your dealer the appropriate parts to fix.
    AJ
    2014 RT-S
    2014 RT/S , Black
  15. #315
    Vermont
    Get your dealership to replace the DESS module, and the ignition switch, both are covered under warranty.
    I had the DESS Module replaced twice( on July, 2015, Aug. 2015) the ignition switch replaced once, and my dealership reprogrammed keys, gave me a new trailer lock. My dealership did open up a case with BRP, and they fixed it. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  16. #316
    Registered Users tcbracing's Avatar
    Feb 2016
    Wentzville, MO
    Quote Originally Posted by Trbayth View Post
    2014 ST's as well.
    and 2014 RSS's...
  17. #317
    Active Member ndspyderlover's Avatar
    Dec 2012
    fargo, north dakota
    Quote Originally Posted by tcbracing View Post
    and 2014 RSS's...
    I got the dess code again on mine this morning. I thought I had the issue taken care of but I guess not. this is very maddening. I have had the switch replaced already. I am considering a harley trike
  18. #318
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by ndspyderlover View Post
    I bet those are trouble free, right! Might want to search Tri-Glide Problems first. Here is a question from a tech.
    Hey tri-gliders!
    I was just wondering what you guys are seeing with problems on these models.
    I service 3 of these and all have some sort of issues.
    So far i have seen:
    Steering Damperleaking
    3 oil coolermounts getting loose
    all 3 had the transmission trap door bolts loosen up and the exhaust mountbolts fall out.
    Left side mufflershang down a slight bit more than the right side
    Shift arm on transmission loosening up
    all 3 needed rear rotors/pads at 4k-8k miles.
    starter was loose
    exhaust bracketat rear of trans case bolts falling out
    parking brakes not working
    reverse assembly loosening up
    IMHO everything that has wheels and a motor will have problems of some kind, and the more computerized they get, the more issues they will have.
    2020 RT Limited , Petrol Blue
  19. #319
    Feb 2016
    Wentzville, MO
    If you get the D.E.S.S again, take a picture, ( show the picture to your dealership) the D.E.S.S. Module is UNDER WARRANTY, and have your dealership open up a case with BRP, and be sure that your dealership has the D.E.S.S module, ( so you are not spyderless) and also, have your dealership replace the Ignition Switch which is UNDER WARRANTY also, have your dealership reprogram keys, and get a new trailer lock from your dealership.
    The part # for the 2014 RSS is: 710004190.
    I got the following info. ("Solution: Replace the D.E.S.S. module. Program the keys using B.U.D.S. NOTE: If after the replacement of the D.E.S.S. Module the problem reoccurs, update the previously opened BOSS Web Case and report this situation) from my dealership.
    Also, try "Turn on/off immediately and DO NOT LET YOUR SYSTEM SHUT DOWN for 4 to 5 cycles. Also, I got this from an email from a BRP TECH " We have had cases where a cell phone or magnetic card, placed near the ignition switch cause this. This includes any device that may emit some type of frequency".
    Where do you carry your spare key?
    Keep us posted!
    Please post on this thread, so new/and current spyder owners now.
    I will check this thread, when I get a chance, ( I am still in the work force). I hope the above info helps.
    Deanna
    I will definitely take a picture this time. We bought the Spyder brand new in March. It had been sitting on the lot for a while. Warranty coverage started in March.
    The problem actually just started when I carried both keys to Spyderfest (figured it was better to have both on me, in different locations, then to have one of them 250 miles away). I think I may have caused the issue by confusing the DESS module with both keys. Going to put one back in the house and see if it comes back.
    Thanks for all the research and part numbers. It will help if I have to take it back to the dealer. This dealer only does a few Spyders and mostly does crotch rockets.
  20. #320
    Default Taking pictures
    This taking pictures thing is TOTAL B.S. ...IMHO..... Anything that occurs to/on/with your Spyder that has anything to do with the COMPUTER system is LOGGED IN "FOREVER" even if the Techs "clear" it ...... IT IS STILL THERE ...... any good Computer Hacker can find and retrieve ALL the so called "cleared codes"....... In Law Enforcement I've talked to Forensic Computer Retrieval Experts, and I don't think they lied to me when they said "if it's in there we can get it out"............. Remember "Apple" is still trying to find out How the FBI got a computer Hacker to break APPLE's code!!!!!!! ............. So if a dealer tells you "IT'S NOT IN THERE" - They are flat out LYING to you OR are in-competent ................ KNOWLEDGE IS POWER, My friend ...... Mike
  21. #321
    May 2013
    Apex, N.C.
    I got the D.E.S.S. code error on mine, and have been able to get around. But I had it checked at my last service and they ordered the replacement part. My question is, will this issue come up again with the new part, and is there a certain part number that I need to look out for? Now when my bike gets the error, I am able to wait about a minute or less, and reinsert the key in the opposite direction and I am good to go. I don't want to get it replaced and end up with an even worse problem.
    Thanks,
    Keith
    PS, I have had this error for over a year and it is actually not too much of a problem, YET. Will it get worse with time? Right now I also take both keys if I am going on a multi day trip.
  22. #322
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    .... The problem actually just started when I carried both keys to Spyderfest (figured it was better to have both on me, in different locations, then to have one of them 250 miles away). I think I may have caused the issue by confusing the DESS module with both keys. Going to put one back in the house and see if it comes back. .....
    What about carrying your extra key in a credit card signal blocking pouch? It will keep the signal of the extra key blocked so it should not confuse the computer. Just an idea. I think I will try it. Bed, Bath, and Beyond has them for 10 bucks. Worth a try.
    http://s7d2.scene7.com/is/image/BedB...=2000&qlt=50,1
    I haven't had the problem yet, but can't say that it isn't always in the back of my mind when I am out.
  23. #323
    Blacklightning --- once this occurs, it is the beginning --- it does not self-heal, it will eventually FAIL.... Good Luck
    JHeck --- If your issue has to do with the signal between the Key and the ignition switch the transponder should not be able to get the signal if the Key is in the rear trunk --- it's too far away......... If your issue is the MODULE like I told Blacklightning ---- it doesn't heal itself.................. and to ALL it appears the new 2016 MODULES are having the same issues ........ There really needs to be a way to de-activate this until the problem has a permanent FIX ...... Of course, if someone riding a Spyder gets KILLED because this module shut the Spyder off while they were driving it and it can be PROVEN ....... then the NHTSA (?) will again put BRP's feet to the FIRE and force them to fix it ...... like the 2013 HEAT issue............. WAKE UP BRP ............... sorry for the RANT - Steve .... Mike
  24. #324
    Vermont
    You are welcome for the research and the part numbers. Post on this thread what you find out @ your dealership.
    What is your spyder model?
    What year is your Spyder?
    Good Luck!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  25. #325
    Feb 2016
    Wentzville, MO
    2014 RSS
