Page 6 of 44 FirstFirst ... 234567891016 ... LastLast
Results 126 to 150 of 1100
  1. #126
    Vermont
    Quote Originally Posted by MarcusB View Post
    I am on my 2nd replacement module, the 2nd one is a 2015 part#, no problems since the 2nd install. BRP told my dealer they are not sure if the 2015 # is the fix, but they have had much less problems w/2015. MarcusB
    MarcusB, Did they replace the ignition switch, at the same time? If they did what is the part # for the ignition switch?
    How many miles do you have on spyder with the 2nd replacement module?
    Keep us posted!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  2. #127
    Vermont
    Quote Originally Posted by StanProff View Post
    I got the first DESS problem last week, 4,000 miles on a '14 RTS. It did restart after turning the switch on and off about 3 or 4 times. Dealer says that BRP will not address the problem unless the problem can be duplicated at the dealer. Meaning it would have to fail leaving me stranded and towed to the dealer. Then it could start at the dealer so what then? My dealer is a good dealer and friend, they are dissapointed in BRP's response to this issue. They said that if and when it happens again to take a pic of the screen and document it before trying to restart. If it won't start it will be towed to the dealer. If it does start they will push on BRP again. I have been a strong Spyder advocate and am on my 2nd Spyder. It is simply not a very good feeling to wonder, every time you ride, if you are going to get stranded. We all know BRP monitors the forum and responds when they have something to say about a problem. The lack of response tells me they don't know what to say or do about this issue. I have been totally happy with the '14 Spyder aside from this problem. Love it, but no one wants to gamble every time they turn the key to see if it will start, Then if it does start you wonder if you'll get back home. I work out of town and get home on weekends, I love to ride and this is my way of stress relief from the job. I hope something can be done soon. At least with Limp mode you can get somewhere.
    I guess I've vented enough. Thanks for bearing with me. On a good note, BRP is replacing the rear tire under warranty, it was down to the ware bars at about 3400 miles. Yea!
    Stan
    When I had my first D.E.S.S code, I took a picture ( look at my Thread that I started about the D.E.S.S Error)
    My dealer replaced my first D.E.S.S module, then this month I was out doing errands, and I got the D.E.S.S. Key Code again, so I called my dealer and I said to them that I got the D.E.S.S. key code again, they replaced the D.E.S.S. module and replaced the ignition switch/ and changed the key lock on rear trunk, also, made the keys to fit the new ignition switch. I agree with you on it is not a good feeling if I am going to get stranded some where.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  3. #128
    Vermont
    I went for a spyder ride today, ( yesterday Friday 8/28/15) my can-am dealer replaced D.E.S.S. module 2nd time, and the ignition switch) and I did not get D.E.S.S. key code WOHOO! Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  4. #129
    Very Active Member StanProff's Avatar
    Jun 2011
    Jonesborough Tennessee
    Was at the dealer getting the rear tire replaced under warranty and when I went to leave the DESS code came up. Great timing! I left the switch in the on position so the screen kept the code showing and walked into the dealer and had the service manager look at it. the part is on order. When I went back out and turned it off and back on it did start up. couldn't have happened at a better time.
    Happy Spyderlovers
  5. #130
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    That's great Deanna. My fingers are crossed that it never happens to you again
    Pam
  6. #131
    Jun 2014
    Green Bay, Wi.
    Deanna, No key replacement w/either DESS, mileage on 2nd one approx 10500. MarcusB
  7. #132
    Quote Originally Posted by Pampurrs View Post
    Pam
  8. #133
    Vermont
    Pam
    Pam, I rode this week-end( Thursday, Friday, Sat.) so far no D.E.S.S. error. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  9. #134
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
  10. #135
    Vermont
    My mileage on the 2nd D.E.S.S. module is : 9,025. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  11. #136
    Vermont
    Pam, Thanks Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  12. #137
    Mar 2015
    Brockport, NY
    2nd DESS Failed within 1 mile!
    Went back and forth a couple times with the service dealer. They said they could not get a DESS failure unless they had cell phone interference or touched both keys together. I insisted on DESS replacement as I was stuck at work for half a hour the week before with a DESS error. I was able to get it going and made it home. I just picked bike up Thursday 9/10 and trailered home. I went to start it today and there was the DESS error again. I called the service manager and he reassured me they did replace the unit. He will be contacting brp Monday am to open a case with them.
    2014 RT-S Pearl White
  13. #138
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    IMHO
    When one receives these infamous errors, one should ALWAYS take a photo prior to turning the key OFF.
    Then you can contact the dealership with proof.
    AJ
    Quote Originally Posted by Brentc View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  14. #139
    Mar 2015
    Brockport, NY
    Quote Originally Posted by PaladinLV View Post
    IMHO
    AJ
    I was fortunate enough to have been reading enough of these DESS posts to have the same thought. I have been able to get pictures of all of my DESS screens and even have my service techs cell phone number to send them directly to him.
  15. #140
    Sep 2015
    Kansas city mo
    Just curious if anyone with an F3 had experienced this problem? I didn't see any F3's in these posts.
  16. #141
    Vermont
    When you get the D.E.S.S. error take a picture, take that picture with you to your dealer. (look @ my D.E.S.S. Key Code, D.E.S.S. Key Code Again!!!!!!!!!!!!!, threads,)
    I posted pictures of the D.E.S.S. error that I got on my 2014RTS-SE6 Cognac.
    When I got the D.E.S.S. Key code I called my dealership and they opened up a case with BRP, and they ordered the parts, the dealership called me when they got the parts in, made an appointment and got it fixed. They have replaced the D.E.S.S. module 2nd time, and changed the ignition switch, changed the lock on the back trunk once.
    Keep us posted on what happens. Good luck! Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  17. #142
    Apr 2015
    Boise Idaho
    Quote Originally Posted by staneric View Post
    Haven't had the DESS code but have had a "Bad Key Error" twice. Has eventually started but it does make one wonder whats going on.
  18. #143
    Vermont
    Quote Originally Posted by Mike Ard View Post
    Haven't had the DESS code but have had a "Bad Key Error" twice. Has eventually started but it does make one wonder what's going on.
    Read post #1 on this thread, and read post # 1 on: D.E.S.S. KEY CODE on a 2014RTS-SE6 (I started that thread) you will see what the D.E.S.S. key code looks like.
    If you get the D.E.S.S. Key code again "Take a picture and show your can-am dealer, and let us know what happens next. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  19. #144
    Vermont
    Went to SQ in Lake George, New York and got home and did not get any codes If I get a D.E.S.S. key code I will post on this "Thread". Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  20. #145
    on a trouble-free ride!
  21. #146
    Sep 2015
    Bleecker N.Y.
    Got the same code for the first time (2014 RT) at Spyder Quest on one of the rides. Was able to remove the key and try again and it worked. Didn't know at the time what it meant, just glad it worked. Have about the same mileage as one of the pic's, wondering if that has anything to do with it. ???
  22. #147
    Vermont
    Quote Originally Posted by Chuck125 View Post
    Got the same code for the first time,(2014 RT) at Spyder Quest on one of the rides. Was able to remove the key and try again and it worked. Didnt know at the time what it meant, Just glad it worked. Have about the same mileage as one of the pic's, wondering if that has anything to do with it. ???
    No the mileage has nothing to do with it.
    If it happens again take a picture, take the picture to your can-am dealership, and let them know that it has been happening, on the 2014RTS-SE6, & 2015RTS-SE6 Models. Keep us informed on what happens.
    Glad that you were able to get your Spyder started again. Did you take your key out and walk away from your Spyder?
    When it happened were you on a gas stop, or at a destination?
    Let us know what happens. Good luck. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  23. #148
    Feb 2015
    Las Vegas
    I don't know if this has any relation - I wouldn't think so, but the Spyder are kinda weird
    I wonder how many of the people having this problem shut-down with the Spyder "in gear"?
    My reason for asking is I had the screen of death pop-up twice. Both times I was able to clear it.
    After the 2nd time I started shutting down in Neutral and since then it has never returned.
    That was 5 months ago.
    Just coincidence?
    AJ
    Last edited by Peter Aawen; 10-02-2023 at 05:07 PM. Reason: Fixed quote display ;-)
    2014 RT-S
    2014 RT/S , Black
  24. #149
    Vermont
    I don't know if this has any relation - I wouldn't thinks so, but the Spyder are kinda weird
    Just coincidence?
    AJ
    AJ, From day 1 with my 2014RTS-SE6 Cognac I have always shut my down in Neutral. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  25. #150
    Feb 2015
    Las Vegas
    Just color me LUCKY (so far)
    AJ
    2014 RT-S
    2014 RT/S , Black
