Page 16 of 44 FirstFirst ... 612131415161718192026 ... LastLast
Results 376 to 400 of 1100
  1. #376
    Mar 2013
    Quote Originally Posted by ndspyderlover View Post
    Who is your dealer? Mine was honda motorsports out of st cloud. They are no longer in business.
    Caswell's out of Mora.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  2. #377
    Mar 2013
    Les, with you tell your dealership to OPEN UP A CASE WITH BRP, and it is UNDER WARRANTY!
    Please post the D.E.S.S module part # so new/and current spyder owners know what the part # is.
    I have had the D.E.S.S. Module replaced twice( first DESS module on July 14, 2015, the second was replaced on Aug. 28th, the same time they reprogrammed the keys, and gave me a new trailer lock. I have not had the DESS error show up. If I do I will post on my thread.
    Good Luck!
    Deanna
    Hi Deanna,
    I will as soon as It's fixed. It maybe already as they were working on it yesterday, but I will not pick it up until Saturday since it's a two hour drive.
    Les
  3. #378
    Vermont
    Quote Originally Posted by PW2013STL View Post
    Hi Deanna,
    Les
    Les, I posted the part #'s that my dealership used to replaced the D.E.S.S. Module, and the Switch, on my post # 406.
    Good Luck!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  4. #379
    Vermont
    Quote Originally Posted by Reginald View Post
    I recommend making a complaint to NHTSA at https://www-odi.nhtsa.dot.gov/VehicleComplaint/
    This is a continuing problem that needs a general recall and fix. How many pages now. Being stranded is not safe for single riders. BRP has a fun product with the Spyder, it needs better reliability/TQM. I've said this before in another thread but here I go again. Consumer Reports states that 42 out of 100 units fail and is the worst in the MC industry. For riders not having problems that's great but for the roughly 42% that have failures (some have multiples) this is not acceptable. Ann (wife) has been stuck on the side of the road 3 times now.
    This thread is up to 18 pages now............................ about being stranded is not safe for any single riders.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  5. #380
    Member Smutt's Avatar
    Nov 2015
    Nl Canada
    Had the DESS error show on my 2015 RTL with 3052klms on it, turned the key off then on again and everything was ok. I contacted my Dealer and was told to bring the bike to the shop the next morning, they hooked up the BUDS and the code did show. They then opened a case with BRP, next day I got a call and was told the module would be replaced. A few days later another call asking me to bring the bike back to the shop, today they replaced the module with a #710004916. Hope it solves the problem.
    Jim
    2015 RT Limited
    Show Chrome Drivers Backrest
    Show Chrome Passenger Armrest
    Show Chrome trunk Rack
    Ron's Shock Adjusters
    Ron's Sway Bar
    BRP Trailer Hitch
    CB Communications System
    Spyderpop's Bump-Skid
    Spyderpop's Belt Guard
    JT's Rear Fender
  6. #381
    Vermont
    Quote Originally Posted by Smutt View Post
    Jim
    Jim, Good Luck with the module part # 710004916.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  7. #382
    Jun 2012
    Fairmont, Minnesota
    This morning I was reading a long term test on a new Nissan Maxima. Guess what they are having a problem with? They tried reprogramming the keys and it didn't work. It is causing problems with starting, unlocking the doors, etc. We apparently are not alone with this issue.
  8. #383
    Vermont
    Quote Originally Posted by rcturner View Post
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  9. #384
    This thread is up to 17 pages now...........................
    43 on TapaTalk!!![emoji1] [emoji1] [emoji1]
    Sent from my SM-T350 using Tapatalk
  10. #385
    Mar 2013
    I have had the D.E.S.S. Module replaced twice( first DESS module on July 14, 2015, the second was replaced on Aug. 28th, the same time they reprogrammed the keys, and gave me a new trailer lock.)
    The part # for the Switch is :710004413. The part # for the D.E.S.S. module is:710004190.
    Good Luck!
    Deanna
    Deanna,
    My switch did not need to be replaced only the DESS module. Part number 710004916. It was covered under warranty.
    Looks like I received a newer one than you did, so I hope it fixes it for good.
    Les
  11. #386
    Invalid Emails
    Nov 2013
    Nashville
    Well had three episodes of dess again this week. Going to have it at the dealers this morning when they open. They will have to replace the module this time as I will not settle for another key reprogram. Have the module number to give to the service writer.
  12. #387
    Active Member Major spyder's Avatar
    Jul 2011
    Great Falls, Mt
    Today, I was doing some errands, after I left the store went to start my spyder, I got the D.E.S.S KEY CODE "AGAIN" so I put a key into the ignition, got the above error, put the 2nd key into the ignition, got the same message, ( and a coarse I did not have my camera so no picture) the spyder did not start.
    Put both keys in their holders ( plastic) and walked away about 50 to 60 feet, and waited for about 1/2 hour ( in my mine I was thinking of calling Roadside Assistance, if the spyder did not start the 2nd time, I did not have to call Roadside Assistance,) because it started. Then I went on my way.
    Thank god!
    So tomorrow I will call my dealer and tell them I got the D.E.S.S KEY CODE again. I had the D.E.S.S. Module replaced last month ( 7/17/15) and both keys reprogramed. I will post here when I can on what the dealer says. My spyder is a 2014RTS-SE6. I know this happens a lot.
    I did start a " Thread last month on the above subject. I was wandering if anyone else has had this recurring problem?
    Deanna
    Im having a problem too with only one of my keys... 2014 RT
  13. #388
    Vermont
    Deanna,
    Les
    Les,
    Good luck with your new DESS module, and I hope the problem is fixed for you.
    Yes, you did receive a newer DESS module then me. So far I have not had the DESS error show up.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  14. #389
    Vermont
    This thread has 18 pages now (I started the 18th page). Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  15. #390
    Vermont
    Quote Originally Posted by Tnpapa View Post
    Which module number are you going to give the service writer at your dealership?
    Good Luck!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  16. #391
    Vermont
    Quote Originally Posted by Major spyder View Post
    Did you try "TURN ON/OFF IMMEDITALLY AND DO NOT LET THE SYSTEM SHUT DOWN FOR 4 TO 5 CYCLES"?
    Have your dealership reprogram both keys( my dealership reprogramed both of my keys, and they gave me a new trailer lock, and a new trunk lock. I have a 2014RTS-SE6) Also, since I have had the both keys reprogramed, and a new dess module, and switch installed, I have not had the dess error show up.
    Good Luck!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  17. #392
    Vermont
    Seems like a lot of superseded part numbers...
    PMK, I noticed that my D.E.S.S Module part # 710004190 is superseded( I have got the part # 710004190 that was installed on July 14, 2015 and Aug. 28th, 2015) and I have not had the Dess error show up. Also I think I was one of the first ones who had the DESS module replaced.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  18. #393
    Vermont
    Looking at that chart I found, your DESS module is three revisions out. So they are on the third version since you had your repaired. With 5 total part numbers that have been offered, yours is the second version, version 5, the 916, is quite a few revisions newer.
    So am I head of the game or what???????
    With the part # that I have?????
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  19. #394
    Vermont
    Honestly, like us with the original 2014 module from Jan 2014 when our bike was built, it is simply luck. I would not say you are ahead of the game at all, just currently lucky. Same for us.
    I hope that good luck stays with me for a long time. But If I do get the D.E.S.S. error, I will post on my thread.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  20. #395
    Invalid Emails
    Nov 2013
    Nashville
    Good Luck!
    Deanna
    gave him 916 we will see what they do
  21. #396
    Jan 2016
    PA
    Oh, for crying out loud.
  22. #397
    Vermont
    Good Luck! Keep us posted. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  23. #398
    Jan 2016
    PA
    She asked and got my honest opinion. With the history of superseded part numbers, and the constant number of failures, there was no crying, simply how I view the situation in regards to our 2014 and her twice failed Spyder.
    I wasn't aware that the replaced module had failed twice.
    If it has then I suppose your opinion is valid.
  24. #399
    Jan 2016
    PA
    Since, as you state, Deanna has had two failures on her replaced module then I agree.
    If you have not had any failures and are being haunted by the fear of a DESS code then if I were you I would sell the thing and buy something I had confidence in.
  25. #400
    Jan 2016
    PA
    Deanna
    Gosh I thought that PMK said you had two errors show up on the replaced module.
    Silly me, I must have been mistaken.
    I guess that will teach me not to gloss over threads.
    Sorry for the inconvenience I caused PMK and Deanna.
    PMK was obviously correct in warning that at any time, without warning an error code could be returned and Deanna should be fearful of that time.
    Apologies all around.
