Page 3 of 32 FirstFirst 123456713 ... LastLast
Results 51 to 75 of 793
  1. #51
    Vermont
    Quote Originally Posted by WEB-WVR View Post
    Just curious...where typically is the DESS module located ? On an ST-L ? Other mdls. ?
    Thanks !
    I was wandering that my self, Where is on the RTS-SE6 Models?
    I have a 2014RTS-SE6
    Deanna
    2014RTS-SE6 Cognac I am a Happy Spyder Owner!
    BRP Semi-Rigid Rear Side Cargo Travel Bags
    BRP Glove Box Organizer
    Ron-rnet Laser Alignment
    TRIC-LED Spyderpockets
    STV Black Carbon Fiber Windshield Blackout
    WRAPMYSPYDER.COM Sceptor Kit Reflective Decals-Orange
    painted Dashboard+ GPS plug-in
    BRP Half Cover
    WRAPMYSPYDER.COM Air Dam Web Decal Black Reflective
    General Altimax RT 43 Rear tire
    BRP Full cover
    TRIC-LEDS Front Fender Marker Lights & Saddlebag Markers Lights
  2. #52
    I don't think so...
    I'm discussing a potential source of the problem. If you keep getting DESS errors time and time again; perhaps it's not the DESS module...
    Just exploring other parts of the system.
  3. #53
    Vermont
    Quote Originally Posted by Trbayth View Post
    So for the people that are having a problem again with a replaced module: are you positive the dealer installed the new part number? The invoice may have the new part number but unless you can see a part number on the module I wonder if it's really the new one.
    According to the ST service manual, there are three parts to this: the ignition switch, of course, the DESS module (mounted above the battery on the back wall of the frunk) and a ring antenna that looks like it's at the base of the ignition switch. Maybe the antenna is a problem too?
    Just for the heck of it I looked up the module on cheapcycleparts. $132 and if you enter the old part number (710003595) the search results show it crossed out and replaced with the new one (710004190.)
    My Repair order says" Part # 710004190 D.E.S.S MODULE, Deanna
    BRP Half Cover
    BRP Full cover
  4. #54
    Vermont
    Quote Originally Posted by duke50 View Post
    I too had the key code problem while on vacation last week. Had to keep trying but each time it finally started. Also had
    Module replaced once Now dealer is ordering me another.
    14 RT
    Keep us posted on what the your can-am dealer says. Deanna
    BRP Half Cover
    BRP Full cover
  5. #55
    Vermont
    I don't think so...
    Sorry ! Deanna
    BRP Half Cover
    BRP Full cover
  6. #56
    That's quite all right...
    It's not as if I've NEVER gone off-topic before!
  7. #57
    Vermont
    When????????? only picking Deanna
    BRP Half Cover
    BRP Full cover
  8. #58
    Very Active Member StanProff's Avatar
    Jun 2011
    Jonesborough Tennessee
    Default Just happened to me today. DESS code
    I guess it is my turn. was out on a short ride today and after about 45 miles I pulled over to make a phone call. upon restart I got the DESS code.
    I have read about this on the Forum so I did not panic but started running options through my mind on what to do. BTW, it is a '14 RT S SE6 with 4100 miles, I tried about 3 times to do a restart and had no luck. I then turned the switch on and off about 3 or 4 times without trying to start it, The DESS code went away and the Engine code appeared (the little orange picture of an engine), the spyder then started up like nothing was wrong. I suppose the electronics finally hooked up as I was turning the switch on and off. Anyway, rode on home after making another stop at the store for the wife and expecting it to happen again I was pleased when it started up without a problem.
    Guess I'll call the dealer.
    Happy Spyderlovers
  9. #59
    Vermont
    Quote Originally Posted by StanProff View Post
    Lets us know what the dealer says. Good for you that your spyder started up after you turned the switch on and off 3 or 4 times. Deanna
    BRP Half Cover
    BRP Full cover
  10. #60
    Active Member LEEB's Avatar
    SE Pennsylvania
    Default DESS Problems
    As I stated in another post on Saturday, my 2014 RTS decided give me the DESS error when I tried to start it. After many attempts to start it and 2.5 hours later, she started. Now, I was out with the wife today in her car. We were stopped in a line of cars in a construction zone. There were 7 Harleys, mostly trikes, behind us. Since it appeared to be a long stop everyone shut down their engines. 20 minutes later traffic began to move again, so everyone started their engines, including the Harleys. I thought for a moment, what would have happened if I would have been on my Spyder and when I tried to start it in this traffic, I would have gotten the dreaded DESS!! There were no shoulder on the roadway due to the construction. I would have been right there like a huge paper weight, holding up traffic. Would not have been a pretty scene!! Also would have given anyone witnessing the problem a negative opinion of the Spyder product! Come on BRP, get your act together and get this problem fixed, please!!!!
    2014 RT-S Pearl White - 'Miss Pearl'
  11. #61
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by LEEB View Post
    Ditto! Mine has popped up several times in the last two weeks, starting to happen more often. It will quit on me sooner or later as this pattern is much like it did before earlier this year, after which, the DESS module was changed. New ignition and keys last year, new module this year. Taking it to dealer tomorrow to see what they can do.
    Other than this, this machine has been darn near flawless and I love it.
    ted
    Favorite Dealer: Winston-Salem Honda/Can-Am, N.C.
    White 2014 RT SE, Vin 0568 (Sold Aug 16 after purchasing a Slingshot)
    2ndnew tire at 24Kmi..Gen hp43 205-60-15
    New Ignition sys & keys in early '14
    1st Dess Module replaced at 15K
    2ndDess Module replaced at 20K
    Utopia back rest
    Lamonts footpegs
    TricLed brake lights,
    Wired for Gerbing
    Ronbar installed
    Garmin 750 with Ram Mount
    Spyderflaps Mud Flap
    Dimple Drain Plugs
    Tri-Axis handlebar
    Rear brake pads @24K
  12. #62
    Vermont
    Please keep us posted, if it happens again take pictures, and bring the pictures to your can-am dealer, then they can say it did not happen, you will have the proof. Deanna
    BRP Half Cover
    BRP Full cover
  13. #63
    Vermont
    Default Latest UP on my D.E.S.S Key code issue as of 8/18/2015
    Here is the latest up date with my D.E.S.S. KEY Code issue( see date in the title bar) I was asked 2 questions from ( via my personal email address) 1. Do you know if the customer (me) has her Spyder key attached to any other keys? I said " no I have the spyder keys on a separate key chain.
    2. Does the customer carry both keys together? I said yes, I do carry both keys together.
    The above 2 questions were from a BRP Tech ( no name was given). They also said" We have had cases where a cell phone or magnetic card, placed near the ignition switch cause this. This includes any device that may emit some type of frequency.
    Now, this is what my can-am dealership said to me( on the phone this afternoon) If it happens again "
    Turn off/on immediately DO NOT LET THE SYSTEM SHUT DOWN, do the " Turn off/on for 4 to 5 cycles, my dealership will be in contact with me. ***** Stay tuned to this Thread***** The above info was given to me from my dealership. Also, my can-am dealership has opened up a Case with BRP. Deanna
    BRP Half Cover
    BRP Full cover
  14. #64
    Jul 2011
    PA
    Quote Originally Posted by pitzerwm View Post
    In light of the fact that on the 2015 all they changed was the colors, I wouldn't hold my breath.
    I think on this "Thread" I might have read that it has happened on the 2015's?????????? not sure, it might have been on an other thread that I stated. Deanna
    According to the parts manuals, the 2015's have a different ECM and a different DESS Module. Since the DESS must communicate with the ECM to start the bike, my guess is that the 2015 DESS will communicate only with a 2015 ECM. The 2015 DESS number (710004241) is different than both the original 2014 part number and the updated 2014 part number. So they did make changes that are more than skin deep. Just not the kind of changes you'd put in your advertising literature.
    RT and Gold Wing States & Provinces
  15. #65
    Vermont
    Quote Originally Posted by gypsy_100 View Post
    Do you read my newest update on this thread?
    Yes , the 2015 DESS number is ( 710004241) it is different from the original 2014 part number.
    I did post on this thread the new parts numbers for the 2014, ( RS,ST, RT......710004190) 2015 ( RS, ST, RT......710004141) 2015,(F3........710004697) just in case if you missed. Deanna
    BRP Half Cover
    BRP Full cover
  16. #66
    SE Pennsylvania
    Default Interesting twist
    Deanna, thanks for the input! This is interesting. I also have no other keys on my Spyder key chain. I never have my two Spyder keys together either. I have one key, my wife has the other one. We do this for safety in case I lock my key in the Spyder by accident. Now for the other info, this past Saturday when my Spyder gave me the DESS for 2.5 hours, I had my phone on with Blue Tooth turned on, and my Sena headset on with Blue tooth attached to my phone. I don't know if that any impact on my problem or not. But after 2.5 hours, when the Spyder did start I didn't have my helmet with me at the bike, nor turned on. Just the phone. Interesting twist!!
  17. #67
    Jun 2014
    Schenevus NY & Wayne NJ
    I keep my phone and credit cards nowhere near the ignition switch. When I had my DESS error I wasn't even on the bike yet; I had turned the key on to let it boot up while I put my helmet and gloves on.
    I don't keep both keys together but I do keep it on a short keyring along with the saddlebag key, LidLox key, and house keys.
    Trb-- (Roger)
    2014 Cognac STL
    Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    Spyder States Visited
  18. #68
    SE Pennsylvania
    Default DESS
    When I mentioned I had my phone with me on Bluetooth, I forgot to say the phone was in the trunk. Helmet with Sena, well that was on my head, as I was seated on the Spyder!!!!
  19. #69
    Jul 2011
    PA
    Just trying to directly address pitzerwms' comment that all they changed for '15 were the colors.
  20. #70
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    This "Does Not Compute"
    So why, why, why, does BRP install the Bluetooth Dongle in the Frunk?!?! (Rhetorical question!)
    AJ
    . Deanna
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
  21. #71
    Default THE DESS THING
    On the POSSIBLE electrical or OTHER KEY interference thing....................I have gotten the DESS message ( @ 13,200 mi ) But I don't even own a CELL phone and I only carry ONE KEY................ so much for that Theory !!!!!....Mike ...........This is starting to sound Familiar....remember when BRP kept saying ....What heat issues, we ain't got no stink'in HEAT issues ( ref.2013 RT )
  22. #72
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    My Spydee goes in the Shop Friday for the 3,000 service. And, they will be looking into the D.E.S.S error as well. I only get the error with one of my keys and not every time I use that key. So, I'm adding more mystery to this.
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
  23. #73
    Please remember: They DID fix those!
  24. #74
    Jun 2015
    Midland, TX
    Has anyone reported the D.E.S.S. error on models earlier than 2014?
    www.sasspyders.com
    2016 F3T
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    F3T Top Case
    Custom Frunk Wrap
  25. #75
    We might have seen a couple, but they were pretty rare...
