Page 29 of 44 FirstFirst ... 1925262728293031323339 ... LastLast
Results 701 to 725 of 1100
  1. #701
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    Yes, it is 8+ years that this defect has been present in Spyders. Yes, I would think from a manufacturing point of view regarding this defect (I also work at a manufacturing plant) that BRP would/could have come up with some solution to fix the problem. We (Spyder owners) are at the mercy of BRP. I would think that BRP would do something about it because of all the cases that have been opened up about the D.E.S.S. Issues!
    I wonder if any other 2018 Spyder models that have had the D.E.S.S. error/or have been stranded?
    Deanna
    Yes, you would think that BRP would have this fixed by now. I had the DESS module replaced last summer after it showed up the second time. Bike was in the shop for over three weeks. Then a week later the instrument cluster crapped out and needed replacing. On the 26th of July I am taking a trip with my son to Colorado for three weeks, can’t say I’m not a little worried about this leaving me stranded in Western Kansas or Colorado where the dealers are a long way apart. I’d just like to have the DESS turned off if I could and have done with it.
  2. #702
    Houston
    Removing the DESS module will result in a fault and no start condition.
    BRP is not replacing these if they fail outside of warranty. Its much cheaper to turn DESS off than to replace all the components on your dime.....Even if you have to buy a one month BUDS licence and connection module.
    Or ride down and see me and I'll fix you up.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  3. #703
    Vermont
    Quote Originally Posted by Jheck View Post
    I also wonder what BRP will do with the D.E.S.S. module/switch for the 2019 spyder models?
    Good luck on your trip to Colorado with your son.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  4. #704
    Sep 2016
    dilworth,minnesota
    Getting my second one installed. Good customer service would be to disable it on customer request, but won't, probably more lucrative to sell parts. My spyder has spent more time in the shop in its first three years than my Goldwing did in the fifteen years I owned it.
  5. #705
    Vermont
    Quote Originally Posted by rustynail51 View Post
    What spyder model do you have?
    What year is your spyder?
    Did you have your can-am dealership open up a case with BRP?
    If you have any warranty left on your Spyder, the D.E.S.S module is covered under the warranty.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  6. #706
    Sep 2016
    dilworth,minnesota
    It's a 2015 RT- S purchased as a hold over in 2016.
  7. #707
    Active Member BRPcare's Avatar
    Jun 2013
    Québec, Canada
    Today, I was doing some errands, after I left the store went to start my spyder, I got the D.E.S.S KEY CODE "AGAIN" so I put a key into the ignition, got the above error, put the 2nd key into the ignition, got the same message, ( and a coarse I did not have my camera so no picture) the spyder did not start.
    Put both keys in their holders ( plastic) and walked away about 50 to 60 feet, and waited for about 1/2 hour ( in my mine I was thinking of calling Roadside Assistance, if the spyder did not start the 2nd time, I did not have to call Roadside Assistance,) because it started. Then I went on my way.
    Thank god!
    So tomorrow I will call my dealer and tell them I got the D.E.S.S KEY CODE again. I had the D.E.S.S. Module replaced last month ( 7/17/15) and both keys reprogramed. I will post here when I can on what the dealer says. My spyder is a 2014RTS-SE6. I know this happens a lot.
    I did start a " Thread last month on the above subject. I was wandering if anyone else has had this recurring problem?
    Deanna
    Hi there,
    We're sorry your having concerns with your Spyder!
    Please definitely get in touch with your dealer. If you need to locate one near you, please do so in utilizing the following link by selecting your country and searching with your ZIP-Postal Code.
    https://can-am.brp.com/content/canam...r-locator.html
    Should you require further assistance from us, please do not hesitate to contact us directly at brp.care@brp.com (Please ensure to copy and paste this conversation in your email so we have the full history)
    Best,
    Karine-Brp-Care
    BRPcare
    Social Consumer Experience Team
  8. #708
    Sep 2014
    USA
    Quote Originally Posted by BRPcare View Post
    Hi there,
    Best,
    Karine-Brp-Care
    The post was two years ago. I am sure Deanna's issue has been resolved for now Module and Ignition was replaced.
  9. #709
    Houston
    Hi there,
    Best,
    Karine-Brp-Care
    There was a time when the person managing the BRPCares profile actually offered timely and useful information from time to time and often stepped in to help directly via private message. Even helped me with a dire situation 2013 RT once.
    This type of post offering no information and responding to a 2 year old long ago resolved post just for purposes of keeping your post count up for corporate management is disingenuous and shows the lack of any sort of care BRP shows its customers recently.
    Consider actually offering help and being a part of the solution rather than adding to background noise. Or just close the account if you are not going to actually offer anything. This is not the first of this sort of useless cut and paste robo post from BRP.
    ITS NOT HELPFUL.
  10. #710
    Dec 2015
    Oakley Utah
    Hi there, We're sorry your having concerns with your Spyder! Please definitely get in touch with your dealer. If you need to locate one near you, please do so in utilizing the following link by selecting your country and searching with your ZIP-Postal Code. https://can-am.brp.com/content/canam...r-locator.html
    Not helpful. In fact, counterproductive if the intention is to reassure us that BRP CARES!
    2014 RTL Platinum
  11. #711
    Vermont
    Hi there,
    Best,
    Karine-Brp-Care
    HI Karine-Brp- Care,
    Thanks for your concerns, the issue has been fixed, I had this issue ( twice) in July 14,2015 & on Aug. 28th, 2015.
    On July 14,2015 I had the D.E.S.S Module replaced, and on Aug. 28th, 2015 I had the D.E.S.S module & Switch replaced ( under warranty) This warranty service work was done @ Walt's Sales & Service in Derby, Vt. on the above dates.
    If in the future If I have this issue again, I'll contact you directly @ brp.care.@brp.com.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  12. #712
    Active Member gmctech's Avatar
    Aug 2016
    Antigonish, Nova Scotia
    Hi there,
    Best,
    Karine-Brp-Care
    Holy hand grenades.... I nearly spewed my afternoon Java out my nose I laughed so hard at BRP getting in touch about a MAJOR defect/design flaw two years after Deanna's failure and over 8 years into a continuing problem.... A word of advice BRP, you should have remained silent and contacted people via PM and let the membership here trickle out the info that you're offering "help"....
    “The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.”― George Carlin
  13. #713
    Vermont
    Quote Originally Posted by gmctech View Post
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  14. #714
    Jan 2017
    Olympia, Washington
    Thank god!
    Deanna
    Mine did the same thing. The dealer had to go to BRP and replace the whole key system. New keys and all. If you have a trailer like I did make sure they send you a new tumbler for the new keys for the trailer.
  15. #715
    Vermont
    Quote Originally Posted by spider-rider View Post
    Was the "Whole Key system replaced under warranty?
    I don't have a trailer, but I did get a "new trailer tumbler.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  16. #716
    Houston
    We are seeing more and more 2014s that are now out of all warranty coverage and this issue coming up. Even some that got fixed a few years ago. Repair is over $1000 at the dealer. (new ignition, dess module, install labor, programming). We have simply turned off this defective system in BUDS saving our customers considerable funds and aggravation.
  17. #717
    Vermont
    Bump
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  18. #718
    Jul 2016
    Manitoba
    Just had an issue similar to this on my 13 RSS with 7000 kms on it and purchased 3 years ago new in the crate....My battery would drain and when a new battery was installed, the key was turned on and it bypassed the screen indicating to press the mode button and needless to say wouldn't start. The dealer had it for a week and replaced the DESS module and the ignition switch and programmed new keys.I am worried whats gonna happen when the warranty is over in 2 months..
  19. #719
    Vermont
    Quote Originally Posted by LisaJ View Post
    Hi LisaJ: Do you have the B.E.S.T warranty on your spyder?
    If you do the B.E.S.T warranty will cover the D.E.S.S. module.
    Some one else should chime in with the answer.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  20. #720
    Active Member Brettssunshine's Avatar
    Jun 2015
    Lancaster PA transplant (Southern born and bred)
    I have now gotten the dreaded Bad Key error on my 2015 F3S. It is out of every warranty there is....No Warranty. For awhile, I was able to spray inside the ignition with some electrical spray and that kept me going for a couple of months but now....it won't work.
    The dealer, nearest me, has ordered a new ignition system. He's telling me that there is an "antenna" in the ignition that communicates with the chip in the key. Ok, I get that is probably simplifying things, but he also told me the Can Am will do nothing about this. My cost (guessing) will be around $700 when all is said and done. I know the part cost is $400+.
    If using BUDS on my Spyder will save the $$ as well as the aggravation of my Spyder being in the shop....I'm down for it. Where do I find someone that will do this for me?
    2015 F3-S SE6
  21. #721
    Nov 2016
    Upstate NY
    I dont know if the DESS can be deactivated if it doesnt recognize the key at all.
  22. #722
    Jun 2015
    So is the Bad Key and the D.E.S.S. error two different things?
    2015 F3-S SE6
  23. #723
    Nov 2016
    Upstate NY
    My guess is yes. If the screen says bad key, then disabling the DESS might not fix it. My screen said DESS error when it went bad. I could be wrong though.
  24. #724
    May 2019
    New Mexico
    Brp's system sounds like a sort of RFID system to me, a topic which I am quite familiar with. AFAIK, these keys have no batteries, and it's rare for a batteryless RFID chip to go bad. The dealer is on the right path, start with the antenna element and work your way back to the reader module.
  25. #725
    Vermont
    Any golf you out there who have bought Rykers, have you had the dreaded D.E.S.S. error?
    Just curious
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
