Results 1 to 10 of 10
    Sep 2011
    Austin TX
    Default rear shock issue
    While working on tail light I noticed that the spring on the rear shock is rubbing the shock body. Is this normal? If not any ideas other than have it replaced under warranty. BTW Spyder is a 2014 ST with just over 600 mi.
    Mar 2012
    NJ
    Not normal at all. Any pics? Sounds like something is bent...
    Sent from my SCH-I545 using Tapatalk
    Default Not good..!!
    can you look at the shaft from different angles to if it is bent..??
    ​2012 RS sm5
    Jul 2011
    Mitchell, Ontario, Canada
    Some pics would be good.
    2018 F3 LIMITED
    Active Member TexAmRider's Avatar
    Jul 2013
    Coahoma, Texas
    Default Now Im Curious
    Quote Originally Posted by Allensr View Post
    I've had a knocking noise on my 14 RTL for some time and have not been able to find it. Sounds like coming from the right side rear of the bike. Possible it could be the shock?
    2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
    Very Active Member 900Dave's Avatar
    Jun 2013
    Fleetwood, PA
    I do not think this is "out of the ordinary" at all. What you have is a low quality OEM shock. It is not perfect but it gets the job done at the end of the day. I have seen this many times on Snowmobiles. The coil spring rubs the shock body. A higher quality shock will not do this. My Elka on the back of my ST no rubbing. Here is a pick of my OEM rear shock with about 5000 miles on it. I have about 10,000 now on the Elka and have not seen this.
    The shock is not perfectly centered in the coil and has very little clearance on this side.
    2016 Spyder F3 Limited Steel Black Metallic
    Lamonster approved LED Headlights
    Lamonsters LED Fog lights
    BRP Driver & Passenger backrest
    BRP Trailer Hitch
    Shamrock Black & Polished
    Signature light
    Elka front shock's
    Rolo Laser Alignment
    Dual Power outlets
    Garmin 590 GPS
    Sep 2011
    Austin TX
    900Dave that is just what my shock looks like. There is not very much clearance at all. I will ask the guys to look at it when I take it in for it's service.
    Thanks Allen
    Mar 2012
    NJ
    Are you guys bottoming out a lot? I have close to 15k on my 12' RS rear shock and a good friend is close to 20k on his and the spring has never touched the shock body on either.
    Sep 2011
    Austin TX
    never bottomed out. nothing looks bent. it just looks as if the spring is not held in the center of the shock.
    Allen
    Jun 2013
    Fleetwood, PA
    Quote Originally Posted by DrewNJ View Post
    I may have been bottoming out. My wife is on the back most of the time. The OEM shock is non adjustable. This is why I also put an Elka on the rear so I could adjust for 2 up riding and full saddle bags.
    BRP Trailer Hitch
    Signature light
    Elka front shock's
    Dual Power outlets
    Garmin 590 GPS
