Results 1 to 25 of 25
    Crystal city mo
    Default Boging down lost power
    Hi all I have a 2014 rt with the new
    1300 ace eng . It's Been boging down
    and vibration at speeds68 to 70 plus
    has any one out their experience this yet
    and if so how did u fix it .
    I am noticing by your previous posts that you just recently came off a 2013 ST. You mentioned issues with running rough in first gear on that one.
    Seems similar with the 2014 RT mentioned above. You also mentioned that the 2014 was purchased used with 3,900 miles on it.
    Is it possible that you are using wrong rpm's for shifting? The 1330 likes to be shifted in the 3,000 - 3,500 range. The 2013 (998) likes to be shifted in the 5,000 - 5,500 range.
    Has you dealer addressed any of the issues on your new 2014? If the engine seems to be "bogging out," that does not sound right to me. Is there another rider that you trust who could possibly give yours a "test spin" just to see if they notice something out of order?
    Please let us know what you find out.
    See if you can have someone else who's used to the "Spyder's Byte", give it a test run for you!
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Spyder Byte???
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Quote Originally Posted by Pampurrs View Post
    Spyder Byte???
    Testing for "normalcy." "They all do it"
    Apr 2012
    Northglenn Colorado
    Dont say bogging the engine around here, they hate that word, I know I used it an I am still getting flack about it.
    Tell us a bit more about how you are driving it. The shift points of my 2014 get me moving the way I want if I'm just loafing. If I'm driving in a more spirited manner I shift in the 3,000 to 3,500 range. ECO mode flattens the torque curve. Have you read your owner's manual?
    "Mine feels like it is bogging if I run in 6th gear below 75 and most have belt vibration around 70-75.
    The fix is to stay in 5th till 80 unless you are going downhill or have a good tailwind."
    Sorry: I've got the throw the Bull flag on this one...
    Mar 2015
    San Tan Valley, AZ
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    I can drive 50 mph in 6th. The tach is running at 2850. If I need a surge of power--I only need to twist the throttle. The 1330 will "get up and go!"
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    When I pull my trailer with my 14 and run in sixth gear I will actually loose speed/rpm up a hill on the freeway, even I shift down to 5th it will not pick up again. Dropping down to 4th takes care of it and I can then shift to 5th. As the grade lessons I can go back into 6th. 6th is overdrive and great for mileage but you are not in the torque band. While not as obvious without the trailer, the same thing applies when I head up a good grade.
    What are you hauling; Lead ingots?
    Two-up and no trailer: my bike hauls me effortlessly with upshifts at the earliest possible instant.
    2nd gear is too quick to even look at the speedo...
    3rd gear at 20 mph...
    4th at 27 mph...
    5th at 32...
    and 6th at 39 mph...
    As I said; it's effortless!
    western Colorado
    totally with bob. The 1330 has the power to move your Butt easy.My suggestion is try Eco mode to get the hang of the shift points.
    I honestly think that folks will sometimes post something; just to start a fight...
    And I'm just not smart enough, to not take the bait!
    There appears to be some of that going on of late. The trollinators seem to be doing a good job though.
    Mar 2012
    NJ
    So the guy isn't all that thrilled with the power of the 1330 and has belt vibes and you all are calling him a troll?...really?
    Sent from my SCH-I545 using Tapatalk
    Quote Originally Posted by DrewNJ View Post
    I see that you publicly like to disagree with me almost anytime I make a comment.
    Here: No sir. I did not call the OP (jima) a troll. He does not fit the description and has posted other threads that were interesting.
    I did say....there have been a lot of trolls on board lately. It should be obvious who they are/were.
    I was commenting on a statement made by another member.
    If you are going to challenge me (and I am sure okay with that)--just please get your facts and information right.
    Mar 2012
    NJ
    Don't be so full of yourself. I was speaking to the group in general. I didn't quote you. I am not following you around and I honestly don't care what you say. Nothing personal...
    The guy isn't all that impressed with the 1330 power. Either was I. Fact is that it's a good motor, but not a powerhouse great motor that some of the Kool aide drinking SL members make it out to be.
    Drew,
    If you look at the "1330 versus the 998" debate, from a perspective that encompasses the larger picture; several other attributes start to surface:
    Lower maintenance costs
    More torque at lower rpms does help to move a heavier load off of the line easier.
    The better fuel economy
    Clearly; this is not an issue solely discussed at the chassis dyno or dragstrip.
    When the six speed transmission is added to the mix; the gap between the two packages becomes greater.
    Now: I'm NOT saying that the 998 isn't a good engine: depending upon your application and intended usage; there may be better ones that are available.
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I think the beauty of the new engine and SE6 transmission is that there are no right or wrong shift points. I may shift at 3500nrpms while someone else shifts at 2500rpms the only thing that decides what shift is correct is the spyder. If the RPMs are too low for the next gear the spyder will not let you shift until the rpms are raised. I am not speaking about performance and shifting but just general riding and shifting. This is just my opinion and what I have noticed while reading the comments throughout this site about shifting gears in general.
    Yup! It's not a "fussy" combination at all...
    Mar 2012
    NJ
    Hey Bob,
    I didn't think this was a comparison thread or a 998 vs. 1330 thread. That's a whole different topic.
    The guy simply stated that he wasn't all that happy with the performance of the 1330 and there are quite a few of us who have a similar view who haven't made the model change. Maybe BRP will change that.....
    It's kinda sad how a lot of you jump all over someone when they don't drink the latest flavor of kool aide and agree with the herd. It's like a lot of you have to try to convince someone that they are wrong when they don't like something, or are under impressed.
    Personally, I've found that both motors make mediocre, at best, power in stock form. Some of us even believe poor power stock. The 1330 is a slug and completely uninspiring motor. Like riding a tractor. However, if muling it up, lugging around in a single gear, not worrying about shifting, and being happy about slightly better fuel economy is your thing, then the 1330 will do the job just fine, especially with the SE tranny. Go get em'!
    It's time for BRP to REALLY step it up!
    When you've ridden the 998 and the 1330; it lends some perspective to the discussion.
    I'm not bashing the 998s; I just like the 1330 better.
    Jul 2015
    Surprise, AZ
    Wait a minute.....you mean i have to shift?
