congrats on a fine new ryde... 26 miles is a path home when is the real ryding going to start... well welcome to the spyder world and this site. The real fun starts now in both places though your safer on the road....
Gene and Ilana De Laney Mt. Helix, California
2012 RS sm5
I bought my RT about a month ago and am at about 2000 miles. Just this past weekend I started getting over my fear of high speed sweeping turns, especially on the highway. Part of the solution was to look further ahead down the road, and to lock in my arm on the outside of the turn. It cuts down on the darting about with each bump. I'm loving it.
It really shouldn't dart around in the corners, sweeping or tight. You may want to see about lazer alignment and if you don't have the upgraded sway bar you will want to get that. Remember light grip on the bars, and put as much weight as you can on the outside leg as you turn, and just to make it seem more confusing, lean your body a little bit into the tune as well. Its kinda like ballroom dancing!
Good info. Thank you for sharing!
2015 Can-Am RT Limited Pearl White
Farkle: Laser alignment, Bararon sway bar, Bump skid with LED, Tri Axis adjustable handlebar, BRP heated comfort seat, Utopia backrest, Kott grills, Tailgunner Black Widow exhaust, BRP adjustable side wind deflectors, and Upper wind deflectors.
I bought my '15 a month ago and reached 3,000 miles, yesterday
On long rydes, we (my hubs has a Kaw Voyager) stop every 50 or 60 miles or so to walk around and take a short break.
Looking ahead in the curves is key for me, if I don't do that, the ride through the curves can be a
bit strange. I have a laser alignment. I don't have the added sway bar, yet. Not sure I am going to need it.
Also, relax your grip on the handle bars and enjoy the ryde!! It is definitely a different feel as you go over bumps
and grooves in the road. It gets easier after you get some miles on it!
Have a great time!!
2015 Spyder RT Limited, Red Pearl
Tri-Axis Handle Bars
Contigo Cup
Cup Holder
Cargo Nets
Additional turn signals mounted behind speaker grill
12v cable for heated clothing
Sheepskin seat cover
Baja Ron Sway bar
Have a great time!!
Good info. Thanks!
