Results 1 to 6 of 6
    Crystal city mo
    Default Compressor sounding notice
    Hi all
    My last issue 😄 I have 2014 rt s
    and theirs a compressor sounding notice that
    comes on all the time does anyone else's bike
    do that ? It happen s on flat , on hills .,
    stop sighns and wil driving .
    Thanks for your help in advance
    Jun 2010
    Las Vegas
    The RT-S and RT-Ltd have an onboard compressor for the rear air shock. You will hear it kick on at various times.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default ALL THE TIME SOUND ??????
    Quote Originally Posted by SpyderAnn01 View Post
    ....with Ann, but what do you mean by " all the time ".........The Air compressor has an Auto fill feature which is determined by weight among other criteria.......But I don't think you should hear it 5 or 6 times a ride .........Ann what is normal on this ........Mike
    Jun 2010
    Las Vegas
    Mike, it does depend on your size and I'm sure there are other factors. I keep my rear shock at the hardest setting so I would think that it might make the compressor kick on more often to keep it at the highest psi. 5 or 6 times wouldn't be a big deal if you are on a long ride but 5 or 6 times in a few miles is probably not normal
    2010 RT- 622
    I keep mine set up near the top also...
    Since it is monitoring the ride-height; it'll bleed out air, or add it even as temperatures change within the system. It's a pretty small amount of air, and temperature changes DO make it work a lot harder...
    When I start out in the morning; mine will come on, and set the height. By the time I've ridden about two miles. it'll be bleeding off air already...
    If yours is absolutely running non-stop; you've got a leak in the system. See your dealer.
    Nov 2012
    North Las Vegas, NV
    Ours just quit working, but I couldn't tell with my bad hearing. Noticed the rear fender was very close to the tire and it rode harder too. I am putting air in manually until my dealer will look at it. It usually cycles at hard stops.
    As was mentioned earlier if it runs all the time there is a leak.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
