Results 1 to 15 of 15
Thread: Missing a Part
    Nov 2014
    Alexandria, VA
    Default Missing a Part
    Need some assistance. I noticed last night that if you see on Pic 1 I have that black cup inside the wheel (sorry don't know what to call it), on PIc 2 is the black cup I am talking about. What is that black cup does to the brakes or what? I know that cup spins around. Thanks.
    2016 Spyder F3 Limited, black, Special Edition, SE6, belt tensioner, Bajaron swaybar, AKARAPOVIC, F4 windshield with vent. Previous 2015 RTS in black and 2011 RT Limited, SE5 with Bajaron Swaybar and Bumpskid
    Active Member KennW's Avatar
    Oct 2013
    Gold Coast QLD Australia
    Just a crappy plastic cap that covers the stub axle. There are options that work better but most likely cheapest option is to get a new OEM unit and apply a little stylistic to hold it a little more securely.
    Regards
    Kenn
    Nov 2014
    Alexandria, VA
    Quote Originally Posted by KennW View Post
    Regards
    Kenn
    Thank you Kenn, should I worry riding without if until I get a new one?
    NE Illinois
    I would not be concerned at all about riding it during the very short time that it will take to get a replacement. My guess is that there are many out there riding without them, either knowingly or unknowingly. Based on a suggestion in an old forum thread, I applied some black silicone to mine in order to keep them from coming off too easily.
    MEP
    ​2019 F3 Limited
    Now I'm gonna have to go take a peek, and see if both of mine are still there...
    Jun 2010
    Las Vegas
    Quote Originally Posted by wengerda View Post
    I rode mine from Las Vegas to Alaska and back without one and I didn't have any trouble.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Caps...
    There are actually four (4) such caps on your spyder. One on each end of the rear axel and one on each front axel on the inside behind the wheels. They help keep area clean and prevent rust etc.. actually I think they are just like hub caps. I would worry about the front wheel ones more so that the rear. The front ones do spin and if you should run across a plastic bag or anything that can get wound up in there it could mess up your brakes or abs system.
    Interesting note , on our last ryde (15 spyders) two of them had one cap left up front and one had both (a 2015). Wonder if they all fall off or they never get put on..?? I have Lamonts caps though pricey very well made great accent and they don't fall off...
    ​2012 RS sm5
    Hi Gene,
    Are the ones up front the same size as the ones on the rear axle?
    (I've got those OEM rear caps just sitting around: gathering dust!)
    Very Active Member bronzeflex42's Avatar
    Sep 2014
    Sandersville, GA
    Default caps?
    Wow going to take a look at my when i get off work.
    2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
    Quote Originally Posted by bronzeflex42 View Post
    Since it's over 90 degrees outside; I decided to wait until evening to check mine!
    (Laying down on the blacktop just doesn't seem like a great idea... )
    Default Not sure..!!
    Hi Gene,
    Mine came without caps (thats why I wonder if they forget to put them on). I would have to check but the rear cover a 36mm nut and the fronts I believe are smaller. What holds them in is the hollow center of the axle in the rear anyway....let me check... okay, upon inspection, they will work but you would have to cut down the center stem. The front axle is not hollow all the way threw. This may be the reason they fall off. On the rear they go in a couple of inches on the fronts not even an inch...
    ​2012 RS sm5
    Oct 2013
    Just an item worth checking if you don't have the caps on your stub axles. "Ensure" wires and brake lines are securely fastened so as to not catch on the stub axle when they're rotating.
    Regards
    Kenn
    Nov 2012
    North Las Vegas, NV
    My 2012 never had any. Didn't know they were supposed to be there.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2014
    Mint Hill, NC
    This was kicked around somewhere else on SL. I checked mine and was dissatisfied with how easily they came off so I applied a bit of Permatex RTV silicone to the attachment tabs and they aren't going anywhere now. For those who have lost and want to replace with OEM the 2014 PN is 705401100, cost $4.99.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2011
    Mitchell, Ontario, Canada
    Those caps is just decorative and serve no useful function other than to make it look better. Many GS/RS models did not have them at all.
    2018 F3 LIMITED
