2013 RT Scoops on 2014 RT
Has anybody installed the scoops on a '14 RT? I saw several on '13s this morning and love the look! I checked on the parts and they are available. If you have done it were there any issues?
Sent from my LG-V496 using Tapatalk
Don't know..!!
Heard they will not be available till all the recall work is done. Had someone trying to get the scoops for a 2010 but could not...
2012 RS sm5
I know where I can get them but am a curious if they will fit?
Ordered and received in 3 Days for the 2012 ($70 Plus $50 to Cut the panels) and I installed! Dropped panels Off and Picked up then took 2 Hours (Slow) to install at home!
2014 May be different size panels? Probably Do Not need it with the ACE1330?
Sea Doo GTI-SE 90 Jet Ski!!
13/14 Air Scoops
I have a set to do my 14 RTS but I'm too busy to start that project until I get back from my Hatfield & McCoy trip the first week in August...BUT I KNOW SOMEONE ELSE THAT WILL SOON BE DOING THIS TO THEIR 2014 BEFORE ME...STAND BY...larryd
Find it amazing just how many people want their RT's to look just like my 2013 RT. 😉
Regards
Kenn
I'll see my dealer this week and see if I can get the scoops for my 2012 RT.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I saw these scoops installed on a 13 and I too am interested on installing on my 14.
They look awesome.
I can not tell you if they will work on your 2014 but for clarification I had them installed this week on my 2010 RTS at Gargano GSS Powersports in East Haven, CT at no cost. The owner Bob Gargano said that he was able to get reimbursed for the work by submitting it as a good will claim. I will also add that there is a substantial reduction in heat after the installation.
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
Nicely done ! I'd love to see them.
IBA #47122
2020 RT Limited Asphalt Grey
I don't completely understand this thread. What would be the point in installing the scoops designed to remedy the 13 heat issues on a 14? Seems to me that it would be purely aesthetics. What am I missing?
With the amount of money that I spend on must-have farkles (just ask my wife, lol!), I would never question someone wanting the scoops for the looks. Just didn't know if there was some other reason, since my 14 RT has zero heat issues.
Nope; we don't need them on the 1330s...
I like the look of them on the 2013s.
It's another visual cue, to distance them from the prior bikes...
After all the doubters over the 2013 fix BRP has got to be grinning ear to ear now.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Your Dealer CAN get the Kit for $70 (If out of warranty like me) and you bring in the Panels to get cut-If your dealer will do this (?) and then you install them. The instructions are part of the recall instructions posted in the other thread about this.
I was out in 85 degrees and never went above 4 Bars when at a constant speed! Its a Must to also take of the Acoustic panels under the Tupperware and If you have a 2010-2012 the 2 underneath panels are very easy to take off if you jack it up and look for 2-3 10mm Small bolts that hold on the lower panels-2 are attached to the middle frame.
With ALL 3 done the air enters the scoops- Flows over and around the cylinder heads and gas tank and then a Lot of it escapes underneath through the panels removed underneath.
PS: Someone PM,d me about this but its better to ask the "Whole" group.
Scoops
I have a 12 ' RTS and the scoops are being installed Aug 4th by the dealer at no cost to me. BRP good will warranty claim. So if your dealer tells you BRP is not covering older RT"s they are not going to bat for you.
2012 RTS SE5, GT stripes, belt guard, hmt brake light, lower vent heat deflector, driver foot boards, Corbin seat, RH vent covers
Make sure you keep your receipts. If BRP ever issues a Warranty Bulletin to install the scoops on the 2012 RT's, you should be reimbursed. Since they work so well on the 2013's, that may not be as far fetched as it sounds.
I'm sure that Steve is, at least. But he'll never say that.
Thanks! Mine was out of warranty But I mentioned the "Good Will" phrase - I will keep the CC Receipt for sure!!!
$125 was a worthwhile Donation BUT I will deduct it off my F3 Offer in Mid-October?
I didn't have to pay for the scoops or labor as BRP covered it.
