Results 1 to 12 of 12
    SF Bay Area
    Default F3 gas cap issue?
    So my friend just picked up her new F3s. Using the key, she unlocked the gas cap, no problem. Now, trying to close the gas cap and lock back up with key, but no go. Key will not turn all the way to lock. Tried applying pressure to cap, making sure it was down all the way and retried to turn key to lock but still no luck You can turn the key all the way to open or close and can remove the key but can not get the key to lock the gas cap. Any ideas?
    2014 RT-SE6
    Akrapovic Sport Touring 3C Silencer
    High Mount Third Brake Light
    Kuryakyn Black ISO Motorcycle Grips
    LaMonster Spyderdock
    LED’s everywhere!
    Russell Day-Long w/ Backrest
    Seal Floorboards
    Spyderpops Bump Skid
    Spyderpops KOTT Grill (Keep Out The Trash)
    Squared Away Alignment
    Riding taught me why dogs stick their heads out the window!
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    Quote Originally Posted by martiniman View Post
    Yes, they are hard to click all the way closed. I leave the key in the lock and press down HARD with both thumbs on the edges of the cap until I hear a distinct "click". Then remove the key.
    jb
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    SF Bay Area
    Quote Originally Posted by xwingnut View Post
    jb
    I assume leave the key in the open position while pushing down on the cap?
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
    Oct 2015
    Laurel, Mississippi
    Default F3 Gas cap
    There seems to be a lot of variation in closing difficulty from one F3 to another and at different times on the same F3. Here is a recent link with some additional suggestions on the topic: http://www.spyderlovers.com/forums/s...-GAS-CAP/page2
    Ours seems to be more difficult to close at times but never as bad as some have described.
    Lee & Karen
    2022 F3 Limited - Matte Black
    F4 Customs Windshield, Lamonster Driver Backrest,
    Lamonster Fog Lights, Wrap My SPYDER Tank Protector,
    Lumina Trailer
    Bossier LoUiSiAna
    Quote Originally Posted by SpyD59 View Post
    Is it only that bike, only that driver? Use the suggestions above & report back. It fundamentally was designed to be used by all users weak & strong, the can gum up & need internal cleaning but that takes few years or poor cleaning conditions.
    Feb 2015
    Default yes
    YES....just don't force anything with the key.
    John B.
    Active Member siny10309's Avatar
    Dec 2015
    Tropical Island ____________of Staten
    jb
    What he said! took me an hour the first time I opened it to figure this out.
    2015 F3 SE6
    This is a known issue, and I believe that Lamont is working on a solution.
    Mar 2015
    Westminster, SC, United States
    Yes 15,000 miles later I finally figured out do not force the key. Above is correct, it does not get any easier. Good seal, huh!
    Mar 2015
    New York
    jb
    This is an excellent piece of advice and works every time! Well said, thank you!
    Oxford, GA
    jb
    I'm so glad I found this. Works like a charm. Thanks.
    Default Let's see....
    The best way with a sign that your done is to open the cap leave the key in...close the cap without touching the key press the cap firmly towards the front till the key pops back to the center...that's the sign ..pull the key and be on your merry way....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
