Results 1 to 19 of 19
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    Default Dual USB Power Outlet in Dash
    I'm wanting to put a USB Power Outlet in the dash of my RT. Can I just tap in to the Gas Gauge wires for power?
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
    Default USB POWER
    Since USB devices draw very little power I don't why not .........Mike
    Registered Users yamahog's Avatar
    Jun 2012
    Vernon Texas
    Default It works
    It is working for me, I replaced both gauges with dual USB ports and they charge my phones and gopro no problem, so far.
    Ram mount on both upper air deflectors custom ram mount for ATC9k action cam
    Chrome Dear Whistles
    Dual Color MagicFLEX® Channelz finder lights
    TIPZ units
    CAN AM SPYDER RT RADIATOR UPPER BLOCK OFF PLATE
    CAN AM SPYDER RT RADIATOR LOWER BLOCK OFF PLATE
    CATALYTIC CONVERTER SHIELD
    TITANIUM EXHAUST WRAP
    JT's AIR FILTER KIT
    Jun 2015
    Midland, TX
    Quote Originally Posted by yamahog View Post
    I was not planning to remove my fuel gauge. I just wanted to tap in to the fuel gauge for power and ground with the above USB power port. I know smart phones do not draw more than 1 amp or a tad more.
    www.sasspyders.com
    2016 F3T
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    F3T Top Case
    Custom Frunk Wrap
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    The draw for a USB port is never more than 1.8 amps (with an output of 500 milliamps), but your add-on USB port probably pulls less so you should have a little wiggle room. It is normally less than one amp for a cell phone or GPS.
    Since many of the add-on USB chargers fit in place of one of the gauges and the gauges pull almost nothing, I think you'll be well within tolerance to add this on. Of course, if it melts your Spyder into a worthless pile of steel and plastic it's not my fault.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    May 2013
    Stanton, ca
    Well first off do not quote incorrect USB specs. 1.8 amps is not true anymore!
    And by the way 500 milliamps is .5 AMPs not 1.8.
    For instance, the iPhone 6 Plus, Apple tablets, etc all require a minimum of 2.1 AMPs to charge!
    USB plugs do NOT have current control in them. If you wire a USB plug to a 12V source the "device" you plug in will draw what it needs to. So do not think you are protected because it is a USB plug!!!! Also do not think that any device you plug in will limit it's AMP draw to 1.8 AMPs. Not true anymore folks! So be careful!
    Now, in 2015 they changed the gauges on the RT. I would not tap into the wires on these new gauges as they run through the cluster and are not mean to power anything.
    The new 2015 gauges no longer have a "light bulb". They are self powered with a LED inside now. The new gauges are a 3 wire system not a 4 wire like previous years.
    The previous year RT's had a 4 wire system. 3 wires for the gauge signal to the cluster and a 4th single stab on connector wire to power the light bulb. This single wire did not run through the cluster so it was safe to use to power USB devices.
    Basically the pre-2015 gauges had a triangular plug which had 3 wires in it. The middle wire on that plug was ground and can be used for 12V ground connection. The other two wires are gauge wires. Yes one is 12V to power the internal gauge and the other is a signal wire, which by the way if you use a volt meter on either you will get "about" 12v as a reading on both. THESE TWO run through the cluster!
    Then there was the single "stab on" connector wire. This powers the light bulb in the gauge. This does not run through the cluster and is fused with other lights at the fuse box.
    The new gauges have a single square connector plug and only 3 wires.
    Now with that said, some may have used one of the 3 wires on the new gauges to power a USB port. But I personally would NOT do that based on what I said above about how a device can now easily demand higher currents from power source than 1.8 AMPs. You may be OK with older or smaller devices that will not draw more than say .5 AMPs but if you plug in something that demands more like a iPhone 6 Plus, you risk possible damage to your cluster!
    Bob
    2011 RT-S SM5 - Black
    Sep 2014
    United States
    Default I'm NOT WORTHY!!!
    Quote Originally Posted by finless View Post
    Bob
    Please ignore my previous post and listen to WHAT HE SAID!!
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Jun 2015
    Midland, TX
    That is the kind of information I was looking for. I'll just keep my phone in the rear trunk and powered as it is now.
    www.sasspyders.com
    2016 F3T
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    F3T Top Case
    Custom Frunk Wrap
    Active Member Rawhide kid's Avatar
    Jun 2015
    Goodyear, AZ
    Hmmmmm
    so Bob what is the best way to wire In a USB hub safely, in the dash? I bought a hub.
    Ill look around on SL to see if this has been discussed already. Apologize if it has.
    Rawhide Kid
    2014 Spyder RT Limited. Cognac
    Goodyear, AZ
    May 2013
    Stanton, ca
    Quote Originally Posted by Rawhide kid View Post
    Hmmmmm
    In my opinion there is a fused and reasonable connection you can tap into.
    That is the power wires that run to the front trunk to power the optional cig lighter plug you can get for the Frunk.
    The wires are there on all models just the cig plug is not.
    Bob
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by KJWEB View Post
    That's exactly where I keep mine; one less piece of junk to lug around when off the bike. I haven't even changed the fuse to make the socket always hot.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Feb 2015
    Kansas
    Bob
    Bob didn't know there was power in the Fruck. Are the wires for this under the Fruck liner, and if so do you know what color they are? Also do these run to the back of bike somewhere? Would appreciate your input. I have 2012 RT Limited.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by JayHawker View Post
    It's not in the front trunk it's behind it. Tie strapped to a left side frame member.
    2018 F3 LIMITED
    May 2013
    Stanton, ca
    If I could find the BRP install instructions for the frunk cig lighter plug, that would help him find the connector.
    I just cannot find them and I know someone posted them here before as I remember seeing them.
    If someone has a copy please post it.
    Bob
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Default Frunk Power
    I got a cigarette lighter power outlet on ebay much cheaper than BRP. I installed it in the frunk. There is a rubber cover over the hole for the power port on the right side as you are facing the frunk. Taking the battery out helps a lot but can be done without removing it. Just makes it hard to get the rubber boot over the wire connections. Once you remover the plug you can see the boot and the wires are tucked inside it I was able to pull them out. Take the battery cover off and you can get your hand behind to put the locking ring over the wires then plug them in. insert port into hole and thread the ring onto it and tighten. Once done slip the rubber boot over the back of it to help to keep the wires from corroding when getting wet. Took me all of about 15 minutes and it is powered all the time if you move the fuse so I am assuming it is tied into the one in the rear trunk! I hope this helps.
    14 RT-S , Stock Large brake pedal White Pearl
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Is the one in the trunk powered all the time? If so, how does the battery not die?
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    Funny thing about electricty------- the electromotive force ( voltage ) can be in the wire, ready to go BUT if there is no current ( amperage ) draw---- NO electricty will flow, but it's ready to. A cig lighter, with nothing in it will not complete a circuit and not draw down a battery. You're safe.
    I have cig plugs in both trunks and a USB cig plug adapter handy.
    Lew L
    2014 RTS , Circuit Yellow
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    If you go to a cig lighter socket connected directly to battery, you can power a usb plugin, heated gear, power to an air pump, or anything else you want.
    Just saying
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Member glorybiz's Avatar
    May 2018
    Ellicott City, Maryland
    I added the Dual USB/voltmeter combo so I can monitor the battery and alternator. plugged into the gas meter power and frame ground. you can get it on EBAY
    https://www.ebay.com/itm/12V-24V-4-2...frcectupt=true
    2016 RT Limited , stock yes red
