PROBLEM: Need Help Changing Headlight
I have a 2012 RS SE5. The Headlights will not come on. Fog lights work fine as well as turn signals, brakes etc. I change out the fuse underneath the seat. I have removed the front cluster and the housing cap for the bulb. However I cannot figure out how to detach the bulb so that I can insert the replacement. The manual says: "Remove the bulb by releasing both clips with a small flathead screwdriver." I am unable to find the clips that it's referring to. Please help. Thanks in advance.
