RT Starting without touching brake pedal
Have noticed since doing cat bypass on my RT it will now start without touching the brake pedal.
I've checked the brake pedal travel under the RT and there is nothing anywhere near touching/hindering the full travel of the brake pedal.
Have not heard of this situation before on this forum or others so any constructive suggestions of possible causes will be very much appreciated.
Regards
Kenn
Pragmatic Member
Regards
Kenn
Mine starts without engaging the brake if it's in neutral. If it was shut down and left in any gear, I have to engage the brake to start it. It's been that way since I got it a month ago.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
Pam
If I shut down in gear then I have to push the break pedal down. otherwise just reach over and hit start.
To cold now but shall check mine out in the morning. Many thanks for your replies
Regards
Kenn
my 2014 RT limited auto from day one has always started without touching the brake petal..
osm
Checked my 2010 and it started, without touching the break, when it was in N. Any other time, I have to press the break.
Sent from my SM-N910V using Tapatalk
